I implement the BINFS on iMX53 WinCE7 follow the advice in the followting forum.
How to support MultiBIN(BINFS) on SDMMC for Freescale IMX5x WinCE 6.0/7.0 BSP -blog archive
But after override the corresponding codes follow the advice in above blog . BINFS for SDMMC WinCE7.zip ;But after I build the whole iMX53 project ,it come out "Build Failed " as follows:
Error Information:
BUILD: [02:0000014443:ERRORE] Error(s) in directory "F:\WINCE700\platform\common\src\soc\COMMON_FSL_V3\BINFS_SDCARD\SDMEMORY\".
BUILD: [02:0000014444:ERRORE] NMAKE : fatal error U1073: don't know how to make 'F:\WINCE700\osdesigns\iMX53_SMD_Mobility\Wince700\iMX53_SMD_ARMV7_Retail\cesysgen\platcomm\iMX53_SMD\lib\ARMV7\retail\binfs_sdbus.lib'
Judging from the above error prompt.
First, I thought the binfs_sdbus.lib is not compile, but I find the binfs_sdbus.lib lies in the directory:":\WINCE700\osdesigns\iMX53_SMD_Mobility\Wince700\iMX53_SMD_ARMV7_Retail\cesysgen\platcomm\iMX53_SMD\lib\ARMV7\retail\";
Second, while I rebuild (build -c) the above directory "BINFS_SDCARD", the output window will have the above error information. But when I respectively rebuild the sub-directories of BINFS_SDCARD ( FormatFAT, SDBUS, SDCARDLIB, SDMEMORY). the four directories are all builded succeed.
The BINFS_SDCARD directory and build errors files are in the attachment.
I find the source file and dirs file are OK.What's the matter ? A little strange, I now fully confused by this problem.
So , anyone know what the reason is? Could U share your experience here ? Great thx ~.~
Best regards.
Original Attachment has been moved to: Build.log.zip
Original Attachment has been moved to: bldsys.log.zip
Original Attachment has been moved to: BINFS_SDCARD.rar.zip
Holy
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Holy
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to
reply with an update to this discussion.
Yixing
Holy
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need Freescale help, please feel free to contact us.
Yixing
