Description | Module implementing mini threads using timer based callbacks (triggers) |
Component | Trigger.PEupd |
Dependencies | LowPower |
License : Open Source (LGPL)
Copyright : (c) Copyright Erich Styger, 2011, all rights reserved.
This an open source software implementing triggers using Processor Expert.
This is a free software and is opened for education, research and commercial developments under license policy of following terms:
* This is a free software and there is NO WARRANTY.
* No restriction on use. You can use, modify and redistribute it for personal, non-profit or commercial product UNDER YOUR RESPONSIBILITY.
* Redistributions of source code must retain the above copyright notice.
