The “Hello World” of TensorFlow Lite
Goal
Our goal is to train a model that can take a value, x, and predict its sine, y. In a real-world application, if you needed the sine of x, you could just calculate it directly. However, by training a model to approximate the result, we can demonstrate the basics of machine learning.
TensorFlow and Keras
TensorFlow is a set of tools for building, training, evaluating, and deploying machine learning models. Originally developed at Google, TensorFlow is now an open-source project built and maintained by thousands of contributors across the world. It is the most popular and widely used framework for machine learning. Most developers interact with TensorFlow via its Python library. TensorFlow does many different things. In this post, we’ll use Keras, TensorFlow’s high-level API that makes it easy to build and train deep learning networks.
To enable TensorFlow on mobile and embedded devices, Google developed the TensorFlow Lite framework. It gives these computationally restricted devices the ability to run inference on pre-trained TensorFlow models that were converted to TensorFlow Lite. These converted models cannot be trained any further but can be optimized through techniques like quantization and pruning.
Building the Model
To building the Model, we should follow the below steps.
  1. Obtain a simple dataset.
  2. Train a deep learning model.
  3. Evaluate the model’s performance.
  4. Convert the model to run on-device.
Please navigate to the URL in your browser to open the notebook directly in Colab, this notebook is designed to demonstrate the process of creating a TensorFlow model and converting it to use with TensorFlow Lite.
Deploy the mode to the RT MCU
  • Hardware Board: MIMXRT1050 EVK Board
Fig 1 MIMXRT1050 EVK Board
  • Template demo code: evkbimxrt1050_tensorflow_lite_cifar10
Code
/* Copyright 2017 The TensorFlow Authors. All Rights Reserved.
 Copyright 2018 NXP. All Rights Reserved.
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
 http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
#include "board.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "fsl_debug_console.h"
#include <iostream>
#include <string>
#include <vector>
#include "timer.h"
#include "tensorflow/lite/kernels/register.h"
#include "tensorflow/lite/model.h"
#include "tensorflow/lite/optional_debug_tools.h"
#include "tensorflow/lite/string_util.h"
#include "Sine_mode.h"
int inference_count = 0;
// This is a small number so that it's easy to read the logs
const int kInferencesPerCycle = 30;
const float kXrange = 2.f * 3.14159265359f;
#define LOG(x) std::cout
void RunInference()
 std::unique_ptr<tflite::FlatBufferModel> model;
 std::unique_ptr<tflite::Interpreter> interpreter;
 model = tflite::FlatBufferModel::BuildFromBuffer(sine_model_quantized_tflite, sine_model_quantized_tflite_len);
 if (!model) {
 LOG(FATAL) << "Failed to load model\r\n";
 exit(-1);
 model->error_reporter();
 tflite::ops::builtin::BuiltinOpResolver resolver;
 tflite::InterpreterBuilder(*model, resolver)(&interpreter);
 if (!interpreter) {
 LOG(FATAL) << "Failed to construct interpreter\r\n";
 exit(-1);
 float input = interpreter->inputs()[0];
 if (interpreter->AllocateTensors() != kTfLiteOk) {
 LOG(FATAL) << "Failed to allocate tensors!\r\n";
 while(true)
 // Calculate an x value to feed into the model. We compare the current
 // inference_count to the number of inferences per cycle to determine
 // our position within the range of possible x values the model was
 // trained on, and use this to calculate a value.
 float position = static_cast<float>(inference_count) /
 static_cast<float>(kInferencesPerCycle);
 float x_val = position * kXrange;
 float* input_tensor_data = interpreter->typed_tensor<float>(input);
 *input_tensor_data = x_val;
 Delay_time(1000);
 // Run inference, and report any error
 TfLiteStatus invoke_status = interpreter->Invoke();
 if (invoke_status != kTfLiteOk)
 LOG(FATAL) << "Failed to invoke tflite!\r\n";
 return;
 // Read the predicted y value from the model's output tensor
 float* y_val = interpreter->typed_output_tensor<float>(0);
 PRINTF("\r\n x_value: %f, y_value: %f \r\n", x_val, y_val[0]);
 // Increment the inference_counter, and reset it if we have reached
 // the total number per cycle
 inference_count += 1;
 if (inference_count >= kInferencesPerCycle) inference_count = 0;
 * @brief Application entry point.
int main(void)
 /* Init board hardware */
 BOARD_ConfigMPU();
 BOARD_InitPins();
 BOARD_InitDEBUG_UARTPins();
 BOARD_BootClockRUN();
 BOARD_InitDebugConsole();
 NVIC_SetPriorityGrouping(3);
 InitTimer();
 std::cout << "The hello_world demo of TensorFlow Lite model\r\n";
 RunInference();
 std::flush(std::cout);
 for (;;) {}
Test result
On the MIMXRT1050 EVK Board, we log the input data: x_value and the inferenced output data: y_value via the Serial Port.
Fig2 Received data
In a while loop function, It will run inference for a progression of x values in the range 0 to 2π and then repeat. Each time it runs, a new x value is calculated, the inference is run, and the data is output.
Fig3 Test result
In further, we use Excel to display the received data against our actual values as the below figure shows.
Fig4 Dot Plot
You can see that, for the most part, the dots representing predicted values form a smooth sine curve along the center of the distribution of actual values. In general, Our network has learned to approximate a sine curve.
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1114580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETensorFlow%20Lite%20%E3%81%AE%E3%80%8CHello%20World%E3%80%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3E%E3%82%B4%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E5%80%A4%20x%20%E3%82%92%E5%8F%96%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E6%AD%A3%E5%BC%A6%20y%20%E3%82%92%E4%BA%88%E6%B8%AC%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81x%20%E3%81%AE%E6%AD%A3%E5%BC%A6%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%9B%B4%E6%8E%A5%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E8%BF%91%E4%BC%BC%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%AD%A6%E7%BF%92%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%81%AE%E5%9F%BA%E6%9C%AC%E3%82%92%E7%A4%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3ETensorFlow%20%E3%81%A8%20Keras%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230088cc%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETensorFlow%3C%2FA%3E%3C%2FSPAN%3E%20%E3%81%AF%E3%80%81%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E6%A7%8B%E7%AF%89%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%80%81%E8%A9%95%E4%BE%A1%E3%80%81%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%A8%E3%82%82%E3%81%A8%20Google%20%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%20TensorFlow%20%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81%E4%B8%96%E7%95%8C%E4%B8%AD%E3%81%AE%E4%BD%95%E5%8D%83%E4%BA%BA%E3%82%82%E3%81%AE%E8%B2%A2%E7%8C%AE%E8%80%85%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%8A%E3%82%88%E3%81%B3%E4%BF%9D%E5%AE%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%81%A7%E6%9C%80%E3%82%82%E4%BA%BA%E6%B0%97%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%BA%83%E3%81%8F%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A7%E3%81%99%E3%80%82%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AF%E3%80%81Python%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20TensorFlow%20%E3%81%A8%E5%AF%BE%E8%A9%B1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82TensorFlow%20%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%A9%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%A8%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%B9%E6%98%93%E3%81%AB%E3%81%99%E3%82%8BTensorFlow%E3%81%AE%E9%AB%98%E3%83%AC%E3%83%99%E3%83%ABAPI%E3%81%A7%E3%81%82%E3%82%8B%20%3CSPAN%20style%3D%22color%3A%20%230088cc%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Fguide%2Fkeras%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKeras%3C%2FA%3E%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%22%3E%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%84%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%20TensorFlow%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81Google%20%E3%81%AF%20%3CA%20href%3D%22https%3A%2F%2Fwww.tensorflow.org%2Flite%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETensorFlow%20Lite%3C%2FA%3E%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%88%E7%AE%97%E5%88%B6%E9%99%90%E3%81%AE%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81TensorFlow%20Lite%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%E4%BA%8B%E5%89%8D%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E6%B8%88%E3%81%BF%E3%81%AE%20TensorFlow%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E6%8E%A8%E8%AB%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E9%87%8F%E5%AD%90%E5%8C%96%E3%82%84%E3%83%97%E3%83%AB%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%A9%E3%81%AE%E6%89%8B%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3COL%20style%3D%22margin%3A%200px%3B%22%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20decimal%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E5%8D%98%E7%B4%94%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20decimal%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%83%A9%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20decimal%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20decimal%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230088cc%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcolab.research.google.com%2Fgithub%2Ftensorflow%2Ftensorflow%2Fblob%2Fmaster%2Ftensorflow%2Flite%2Fmicro%2Fexamples%2Fhello_world%2Fcreate_sine_model.ipynb%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FSPAN%3E%E3%81%93%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%88%E3%83%96%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81%20TensorFlow%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92TensorFlow%20Lite%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E7%A4%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3ERT%20MCU%20%E3%81%B8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%3E%3CUL%20style%3D%22margin%3A%200px%3B%22%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20disc%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%3A%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EMIMXRT1050%20EVK%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22WeChat%20Image_20200203172635.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22WeChat%20Image_20200203172635.jpg%22%20style%3D%22width%3A%20730px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F100588i15EE8F2A41EF4473%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22WeChat%20Image_20200203172635.jpg%22%20alt%3D%22WeChat%20Image_20200203172635.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWeChat%20Image_20200203172635.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B31%20MIMXRT1050%20EVK%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%3E%3CUL%20style%3D%22margin%3A%200px%3B%22%3E%3CLI%20style%3D%22text-align%3A%20left%3B%20line-height%3A%201.75%3B%20font-size%3A%2014px%3B%20list-style-position%3A%20inside%3B%20white-space%3A%20pre-wrap%3B%20word-break%3A%20break-word%3B%20list-style-type%3A%20disc%3B%20font-family%3A%20'Microsoft%20YaHei'%2C%20STXihei%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20normal%3B%20font-style%3A%20normal%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%20%E3%83%87%E3%83%A2%20%E3%82%B3%E3%83%BC%E3%83%89%3A%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eevkbimxrt1050_tensorflow_lite_cifar10%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CPRE%20class%3D%22language-cpp%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Copyright%202017%20The%20TensorFlow%20Authors.%20All%20Rights%20Reserved.%0A%20Copyright%202018%20NXP.%20All%20Rights%20Reserved.%0A%0ALicensed%20under%20the%20Apache%20License%2C%20Version%202.0%20(the%20%22License%22)%3B%0Ayou%20may%20not%20use%20this%20file%20except%20in%20compliance%20with%20the%20License.%0AYou%20may%20obtain%20a%20copy%20of%20the%20License%20at%0A%0A%20%3CA%20href%3D%22http%3A%2F%2Fwww.apache.org%2Flicenses%2FLICENSE-2.0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.apache.org%2Flicenses%2FLICENSE-2.0%3C%2FA%3E%0A%0AUnless%20required%20by%20applicable%20law%20or%20agreed%20to%20in%20writing%2C%20software%0Adistributed%20under%20the%20License%20is%20distributed%20on%20an%20%22AS%20IS%22%20BASIS%2C%0AWITHOUT%20WARRANTIES%20OR%20CONDITIONS%20OF%20ANY%20KIND%2C%20either%20express%20or%20implied.%0ASee%20the%20License%20for%20the%20specific%20language%20governing%20permissions%20and%0Alimitations%20under%20the%20License.%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22board.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22pin_mux.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22clock_config.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22fsl_debug_console.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%3CIOSTREAM%3E%3C%2FIOSTREAM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%3CSTRING%3E%3C%2FSTRING%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%3CVECTOR%3E%3C%2FVECTOR%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22timer.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22tensorflow%2Flite%2Fkernels%2Fregister.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22tensorflow%2Flite%2Fmodel.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22tensorflow%2Flite%2Foptional_debug_tools.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22tensorflow%2Flite%2Fstring_util.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23include%20%3CSPAN%20class%3D%22string%20token%22%3E%22Sine_mode.h%22%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%0A%0A%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20inference_count%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20This%20is%20a%20small%20number%20so%20that%20it's%20easy%20to%20read%20the%20logs%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20kInferencesPerCycle%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E30%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%20kXrange%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3.14159265359f%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23define%20LOG(x)%20std%3A%3Acout%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22keyword%20token%22%3Evoid%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3ERunInference%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Eunique_ptr%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3Etflite%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3EFlatBufferModel%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20model%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Eunique_ptr%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3Etflite%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3EInterpreter%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20interpreter%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20model%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20tflite%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3EFlatBufferModel%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EBuildFromBuffer%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Esine_model_quantized_tflite%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20sine_model_quantized_tflite_len%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3Emodel%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3ELOG%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EFATAL%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Failed%20to%20load%20model%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3Eexit%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20model%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3Eerror_reporter%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20tflite%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Eops%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Ebuiltin%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3EBuiltinOpResolver%20resolver%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20tflite%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EInterpreterBuilder%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3Emodel%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20resolver%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3Einterpreter%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3Einterpreter%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3ELOG%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EFATAL%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Failed%20to%20construct%20interpreter%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3Eexit%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%20input%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20interpreter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3Einputs%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Einterpreter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EAllocateTensors%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E!%3D%3C%2FSPAN%3E%20kTfLiteOk%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3ELOG%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EFATAL%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Failed%20to%20allocate%20tensors!%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%0A%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20boolean%22%3Etrue%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20Calculate%20an%20x%20value%20to%20feed%20into%20the%20model.%20We%20compare%20the%20current%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20inference_count%20to%20the%20number%20of%20inferences%20per%20cycle%20to%20determine%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20our%20position%20within%20the%20range%20of%20possible%20x%20values%20the%20model%20was%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20trained%20on%2C%20and%20use%20this%20to%20calculate%20a%20value.%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%20position%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Estatic_cast%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Einference_count%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Estatic_cast%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EkInferencesPerCycle%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%20x_val%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20position%20%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3E%20kXrange%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3E%20input_tensor_data%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20interpreter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3Etyped_tensor%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Einput%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3Einput_tensor_data%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20x_val%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22token%20function%22%3EDelay_time%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20Run%20inference%2C%20and%20report%20any%20error%3C%2FSPAN%3E%0A%20TfLiteStatus%20invoke_status%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20interpreter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EInvoke%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Einvoke_status%20%3CSPAN%20class%3D%22operator%20token%22%3E!%3D%3C%2FSPAN%3E%20kTfLiteOk%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3ELOG%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EFATAL%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Failed%20to%20invoke%20tflite!%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20Read%20the%20predicted%20y%20value%20from%20the%20model's%20output%20tensor%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3E%20y_val%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20interpreter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3Etyped_output_tensor%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efloat%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22token%20function%22%3EPRINTF%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5Cn%20x_value%3A%20%25f%2C%20y_value%3A%20%25f%20%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20x_val%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20y_val%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20Increment%20the%20inference_counter%2C%20and%20reset%20it%20if%20we%20have%20reached%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20the%20total%20number%20per%20cycle%3C%2FSPAN%3E%0A%20inference_count%20%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Einference_count%20%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3D%3C%2FSPAN%3E%20kInferencesPerCycle%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20inference_count%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%0A%0A%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%0A%20*%20%40brief%20Application%20entry%20point.%0A%20*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3Emain%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Evoid%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Init%20board%20hardware%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EBOARD_ConfigMPU%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EBOARD_InitPins%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EBOARD_InitDEBUG_UARTPins%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EBOARD_BootClockRUN%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EBOARD_InitDebugConsole%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22token%20function%22%3ENVIC_SetPriorityGrouping%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22token%20function%22%3EInitTimer%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Ecout%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22The%20hello_world%20demo%20of%20TensorFlow%20Lite%20model%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22token%20function%22%3ERunInference%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3Eflush%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Estd%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Ecout%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2034px%3B%22%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3EMIMXRT1050%20EVK%20Board%E3%81%A7%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF(%20%3CSTRONG%3Ex_value%3C%2FSTRONG%3E%20)%E3%81%A8%E6%8E%A8%E8%AB%96%E3%81%95%E3%82%8C%E3%81%9F%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF(%20%3CSTRONG%3Ey_value%3C%2FSTRONG%3E%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E7%B5%8C%E7%94%B1)%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_18-11-27.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_18-11-27.jpg%22%20style%3D%22width%3A%20280px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F100620iC38DC75A42821DB7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222020-02-03_18-11-27.jpg%22%20alt%3D%222020-02-03_18-11-27.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2020-02-03_18-11-27.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%20text-align%3A%20center%3B%22%3E%E5%9B%B32%20%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3Ewhile%20%E3%83%AB%E3%83%BC%E3%83%97%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%AF%E3%80%810%20%E3%81%8B%E3%82%89%202%CF%80%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AE%20x%20%E5%80%A4%E3%81%AE%E9%80%B2%E8%A1%8C%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%8E%A8%E8%AB%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20x%20%E5%80%A4%E3%81%8C%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%80%81%E6%8E%A8%E8%AB%96%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_17-34-01.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_17-34-01.jpg%22%20style%3D%22width%3A%20648px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F100663i3D76757F41F047EB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222020-02-03_17-34-01.jpg%22%20alt%3D%222020-02-03_17-34-01.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2020-02-03_17-34-01.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%20text-align%3A%20center%3B%22%3E%E5%9B%B33%20%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Excel%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%80%A4%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_18-09-33.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222020-02-03_18-09-33.jpg%22%20style%3D%22width%3A%20794px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F100706i4708BB6970C37C0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222020-02-03_18-09-33.jpg%22%20alt%3D%222020-02-03_18-09-33.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2020-02-03_18-09-33.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20font-size%3A%2014px%3B%20text-align%3A%20center%3B%22%3E%E5%9B%B34%20%E3%83%89%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%3CDIV%20style%3D%22white-space%3A%20pre-wrap%3B%20line-height%3A%201.6%3B%20text-align%3A%20left%3B%20font-size%3A%2014px%3B%22%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BA%88%E6%B8%AC%E5%80%A4%E3%82%92%E8%A1%A8%E3%81%99%E3%83%89%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%80%A4%E3%81%AE%E5%88%86%E5%B8%83%E3%81%AE%E4%B8%AD%E5%BF%83%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%A6%E6%BB%91%E3%82%89%E3%81%8B%E3%81%AA%E6%AD%A3%E5%BC%A6%E6%9B%B2%E7%B7%9A%E3%82%92%E5%BD%A2%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%88%AC%E3%81%AB%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AF%E6%AD%A3%E5%BC%A6%E6%9B%B2%E7%B7%9A%E3%82%92%E8%BF%91%E4%BC%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%AD%A6%E7%BF%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20105%E5%80%8D%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:25 AM
更新者:
