About the Fsys of SPC5633mmlq60
xuzheng
hi,
   I'm using spc5633mmlq60, the max Fsys is 60mhz,according the datasheet.
   Whe i set the Fsys 40Mhz,56Mhz,it work well.But  when i set 60Mhz,i could not work.
  Why the SPC5633mmlq60 Fsys could not be set 60Mhz?
                                               MFD + 4
        Fsys   =  Fref * ------------------------------
                                   (PREDIV + 1) * 2e(RFD)
     FMPLL setting:  Fsys = 60Mhz,
     (MFD=11,PREDIV=3,RFD=0,Fref=16Mhz)
davidtosenovjan
Hi, this is incorrect setting. fVCO is out of range.
Use MFD = 11, PREDIF = 1, RFD = 1
Here my colleague shared great tool for MPC55xx and MPC56xx configuration. I believe it’ll help you:
Excel MPC55xx/MPC56xx PLL Calculator
