i need know the example code to generate a variable pwm but other than the Eixample: 35.6.5.14.1 Variable Frequency PWM Mode,reference manual because it is very tangled
----------------------------------------------------------------------------------------------------------------------- Note: If this post answers your question, please click the Correct Answer button. Thank you! -----------------------------------------------------------------------------------------------------------------------
hello
I suggest you refer :
Seeking Kinetis demo code under KDS 3.0.0
Complementary PWM on FRDM-KL25Z using processor expert
hope this can help you.
Zhang Jun
