I'd like to ask for help/advice while migrating project from Tower based module (TWR-k70f120) to MK61 based custom board.
I'm not sure which of the two following approaches are better:
Could you please tell me which solution is better for this purpose ?
Maciej
Solved! Go to Solution.
Hello Maciej,
For the first issue, you need to install the KSDK eclipse_update, please check the following video (minute 3:20). This video is for KSDK 1.2 but it is the same process for KSDK1.3.
For the second issue, if you want to use the MQX for KSDK then you need to modify manually the files according the thread you mentioned https://community.freescale.com/thread/355899.
Attached to this thread you will find a document that shows how to port applications built for MQX RTOS v4.2.0 to MQX RTOS for Kinetis SDK v1.2.0.
I hope this helps.
Sol
Hello Maciej,
I hope this helps.
Sol
