Can't open my project anymore
MAPC
Senior Contributor I
Hello, dears
My project was running ok. Suddenly, when I open Code Warrior 10.5, it pops us the following message:
And since then, I just can't open the project anymore. When I close a message, another one comes up, and this never ends. It is curious that this happens with only one project in my workspace. The other project can be opened without problems. I couldn't identify the reason for that. Probably, one or more files might be corrupted, I don't know.
Did anybody face such a problem?
Marco Coelho
Tags (3)
BlackNight
It might be something with the parallel build settings?
Can you try the fix mentioned in CW ProjectsView Project Loading Verification Internal Error
MAPC
Hi, Erich
I just tried it and worked perfectly.
The doesn't ocurr only with QG8. In my project, I used MC9S08PA8. It seems like a kind of bug in Code Warrior v. 10.5?
I hope that was solved in Code Warrior v. 10.6.
Thank you very much!
Marco Coelho
BlackNight
MAPC
Hi, Erich
Thank you very much and congratulations for your valuable job on mcuoneclipse.com!
Marco Coelho
