How to install misc JDK in Ubuntu for Android build
To build Android version earlier than Lollipop from source code, you need the Sun's 1.6 SDK to be installed for ubuntu as the link Initializing a Build Environment | Android Developers.
You may still cannot get the Sun's JDK  with below instruction:
$ sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner"
$ sudo apt
-get update
$ sudo apt
-get install sun-java6-jdk
There are below options to help install the Sun's JDK  if you cannot find a valid source through apt-get commands:
$ wget --no-cookies --header "Cookie: gpw_e24=http%3A%2F%2Fwww.oracle.com%2F" http://download.oracle.com/otn-pub/java/jdk/6u45-b06/jdk-6u45-linux-x64.bin
$ chmod u+x jdk-6u45-linux-x64.bin
$ ./jdk-6u45-linux-x64.bin
$ sudo mv jdk1.6.0_45 /opt
$ sudo update-alternatives --install /usr/bin/java java /opt/java/64/jdk1.6.0_45/bin/java 1
$ sudo update-alternatives --install /usr/bin/javac javac /opt/java/64/jdk1.6.0_45/bin/javac 1
$ sudo update-alternatives --install /usr/bin/jar jar /opt/java/64/jdk1.6.0_45/bin/jar 1
# if you have already install some other version of JDK, please export the JAVA_HOME env before your android build every time
$ export JAVA_HOME=/opt/jdk1.6.0_45/
#or you can directly link the java binary to the sdk version you need as below:
sudo ln -s /opt/java/64/jdk1.6.0_45/bin/jar /bin/jar
sudo ln -s/opt/java/64/jdk1.6.0_45/java /bin/java
sudo ln -s/opt/java/64/jdk1.6.0_45/javac /bin/javac
sudo ln -s/opt/java/64/jdk1.6.0_45/javah /bin/javah
sudo ln -s/opt/java/64/jdk1.6.0_45/javadoc /bin/javadoc
javaws /bin/javaws
To built the Android version Lollipop and Marshmallow from source code, you need the OpenJDK 7 to be installed for ubuntu as the link Initializing a Build Environment | Android Developers.
$ sudo apt-get update
$ sudo apt-get install openjdk-7-jdk
You may have both openjdk7 and SUN JDK 1.6 intalled in your ubuntu to build different Android version. If you have default java SDK to be Sun's JDK 1.6, you can just use below commands to make android build system use the openjdk7 for Lollipop built
$ export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64/
$ cd myandroid
$ . ./build/envsetup.sh           //be sure to resetup the envsetup, and pick the platform to be built
$ lunch
ラベル(3)
コメント
Thanks for the useful guide.
I had a couple of problems with it, which I will explain here in case it helps anyone else.
1)  sudo mv jdk1.6.0_45 /opt
This seems to put the code in the wrong place. Instead I used:
sudo mkdir -p /opt/java/64
sudo mv jdk1.6.0_45 /opt/java/64
2) sudo ln -s/opt/java/64/jdk1.6.0_45/java /bin/java
There seems to be a space missing so if you just copy/paste these symlink commands they don't work.(The first one is OK, the other 5 fail).
Here are copies with the space added:
sudo ln -s /opt/java/64/jdk1.6.0_45/java /bin/java
sudo ln -s /opt/java/64/jdk1.6.0_45/javac /bin/javac
sudo ln -s /opt/java/64/jdk1.6.0_45/javah /bin/javah
sudo ln -s /opt/java/64/jdk1.6.0_45/javadoc /bin/javadoc
javaws /bin/javaws
All comments welcome! :smileyhappy:
Thanks for sharing! I had the same problems on the directory structure and had to use a similar approach.
I also had to add --no-check-certificate when using wget in order to successfully download the .bin, so the command ended up as follow:
$ wget --no-cookies --no-check-certificate --header "Cookie: gpw_e24=http%3A%2F%2Fwww.oracle.com%2F" http://download.oracle.com/otn-pub/java/jdk/6u45-b06/jdk-6u45-linux-x64.bin
The easiest way to do this is to go to:
Java Archive Downloads - Java SE 6
Look for "jdk-6u45-linux-x64.bin" and manually download it. You will have to login (or create an account). Once it has finished downloading, I usually will copy the jdk (jdk-6u45-linux-x64.bin) to the home directory.
Then we need to run the binary and move it to a shared location:
$ chmod +x jdk-6u45-linux-x64.bin
$ sudo ./jdk-6u45-linux-x64.bin
$ sudo mv jdk1.6.0_45 /usr/lib/jvm/
Now you have to install all binaries and give them highest priority, This will also overwrite the previous version of Java Binaries in your computer.
$ sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jdk1.6.0_45/bin/java 1
$ sudo update-alternatives --install /usr/bin/javac javac /usr/lib/jvm/jdk1.6.0_45/bin/javac 1
$ sudo update-alternatives --install /usr/bin/javaws javaws /usr/lib/jvm/jdk1.6.0_45/bin/javaws 1
$ sudo update-alternatives --install /usr/bin/jar jar /usr/lib/jvm/jdk1.6.0_45/bin/jar 1
$ sudo update-alternatives --install /usr/bin/javadoc javadoc /usr/lib/jvm/jdk1.6.0_45/bin/javadoc 1
Now check if JDK 1.6 is selected on this:
$ sudo update-alternatives --config java
$ sudo update-alternatives --config javac
$ sudo update-alternatives --config javaws
$ sudo update-alternatives --config jar
$ sudo update-alternatives --config javadoc
Now JDK is configured! To check if it is done
Execute this is Terminal:
$ java -version
Output will be similar to this:
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
Now the copy of "jdk-6u45-linux-x64.bin" in your home directory can be deleted, and you can save the one you downloaded for future use.
I know this works for Ubuntu 12.04 LTS (Precise) through Ubuntu 14.04 LTS (Trusty).
Hope this helps out.
Dave
The "deb http://archive.canonical.com/ lucid partner" source doesn't work. Now we can try:
$ sudo add-apt-repository "deb http://ppa.launchpad.net/ferramroberto/java/ubuntu natty main"
$ sudo apt-get install sun-java6-jdk
%3CLINGO-SUB%20id%3D%22lingo-sub-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAndroid%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEUbuntu%E3%81%ABmisc%20JDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89Lollipop%E3%82%88%E3%82%8A%E5%89%8D%E3%81%AEAndroid%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Sun%E3%81%AE1.6%20SDK%E3%82%92ubuntu%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20href%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20title%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAndroid%E9%96%8B%E7%99%BA%E8%80%85%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7Sun%E3%81%AEJDK%E3%82%92%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20sudo%20add%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Erepository%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22str%22%20style%3D%22color%3A%20%23008800%3B%22%3E%3CSPAN%3E%22deb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Farchive.canonical.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Farchive.canonical.com%2F%3C%2FA%3E%3CSPAN%3E%20lucid%20partner%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%24%20sudo%20apt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%20update%3CBR%20%2F%3E%24%20sudo%20apt%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%20install%20sun%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejava6%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejdk%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3Eapt-get%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E3%80%81Sun%20%E3%81%AE%20JDK%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%24%20wget%20--no-cookies%20--header%20%22Cookie%3A%20gpw_e24%3Dhttp%253A%252F%252Fwww.oracle.com%252F%22%20%3CA%20href%3D%22http%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20chmod%20u%2Bx%20jdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20.%2Fjdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20mv%20jdk1.6.0_45%20%2Fopt%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjava%20java%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjava%201%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavac%20javac%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjavac%201%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjar%20jar%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjar%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%23%E3%81%99%E3%81%A7%E3%81%AB%E4%BB%96%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEJDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Android%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E5%89%8D%E3%81%AB%E6%AF%8E%E5%9B%9EJAVA_HOME%E7%92%B0%E5%A2%83%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eexport%20JAVA_HOME%3D%2Fopt%2Fjdk1.6.0_45%2F%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%23or%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Java%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E5%BF%85%E8%A6%81%E3%81%AASDK%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fbin%2Fjar%2Fbin%2Fjar%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavac%20%2Fbin%2Fjavac%3CBR%20%2F%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavah%20%2Fbin%2Fjavah%3CBR%20%2F%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavadoc%20%2Fbin%2Fjavadoc%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Ejavaws%20%2Fbin%2Fjavaws%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89Android%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AELollipop%E3%81%A8Marshmallow%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81OpenJDK%207%E3%82%92ubuntu%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20href%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20title%3D%22http%3A%2F%2Fsource.android.com%2Fsource%2Finitializing.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAndroid%E9%96%8B%E7%99%BA%E8%80%85%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22ch-inject-variable%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22ch-inject-keymethods%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eupdate%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-variable%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3E%24%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Esudo%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eapt%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22kwd%22%20style%3D%22color%3A%20%23000088%3B%22%3Eget%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Einstall%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20monospace%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Eopenjdk%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-number%22%20style%3D%22color%3A%20%233677a9%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22lit%22%20style%3D%22color%3A%20%23006666%3B%22%3E7%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22pun%22%20style%3D%22color%3A%20%23666600%3B%20font-family%3A%20monospace%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22ch-inject-identifier%22%20style%3D%22color%3A%20%23d0d0d0%3B%20font-family%3A%20monospace%3B%22%3E%3CSPAN%20class%3D%22pln%22%20style%3D%22color%3A%20%23000000%3B%22%3Ejdk%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CP%3E%E7%95%B0%E3%81%AA%E3%82%8BAndroid%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81ubuntu%E3%81%ABopenjdk7%E3%81%A8SUN%20JDK%201.6%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEjava%20SDK%E3%81%8CSun%E3%81%AEJDK%201.6%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81Android%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8CLollipop%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEopenjdk7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%24%20export%20JAVA_HOME%3D%2Fusr%2Flib%2Fjvm%2Fjava-7-openjdk-amd64%2F%3C%2FP%3E%3CP%3E%24%20cd%20myandroid%E3%81%AE%3C%2FP%3E%3CP%3E%24%20..%2Fbuild%2F.envsetup.sh%20%2F%2F%E5%BF%85%E3%81%9Aenvsetup%E3%82%92%E5%86%8D%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%24%E3%83%A9%E3%83%B3%E3%83%81%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEUbuntu%E3%81%ABmisc%20JDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8Cdeb%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Farchive.canonical.com%2F%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20monospace%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Farchive.canonical.com%2F%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20monospace%3B%20color%3A%20%23008800%3B%22%3E%20lucid%20partner%E3%80%8D%E3%82%BD%E3%83%BC%E3%82%B9%20%3C%2FSPAN%3E%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E%24%20sudo%20add-apt-repository%20%22deb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fppa.launchpad.net%2Fferramroberto%2Fjava%2Fubuntu%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fppa.launchpad.net%2Fferramroberto%2Fjava%2Fubuntu%3C%2FA%3E%3CSPAN%3E%20natty%20main%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20apt-get%20update%3C%2FP%3E%3CP%3E%24%20sudo%20apt-get%20install%20sun-java6-jdk%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEUbuntu%E3%81%ABmisc%20JDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.oracle.com%2Ftechnetwork%2Fjava%2Fjavasebusiness%2Fdownloads%2Fjava-archive-downloads-javase6-419409.html%22%20title%3D%22http%3A%2F%2Fwww.oracle.com%2Ftechnetwork%2Fjava%2Fjavasebusiness%2Fdownloads%2Fjava-archive-downloads-javase6-419409.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EJava%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20-%20Java%20SE%206%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%80%8Cjdk-6u45-linux-x64.bin%E3%80%8D%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3(%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90)%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81jdk(jdk-6u45-linux-x64.bin)%E3%82%92%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E5%85%B1%E6%9C%89%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20chmod%20%2Bx%20jdk-6u45-linux-x64.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20.%2Fjdk-6u45-linux-x64.bin%3C%2FP%3E%3CP%3E%24%20sudo%20mv%20jdk1.6.0_45%20%2Fusr%2Flib%2Fjvm%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E6%9C%80%E5%84%AA%E5%85%88%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E5%86%85%E3%81%AEJava%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%82%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjava%20java%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjava%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavac%20javac%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavac%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavaws%20javaws%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavaws%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjar%20jar%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjar%201%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--install%20%2Fusr%2Fbin%2Fjavadoc%20javadoc%20%2Fusr%2Flib%2Fjvm%2Fjdk1.6.0_45%2Fbin%2Fjavadoc%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81JDK%201.6%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20sudo%20update-alternatives%20--config%20java%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20javac%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20javaws%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20jar%3C%2FP%3E%3CP%3E%24%20sudo%20update-alternatives%20--config%20javadoc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7JDK%E3%81%8C%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20java%20-%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EJava%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8C1.6.0_45%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EJava(TM)SE%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E7%92%B0%E5%A2%83(%E3%83%93%E3%83%AB%E3%83%891.6.0_45-b06)%3C%2FP%3E%3CP%3EJava%20HotSpot(TM)%2064%E3%83%93%E3%83%83%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BCVM(%E3%83%93%E3%83%AB%E3%83%8920.45-b01%E3%80%81%E6%B7%B7%E5%90%88%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%80%8Cjdk-6u45-linux-x64.bin%E3%80%8D%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%A7%E3%81%8D%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%82%92%E5%BE%8C%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8CUbuntu%2012.04%20LTS(Precise)%E3%81%8B%E3%82%89Ubuntu%2014.04%20LTS(Trusty)%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDave%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEUbuntu%E3%81%ABmisc%20JDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81.bin%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81wget%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB--no-check-certificate%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%24%20wget%20--no-cookies%20--no-check-certificate%20--header%20%22Cookie%3A%20gpw_e24%3Dhttp%253A%252F%252Fwww.oracle.com%252F%22%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.oracle.com%2Fotn-pub%2Fjava%2Fjdk%2F6u45-b06%2Fjdk-6u45-linux-x64.bin%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEUbuntu%E3%81%ABmisc%20JDK%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BE%BF%E5%88%A9%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E4%BB%96%E3%81%AE%E8%AA%B0%E3%81%8B%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E5%82%99%E3%81%88%E3%81%A6%E3%81%93%E3%81%93%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1)%26nbsp%3B%20sudo%20mv%20jdk1.6.0_45%20%2Fopt%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E7%A7%81%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3Esudo%20mkdir%20-p%20%2Fopt%2Fjava%2F64%3C%2FP%3E%3CP%3Esudo%20mv%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20jdk1.6.0_45%20%2Fopt%2Fjava%2F64%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSTRONG%3E2)%20sudo%20ln%20-s%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82(%E6%9C%80%E5%88%9D%E3%81%AE%201%20%E3%81%A4%E3%81%AF%20OK%E3%80%81%E4%BB%96%E3%81%AE%205%20%E3%81%A4%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjava%20%2Fbin%2Fjava%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavac%20%2Fbin%2Fjavac%3CBR%20%2F%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavah%20%2Fbin%2Fjavah%3CBR%20%2F%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2Fjavadoc%20%2Fbin%2Fjavadoc%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Esudo%20ln%20-s%20%2Fopt%2Fjava%2F64%2Fjdk1.6.0_45%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3Ejavaws%20%2Fbin%2Fjavaws%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99!%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-17-2013 10:31 PM
更新者:
