i.MX6 ESPI slave mode support patch based on rel_imx_3.0.35_4.1.0
This patch is for i.MX6 ESPI controller slave mode (SPI timing mode 0 and 3) support.
Hardware prepare:
  Connect two i.MX6 Sabresd boards, remove U14 SPI nor device, connect two boards like:
         MISO --- MISO
         MOSI --- MOSI
         SS     --- SS
         CLK   --- CLK
         GND  ---  GND
Software prepare:
1>Apply patch spi_slave_2013_10_12.patch on 3.0.35_4.1.0 Linux BSP release.
    Note two board all need choose CONFIG_IMX6_SDP_MISCSPI, CONFIG_SPI_SPIDEV of kernel
Symbol: IMX6_SDP_MISCSPI [=y]
  |     -> Device Drivers
  |       -> Misc devices (MISC_DEVICES [=y])
Symbol: SPI_SPIDEV [=y]
  |     -> Device Drivers
  |       -> SPI support (SPI [=y])
   Spi master board choose CONFIG_SPI_IMX_VER_2_3
Symbol: SPI_IMX_VER_2_3 [=y]
  |     -> Device Drivers
  |         -> Choose IMX SPI work mode (<choice> [=y])
   Spi slave board choose CONFIG_SPI_IMX_VER_2_3_SLAVE.
Symbol: SPI_IMX_VER_2_3_SLAVE [=y]
  |     -> Device Drivers
2>Compile test application  mxc_spi_test1.c to generate mxc_spi_test.
3> Test steps :
  1. First  spi slave board input cmd mxc-spi-test –D 0 –b 32 –L 32
  2. Then spi master board input cmd mxc-spi-test –D 0 –b 32 –L 32
          This tool will write its buffer ( the content is same in two side ) to the  other board  through  SPI bus , then read data from the other board , and compare with its write buffer.
タグ(3)
添付
コメント
Dear Peng,
     When I had seen your SPI patch for the i.MX6 slave mode. I meet the same question at the i.MX27 too. I have not use the the i.MX6 so I can't get the SPI programe and make the patch. So I want ask you some quetions in order to solve it because I think the i.MX27 is same as the i.MX6 for the SPI.
     The follow is my testing procedure:
     I want to configure spi1 in slave mode in Linux 2.6.19.2 for i.mx27. That is I am using an i.mx27 board as a SPI MASTER and other board as a SLAVE to communicate with each other. I adopt the 3-wire link each other such as master MOSI<->slave MOSI , master MISO<-> slave MISO  and master CLK->slave CLK . The master SPI only send the data and slave SPI only receive the data.
     According to the SPI device and driver of the i.MX27 we only change the master to the SLAVE of the MODE bit in the CONREG Register in Linux and tranfer same 8bit every time at about 8*1000*1000 bauterate .The master mode work well where the MOSI pin can transfer the data and the CLK pin can get the clock .But the SLAVE mode can’t work and the i.mx27 cannot react the interrupt and still only stay in the spi_put_tx_data function state and can not go to the receive mode in which the processor is  be the slave mode.
     The SPI can only inturrupt to receive once and later transfer the data.
cmd->port is 1
The SPI is 1 and the fd is 4
spi_bitbang :bitbang_work
mxc_spi :mxc_spi_chipselect
The origin mxc_spi_chipselect control register is 1024
The origin mxc_spi_chipselect control registre masked is 1024
mxc_spi :spi_find_baudrate The SPI probe as slave and work mode is SPI_MODE_0.
The mxc_spi_chipselect control register is 66567
mxc_spi :mxc_spi_transfer
mxc_spi :spi_enable_interrupt
mxc_spi :mxc_spi_isr
mxc_spi :spi_get_rx_data
mxc_spi :spi_put_tx_data
     I donot know why the slave can't receive anything.
     My question is :
      1.I do't know where I forget or make mistake to change both software and the hardware. So In order to work in slave mode can any body provide me some link.
     2.how to update i.mx27 spi device file and driver file.if you want get the  C resouce, please tell me. I will give you later.
     3. Would you mind give me the SPI master and slave programe source. I can study where the register and the programe should change for the SPI slave.
     4.If you are a chinese,I want communicate with each other in chinese .
     Please give me some advice.
wangjian
Could anyone comment on how to modify this patch to allow both master and slave mode drivers to be used at the same time?
Is there a version of this available that is compatible with the 3.10.17 driver or similar? The freescale 3.10.17 kernel repo's SPI driver still doesn't have SPI slave mode support.
I am using a hummingboard-gate which has imx6solo processor.
I compiled mainline kernel 4.2.6, it runs ok headless. now how do I add spi slave device support to it?
can you update your patch or at least point me where I should look. I am new to the device tree structure.
%3CLINGO-SUB%20id%3D%22lingo-sub-1105658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%91%E3%83%83%E3%83%81(rel_imx_3.0.35_4.1.0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81i.MX6%20ESPI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%20(SPI%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%200%20%E3%81%8A%E3%82%88%E3%81%B3%203)%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E2%E3%81%A4%E3%81%AEi.MX6%20Sabresd%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81U14%20SPI%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MISO%20---%20MISO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MOSI%20---%20MOSI%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3ESS---SS%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3ECLK---CLK%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20GND%26nbsp%3B%20---%26nbsp%3B%20GND%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%BA%96%E5%82%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E1%26gt%3B3.0.35_4.1.0%E3%81%AB%E3%83%91%E3%83%83%E3%83%81spi_slave_2013_10_12.patch%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8BLinux%20BSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20line-height%3A%201.5em%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AECONFIG_SPI_SPIDEV%20CONFIG_IMX6_SDP_MISCSPI%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E8%A8%98%E5%8F%B7%3A%20IMX6_SDP_MISCSPI%20%5B%3Dy%5D%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E5%A0%B4%E6%89%80%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%97%8F%26gt%3B%20%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9(MISC_DEVICES%20%5B%3Dy%5D)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E8%A8%98%E5%8F%B7%3A%20SPI_SPIDEV%20%5B%3Dy%5D%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E5%A0%B4%E6%89%80%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%97%8F%26gt%3B%20SPI%E5%AF%BE%E5%BF%9C(SPI%5B%3Dy%5D)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%22%3E%20SPI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%22%3ECONFIG_SPI_IMX_VER_2_3%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%A8%98%E5%8F%B7%3A%20SPI_IMX_VER_2_3%20%5B%3Dy%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E5%A0%B4%E6%89%80%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%97%8F%26gt%3B%20SPI%E5%AF%BE%E5%BF%9C(SPI%5B%3Dy%5D)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20IMX%3CCHOICE%3E%20SPI%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E(%5B%3Dy%5D)%3C%2FCHOICE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20line-height%3A%201.5em%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFCONFIG_SPI_IMX_VER_2_3_SLAVE%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%A8%98%E5%8F%B7%3A%20SPI_IMX_VER_2_3_SLAVE%20%5B%3Dy%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E5%A0%B4%E6%89%80%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%97%8F%26gt%3B%20SPI%E5%AF%BE%E5%BF%9C(SPI%5B%3Dy%5D)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20IMX%3CCHOICE%3E%20SPI%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E(%5B%3Dy%5D)%3C%2FCHOICE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E2%26gt%3B%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3mxc_spi_test1.c%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6mxc_spi_test%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E3%26gt%3B%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal-leading-zero%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%20%E6%9C%80%E5%88%9D%E3%81%AE%20spi%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%9C%E3%83%BC%E3%83%89%E5%85%A5%E5%8A%9B%20cmd%20mxc-spi-test%20%E2%80%93D%200%20%E2%80%93b%2032%20%E2%80%93L%2032%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%20%E6%AC%A1%E3%81%AB%E3%80%81spi%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABcmd%20mxc-spi-test%20%E2%80%93D%200%20%E2%80%93b%2032%20%E2%80%93L%2032%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81SPI%E3%83%90%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1(%E5%86%85%E5%AE%B9%E3%81%AF%E4%B8%A1%E5%81%B4%E3%81%A7%E5%90%8C%E3%81%98)%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E6%AC%A1%E3%81%AB%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81rel_imx_3.0.35_4.1.0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFimx6solo%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%8F%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB4.2.6%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%98%E3%83%83%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%AF%E3%80%81SPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E7%A7%81%E3%81%8C%E8%A6%8B%E3%82%8B%E3%81%B9%E3%81%8D%E5%A0%B4%E6%89%80%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E7%A7%81%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%84%E3%83%AA%E3%83%BC%E6%A7%8B%E9%80%A0%E3%81%AB%E4%B8%8D%E6%85%A3%E3%82%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81rel_imx_3.0.35_4.1.0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E3.10.17%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%203.10.17%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%20SPI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81%E3%81%BE%E3%81%A0%20SPI%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81rel_imx_3.0.35_4.1.0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20ESPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81rel_imx_3.0.35_4.1.0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3EDear%20Peng%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3Ei.MX6%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AESPI%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%A6%8B%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82i.MX27%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E8%B3%AA%E5%95%8F%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%E3%80%82i.MX6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81SPI%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81i.MX27%E3%81%AFSPI%E3%81%AEi.MX6%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%86%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%20%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3Ei.mx27%E7%94%A8%E3%81%ABLinux%202.6.19.2%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7spi1%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81i.mx27%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92SPI%20MASTER%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92SLAVE%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%9B%B8%E4%BA%92%E3%81%AB%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCMOSI%26lt%3B-%26gt%3B%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96MOSI%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCMISO%26lt%3B-%26gt%3B%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96MISO%E3%81%A8%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCCLK-%26gt%3B%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96CLK%E3%81%AA%E3%81%A9%E3%81%AE3%E7%B7%9A%E5%BC%8F%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%9B%B8%E4%BA%92%E6%8E%A1%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCSPI%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96SPI%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3Ei.MX27%20%E3%81%AE%20SPI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81Linux%20%E3%81%AE%20CONREG%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%20MODE%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%20SLAVE%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E6%AF%8E%E5%9B%9E%E5%90%8C%E3%81%98%208bit%20%E3%82%92%E7%B4%84%208*1000*1000%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81MOSI%20%E3%83%94%E3%83%B3%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BB%A2%E9%80%81%E3%81%A7%E3%81%8D%E3%80%81CLK%20%E3%83%94%E3%83%B3%E3%81%8C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81SLAVE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%9B%E3%81%9A%E3%80%81i.mx27%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AB%E5%8F%8D%E5%BF%9C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81spi_put_tx_data%E6%A9%9F%E8%83%BD%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%A8%E3%81%A9%E3%81%BE%E3%82%8A%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%97%E4%BF%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3ESPI%E3%81%AF%E3%80%81%E4%B8%80%E5%BA%A6%E3%81%A0%E3%81%91%E5%8F%97%E4%BF%A1%E3%81%97%E3%80%81%E5%BE%8C%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BB%A2%E9%80%81%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Ecmd-%26gt%3Bport%20%E3%81%AF%201%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3ESPI%E3%81%AF1%E3%81%A7%E3%80%81fd%E3%81%AF4%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Espi_bitbang%20%3Abitbang_work%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_chipselect%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3E%E5%8E%9F%E7%82%B9mxc_spi_chipselect%E5%88%B6%E5%BE%A1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%201024%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3E%E3%83%9E%E3%82%B9%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%B3mxc_spi_chipselect%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF1024%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Aspi_find_baudrate%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%9C%E6%A5%AD%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AESPI%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AFSPI_MODE_0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi_chipselect%E5%88%B6%E5%BE%A1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%2066567%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_transfer%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Aspi_enable_interrupt%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Aspi_get_rx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22text-indent%3A%2021.0000pt%3B%20background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%20style%3D%22background%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3Emxc_spi%3Amxc_spi_isr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22p0%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%20background%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20mxc_spi%20%3Aspi_put_tx_data%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E3%81%AA%E3%81%9C%E5%A5%B4%E9%9A%B7%E3%81%8C%E4%BD%95%E3%82%82%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E1.%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%9F%E3%82%8A%E3%80%81%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%82%8A%E3%81%97%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%82%93%E3%81%AA%E4%BD%93%E3%81%A7%E3%82%82%E7%A7%81%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E2.i.MX27%20SPI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9B%B4%E6%96%B0%E6%96%B9%E6%B3%95C%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%BE%8C%E3%81%A7%E3%81%8A%E6%B8%A1%E3%81%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E3.%20SPI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82SPI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%81%A9%E3%81%93%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E4.%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%B8%AD%E5%9B%BD%E4%BA%BA%E3%81%AA%E3%82%89%E3%80%81%E4%B8%AD%E5%9B%BD%E8%AA%9E%E3%81%A7%E3%81%8A%E4%BA%92%E3%81%84%E3%81%AB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E6%84%9F%E8%AC%9D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0000pt%3B%20font-family%3A%20'%E5%AE%8B%E4%BD%93'%3B%22%3E%E3%83%AF%E3%83%B3%E3%82%B8%E3%82%A2%E3%83%B3%20%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-12-2013 12:16 AM
更新者:
