I have the CW version 10.7 on Windows 10,and when i 'Edit' the connection in 'Flash File to Target',it appears a message "cwide.exe has stopped working"and then it exit.and next time,there is no message, exist .
Also when I debug,it appears "the selection cannot be launched,and there is no recent launches"
I tried reinstalling, but it did not work.
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
MC9S12ZVML128,
Thanks.
Hello 孜文 张,
It seems the same case with your another thread CodeWarrior unable to launch
I have reply you on that case.
TIC
