Hi, I am new to iMX family and we want to stream video using iMX6 Dual over LVDS.
1) Can you please suggest whatall modifications I need to do in which driver.
2) Which API of ldb.c I should call to initiate transfer over LVDS?
3) How to get frames from Frame buffer processed by IPU to stream over LVDS?
It may be recommended to use the Gstreamer, please refer to the
following resources :
https://community.freescale.com/docs/DOC-93387
https://community.freescale.com/thread/340677
http://boundarydevices.com/streaming-camera-using-gstreamer/
Yuri
It is really helpful
Thank you
Thank you verymuch Yuri Muhin
Rinkesh Patel
Rinkesh
What do you mean by stream video using imx6 Dual over LVDS?
If want your display to be LVDS than you can modified your bootargs to "video=mxcfb0:dev=ldb,LDB-XGA,if=RGB565".
Saurabh
Yes I understood. Thank you very much
