I've got Problems installing the S32 Design Studio IDE.
If I run the installer as admin it collects all data needed for the Installation, but aborts directly after with the errormessage "multiple instances of the installer not allowed. Exiting". If I run the installer as a regular user I get asked for admin-rights at the product-activation. When I enter my product-ID another error comes up (online as well as offline activation, screenshot below).
OS: Win7 Enterprise 64-Bit (6.1 Build 7601)
System manufacturer: Lenovo
Model: 4484Y1X
CPU: Intel Core i5 2.4 GHz
RAM: 4096 MB
Thanks in advance for your help.
Solved! Go to Solution.
Solved the Problem after looking at the install logs. Seems like the installer doesn't ask for admin-rights when it tries to install the unistaller.
Worked fine after logging in as admin on my machine.
Thanks for your sharing and good luck!
