Hi everyone, I want to know how to recover the P2041RDB-PB because the u-boot on the NOR flash got accidentally erased.
Thanks in advance for your aswer
There is an application note AN4267.pdf about how to recover corrupt Flash, which could be downloaded from Freescale public Website.
You should use Flash Programmer from CW, import P2041RDB_NOR_FLASH.xml Target Task, Add Program Verify Action, select Erase sector before program and set offset to 0xEFF80000 (last 512K of NOR).
Also, you can take a look at this thread: P1020RDB NOR FLASH PROGRAMMING
Adrian
