Hi all,
One of the function of this patch is to add MD5 authentication support in Kernel2.6.35.
Another is when user set a specific IPSEC encryption and authentication, it will display the information through console.
BTW, I'm using P1010RDB for verification.
Share with you guys~
1. drivers\crypto\caam\Algapi.c
+ #define printf(args...) printk(args) + #define printf(args...) printk(args)
164 switch (authsize * 8) {
165 case 96:
166 - if (ctx->alg_op != OP_ALG_ALGSEL_SHA1) {
167 - dev_err(dev, "h/w doesn't support %d-bit ICV trunc."
168 - " length with chosen authentication algorithm",
169 - authsize * 8);
170 - return -EOPNOTSUPP;
171 - }
172 - ctx->class2_alg_type = AUTH_TYPE_IPSEC_SHA1HMAC_96;
+ if (ctx->alg_op == OP_ALG_ALGSEL_MD5){
+ ctx->class2_alg_type = AUTH_TYPE_IPSEC_MD5HMAC_96;
+ printf("AUTH_TYPE : MD5\n");
+ if (ctx->class1_alg_type == CIPHER_TYPE_IPSEC_AESCBC)
+ printf("ALO_TYPE : AES\n");
+ else if (ctx->class1_alg_type == CIPHER_TYPE_IPSEC_3DESCBC)
+ printf("ALO_TYPE : 3DES\n");
+ else if (ctx->class1_alg_type == CIPHER_TYPE_IPSEC_DESCBC)
+ printf("ALO_TYPE : DES\n");
+ else if (ctx->alg_op == OP_ALG_ALGSEL_SHA1){
+ ctx->class2_alg_type = AUTH_TYPE_IPSEC_SHA1HMAC_96;
+ printf("AUTH_TYPE : SHA1\n");
+ else {
+ dev_err(dev, "h/w doesn't support %d-bit ICV trunc."
+ " length with chosen authentication algorithm",
+ authsize * 8);
+ return -EOPNOTSUPP;
break;
1243 static struct caam_alg_template driver_algs[] = {
1244 /* single-pass ipsec_esp descriptor */
+ .name = "authenc(hmac(md5),cbc(aes))",
+ .driver_name = "authenc-hmac-md5-cbc-aes-caam",
+ .blocksize = AES_BLOCK_SIZE,
+ .aead = {
+ .setkey = aead_authenc_setkey,
+ .setauthsize = aead_authenc_setauthsize,
+ .encrypt = aead_authenc_encrypt_first,
+ .decrypt = aead_authenc_decrypt_first,
+ .givencrypt = aead_authenc_givencrypt_first,
+ .geniv = "<built-in>",
+ .ivsize = AES_BLOCK_SIZE,
+ .maxauthsize = MD5_DIGEST_SIZE,
+ .class1_alg_type = CIPHER_TYPE_IPSEC_AESCBC,
+ .class2_alg_type = AUTH_TYPE_IPSEC_MD5HMAC_96,
+ .alg_op = OP_ALG_ALGSEL_MD5,
+ .name = "authenc(hmac(md5),cbc(des3_ede))",
+ .driver_name = "authenc-hmac-md5-cbc-des3_ede-caam",
+ .blocksize = DES3_EDE_BLOCK_SIZE,
+ .aead = {
+ .ivsize = DES3_EDE_BLOCK_SIZE,
+ .class1_alg_type = CIPHER_TYPE_IPSEC_3DESCBC,
+ .name = "authenc(hmac(md5),cbc(des))",
+ .driver_name = "authenc-hmac-md5-cbc-des-caam",
+ .blocksize = DES_BLOCK_SIZE,
+ .aead = {
+ .ivsize = DES_BLOCK_SIZE,
+ .class1_alg_type = CIPHER_TYPE_IPSEC_DESCBC,
1245 {
1246 .name = "authenc(hmac(sha1),cbc(aes))",
1247 .driver_name = "authenc-hmac-sha1-cbc-aes-caam",
2. drivers\crypto\caam\compat.h
58 #include <crypto/algapi.h>
59 #include <crypto/aes.h>
60 #include <crypto/des.h>
61 #include <crypto/sha.h>
+ #include <crypto/md5.h>
62 #include <crypto/aead.h>
63 #include <crypto/authenc.h>
64 #include <crypto/scatterwalk.h>
