Mount the Heat sink
Mount the Heat sink
eishishibusawa
Dear Sir
Customer is considering to mount a heat sink on i.MX6DL.
How is the allowable tightening torque to fix the heat sink?
Eishi SHIBUSAWA
Labels (2)
joanxie
for heat sink questions on i.mx6 , pls refer to the  "i.MX 6 Series Thermal Management Guidelines" Application Note:
http://www.nxp.com/assets/documents/data/en/application-notes/AN4579.pdf
for thermal estimations implementation.
eishishibusawa
Dear joanxie
How about this case?
Would you please reply.
Eishi SHIBUSAWA
joanxie
pls refer to the application note 4871 as below:
https://www.nxp.com/docs/en/application-note/AN4871.pdf?fsrch=1&sr=1&pageNum=1
eishishibusawa
Dear Joan Xie
Thank you for your reply.
I refer to AN 4579, but I cannot find the statement for mounting condition of the heat sink.
For example, in the LS 1021A, the AN4878 has the following description. (P78 Table 72)
"Ensure the spring force does not exceed 15 pounds force (65 Newtons)."
Please tell me the mounting conditions of i.MX6DL.
Eishi SHIBUSAWA
ko-hey
Senior Contributor II
Hi Joan Xie
I have same question with other my customer.
Could you follow and answer this thread ?
If you cannot understand what we're saying, please ask.
Ko-hey
