Hello community. Recently I used Gstreamer on i.MX Phase2 board (Yocto built OS), I found the plugin mpegtsdemux didn't work as gst_element_factory_make("mpegtsdemux", NULL) returned NULL. Type in command: gst-inspect-0.10 mpegtsdemux, the output information only including "plugin detail", No "element" and "pad".
I have installed gstreamer0.10-plugins-bad, and libgstmpegtsdemux.so existed in right directory.
How to fix the problem? Anly help will be appreciated.
For example:
demuxer_1 = gst_element_factory_make ("mpegtsdemux", "demux1");
if(!demuxer_1) g_printerr("demux1 not created\n");
Do you mean it return NULL? Is your pipeline work in your program?
For your reference:
jimmychan 撰写:
For example:
For your reference:
Yeah, gst_element_factory_make("mpegtsdemux", "demux1") returns NULL, and pipeline doesn't work.
Following is the output message of command: gst-inspect-0.10 mpegtsdemux
Plugin Details:
Description: MPEG TS demuxer
Filename: /usr/lib/gstreamer-0.10/libgstmpegtsdemux.so
Version: 0.10.23
License: unknown
Source module: gst-plugins-bad
Source release date: 2012-02-20
Binary package: GStreamer Bad Plug-ins source release
Origin URL: Unknown package origin
tsparse: MPEG transport stream parser
tsdemux: MPEG transport stream demuxer
2 features:
+-- 2 elements
Later I used "tsdemux" instead of "mpegtsdemux", and it really works.
I guess "mpegtsdemux" is just a plugin, it includes "tsparse" and "tsdemux" which are the true elements required by gst_element_factory_make()
is my guess right? anyhow "tsdemux" solved my problem :smileyhappy:
