We changed DDR device on our MX6Q board (because the original one will not be sold). We tried two different DDR models but got the same error. The MFG tool failed to flash images into the board. Attached please find the error log.
Please advise what we should do to solve this issue. Do we need to tune the DDR parameters and how?
Is there a verified DDR device list that customer can use for i.MX6Q/6D?
Thanks!
Original Attachment has been moved to: mfg_fail.txt.zip
I hope the following helps DRAM Customization on i.MX6x
Yuri
Hi Yuri,
Thanks a lot for your reply! I will study the method described in the link.
Hi Frank,
i know you from Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and L... thread.
i had the same problem as you, you can look at my issue thread uboot logo color is not normal
can you teil me how did you solved this problem, and can you give me you QQ or email, my QQ;861239127, email: fulinux@sina.com.
Hople your reply !
fulinux.
