Hi ,
I need to support external FLASH memory to be configured for m_text ( code ) .
How to add driver support and configuration for the same in the KDS IDE using Processor Expert.
Thanks in Advance.
Hi Anil,
I recommend you to refer to the post:
Is it possible to force code into a non-standard section?
Under Build options you can change the memory definition generated by Processor Expert in the dinker file.
Pascal
Freescale Technical Support
