i.MX RT Knowledge Base
Search instead for
Discussions
Sort by:
1 Introduction   NXP-MCUBootUtility is a GUI tool specially designed for NXP MCU secure boot. Its features correspond to the BootROM function in NXP MCU. Currently, it mainly supports i.MXRT series MCU chips, Compared to NXP official security enablement toolset (OpenSSL, CST, sdphost, blhost, elftosb, BD, MfgTool2), NXP-MCUBootUtility is a real one-stop tool, a tool that includes all the features of NXP's official security enablement toolset, and what's more, it supports full graphical user interface operation. With NXP-MCUBootUtility, you can easily get started with NXP MCU secure boot.   The main features of NXP-MCUBootUtility include: Support i.MXRT1021, i.MXRT1051/1052, i.MXRT1061/1062, i.MXRT1064 SIP Support both UART and USB-HID serial downloader modes Support various user application image file formats (elf/axf/srec/hex/bin) Can validate the range and applicability of user application image Support for converting bare image into bootable image Support for loading bootable image into FlexSPI NOR and SEMC NAND boot devices Support for loading bootable image into LPSPI NOR/EEPROM recovery boot device Support DCD which can help load image to SDRAM Support HAB encryption (Signed only, Signed and Encrypted) Can back up certificate with time stamp Support BEE encryption (SNVS Key, User Keys) Support common eFuse memory operation (eFuse Programmer) Support common boot device memory operation (Flash Programmer) Support for reading back and marking bootable image(NFCB/DBBT/FDCB/EKIB/EPRDB/IVT/Boot Data/DCD/Image/CSF/DEK KeyBlob) from boot device   2 Download   NXP-MCUBootUtility is developed in Python, and it is open source. The development environment is Python 2.7.15 (32bit), wxPython 4.0.3, pySerial 3.4, pywinusb 0.4.2, bincopy 15.0.0, PyInstaller 3.3.1 (or higher). Source code: https://github.com/nxp-mcuxpresso/mcu-boot-utility Feedback: https://www.cnblogs.com/henjay724/p/10159925.html   NXP-MCUBootUtility is packaged by PyInstaller, all Python dependencies have been packaged into an executable file (\NXP-MCUBootUtility\bin\NXP-MCUBootUtility.exe), so if you do not want to develop NXP-MCUBootUtility for new feature, there is no need to install any Python software or related libraries. Note1: Before using NXP-MCUBootUtility, you need to download HAB Code Signing Tool from NXP website,upzip it and put it in the \NXP-MCUBootUtility\tools\cst\ directory, then modify the code to enable AES function and rebuild \NXP-MCUBootUtility\tools\cst\mingw32\bin\cst.exe, or HAB related encryption function can not be used properly。See more details in 《The step-by-step guide to rebuild cst.exe for HAB encryption》 Note2: Before using NXP-MCUBootUtility, you need to rebuild the source in \NXP-MCUBootUtility\tools\image_enc\code directory to generate image_enc.exe and put it in \NXP-MCUBootUtility\tools\image_enc\win directory, or BEE related encryption function can not be used properly。See more details in 《The step-by-step guide to build image_enc.exe for BEE encryption》   3 Installation   NXP-MCUBootUtility is a pure green free installation tool. After downloading the source code package, double-click "\NXP-MCUBootUtility\bin\NXP-MCUBootUtility.exe" to use it. No additional software is required.   Before the NXP-MCUBootUtility.exe graphical interface is displayed, a console window will pop up first. The console will work along with the NXP-MCUBootUtility.exe graphical interface. The console is mainly for the purpose of showing error information of NXP-MCUBootUtility.exe. At present, NXP-MCUBootUtility is still in development stage, and the console will be removed when the NXP-MCUBootUtility is fully validated.   4 Interface   The following figure shows the main interface of the NXP-MCUBootUtility tool. The interface consists of six parts.
View full article
This article will help you understand in detail the necessary steps to connect an external SRAM memory to the RT devices with the SEMC module. This document is focused on RT1170 however a lot of this information can also be followed for other RT devices with the SEMC module, please consult limitations on the specific device Reference Manual. In this post, there is attached an example of this, since the EVK does not contain an SRAM a specific memory is not used for this. This is a theoretical approach to how to set this kind of memory. The user needs to set specific parameters for the memory to be used.   The SEMC is a multi-standard memory controller optimized for both high performance and low pin count. It can support multiple external memories in the same application with shared address and data pins. The interface supported includes SDRAM, NOR Flash, SRAM, and NAND Flash, as well as the 8080 display interface. Features The SEMC includes the following features: SRAM interface Supports SRAM and Pseudo SRAM Supports 8/16 bit modes Supports ADMUX, AADM, and Non-ADMUX modes Up to 4 Chip Select (CS) Up to 4096Mb memory size NOTE For 16-bit devices, up to 4096Mb memory size For 8-bit devices, up to 2048Mb memory size For more detailed features on supported memories of this module please consult Reference Manual How to set SRAM It is important to mention that RT1170 supports ASYNC and SYNC mode on the SRAM however SYNC mode is not supported in all RT devices, e.g. RT1050 does not support SRAM SYNC mode. It is important to consider the pin mux for these devices, for this you can refer to table 29-7 for the RT1170. Please consider that pins controlled through the IOCR register should be static. This means that if you configure, for example, SEMC_ADDR08 to be CE on the SRAM it cannot be used in the same application as A8 in an SDRAM. Let´s go step by step on how to configure the parameters and where to find that information:   Configure MCR[DQSMD] bit to select the read clock source for synchronous mode. Suggest setting it with 0x1 to reach high clock frequency. config.dqsMode = kSEMC_Loopbackdqspad; Configure the IOCR register to choose CS pins. For this, you can refer to table 29-6. I suggest using CSX pins for CS signals of the SRAM. The Init function from the SDK sets this register incorrectly so write this register outside the function SEMC->IOCR |= 0x00908BB6; // A8:CE#0, CSX0:A24, CSX1:A25, CSX2:CE#1, RDY:CE#2 Optional Configure BMCR registers for bus access efficiency, the arbitration adopts a weight-based algorithm where the weights are obtained from BMCR registers. A score is calculated and the command with the highest score is served first. The score is calculated with the following formula: SCORE = QOS*WQOS + AGE*WAGE/4 + WSH + WRWS Where : - QOS stands for AxQOS of AXI bus-WQOS is the weight factor of QOS. -AGE stands for the wait period for each command -WAGE is the weight factor of AGE. -WSH stands for the weight of slave hit without read/write switch scenario. -WRWS stands for the weight of the slave hit with read/write switch scenario. This is used when you have multiple devices connected to the module and you want to assign access priorities to the different devices.   Configure Base Register 6/9/10/11 with base address, memory size, and valid information. BRx[BA]: In this field, you set the address where the SRAM is going to be located. You can refer to the specific device memory map. In the example, I used 0x9000_0000 but you can use any SEMC location as long it does not overlap with other memory spaces. BRx[MS]: Here you specify the size of the SRAM. [Image from register] BRx[VLD] must be 1 so the memory can be accessed. //VLD is always set to 1 in the SRAM Init function of the SDK sram_config.address = SRAM_BASE;// Base address 0x90000000 (BR6[BA]) sram_config.memsize_kbytes = 0x10000;// SRAM0 space size 64MB (BR6[MS])   Configure INTEN and INTR registers if need to generate interrupts. You can use the function "SEMC_EnableInterrupts()" Configure SRAM Control Register with parameters obtained from the specific SRAM device. These registers contain the timings for the memory used. These values are obtained from the memory datasheet. sram_config.addrPortWidth = 8;// Port width (SRAMCR0[COL])Don't care in SRAM. sram_config.advActivePolarity = kSEMC_AdvActiveLow;//ADV# polarity //(SRAMCR0[ADVP])Don't care if not use ADV. sram_config.addrMode = kSEMC_AddrDataNonMux;//Non Mux mode(SRAMCR0[AM]) sram_config.burstLen = kSEMC_Nor_BurstLen1;//Burst length (SRAMCR0[BL]) sram_config.portSize = kSEMC_PortSize16Bit;//Port size 16bit (SRAMCR0[PS]) sram_config.syncMode = kSEMC_AsyncMode;// ASYNC mode (SRAMCR0[SYNCEN]) sram_config.waitEnable = true;// WAIT enable (SRAMCR0[WAITEN]) sram_config.waitSample = 0;// WAIT sample (SRAMCR0[WAITSP]) sram_config.advLevelCtrl = kSEMC_AdvHigh;// ADV# level control(SRAMCR0[ADVH]) //Don't care if not use ADV. sram_config.tCeSetup_Ns = 20;//CE#setup time[nsec](SRAMCR1[CES])Need tuning. sram_config.tCeHold_Ns = 20;// CE#hold time [nsec](SRAMCR1[CEH]) Need tuning. sram_config.tCeInterval_Ns = 20;//CE#interval time[nsec](SRAMCR2[CEITV]) Need //tuning. sram_config.readHoldTime_Ns = 20;//Read hold time[nsec](SRAMCR2[RDH])Only for //SYNC mode. sram_config.tAddrSetup_N s= 20;//ADDRsetup time[nsec](SRAMCR1[AS])Need tuning. sram_config.tAddrHold_Ns = 20;//ADDRhold time[nsec](SRAMCR1[AH]) Need tuning. sram_config.tWeLow_Ns = 20;//WE low time [nsec] (SRAMCR1[WEL]) Need tuning. sram_config.tWeHigh_Ns = 20;//WE high time [nsec] (SRAMCR1[WEH]) Need tuning. sram_config.tReLow_Ns = 20;// RE low time [nsec] (SRAMCR1[REL]) Need tuning. sram_config.tReHigh_Ns = 20;// RE high time[nsec](SRAMCR1[REH]) Need tuning. sram_config.tTurnAround_Ns = 20;//Turnaround time[nsec](SRAMCR2[TA])Need //tuning but don't set it to be 0. sram_config.tAddr2WriteHold_Ns = 20;//Address to write data hold time [nsec] (SRAMCR2[AWDH]) Need tuning. sram_config.tWriteSetup_Ns = 20;//Write Data setup time[nsec](SRAMCR2[WDS]) //Only for SYNC mode. sram_config.tWriteHold_Ns= 20;//Write Data hold time [nsec] (SRAMCR2[WDH]) //Only for SYNC mode. sram_config.latencyCount = 20;//Latency count[nsec](SRAMCR2[LC]) Only for //SYNC mode. sram_config.readCycle = 20;// read time[nsec](SRAMCR2[RD])Only for SYNC mode. sram_config.delayChain = 20;// typically not used in SRAM. (DCCR [SRAMXVAL], //DCCR [SRAMXEN], DCCR [SRAM0VAL], DCCR [SRAM0EN]) ​ These values are for reference and do not suggest the exact values for a specific SRAM. Initialize the SRAM device by IP command registers (IPCR0/1/2, IPCMD, and IPTXDAT) if needed.  Notes: -Configure independent timing for SRAM device 0 and device 1/2/3 -Configure SRAM device 0 timing with register SRAMCR0~SRAMCR3 -Configure SRAM decive1/2/3 timing with register SRAMCR4~SRAMCR6
View full article
There are two new LCD panels that are now available for i.MX RT EVKs: The original RK043FN02H-CT is being replaced with RK043FN66HS-CTG used by the following EVKs: i.MX RT1050 i.MX RT1060 i.MX RT1064   The original RK055HDMIPI4M is being replaced with RK055HDMIPI4MA0 used by the following EVKs: i.MX RT595 i.MX RT1160 i.MX RT1170   These changes are due to the previous panels being EOL by the LCD panel manufacturer. These new LCDs have the same dimensions and screen size as their original versions (4.3” 480x272 and 5.5” 720x1280 respectively) and the physical connections are the same. The version name can be found on the back of the LCD. However there are modifications to the software that may need to be made. This updated code is already available in the latest MCUXpresso SDK and demos are configured by default to use the new panels.   For the i.MX RT1050/1060/1064 panel RK043FN66HS-CTG: The touch controller has changed and the SDK software has been modified to support the new touch controller. The LCD panel also has slightly different specs but the same code used for the original LCD panel will also work with the new LCD panel, so no change is necessary for display-only demos.  LCD demos are configured to support the new panel by default in the latest MCUXpresso SDK. So if you have the original panel you will need to change in the SDK code:      #define DEMO_PANEL           from DEMO_PANEL_RK043FN66HS    //new panel (default setting)           to DEMO_PANEL_RK043FN02H          //original panel   For the i.MX RT595/RT1160/RT1170 panel RK055HDMIPI4MA0: Both the touch and display SDK software had to be updated to support this new panel. LCD demos are configured to support the new panel by default in the latest MCUXpresso SDK. So if you have the original panel you will need to change in the SDK code:     #define DEMO_PANEL           from DEMO_PANEL_RK055MHD091    //new panel (default setting)           to DEMO_PANEL_RK055AHD091         //original panel
View full article
A vulnerability (CVE-2022-22819) has been identified on select NXP processors by which a malformed SB2 file header sent to the device as part of an update or recovery boot can be used to create a buffer overflow. The buffer overflow can then be used to launch various exploits. Refer to the attached bulletin for more information.   09/26/2022 - Bulletin updated to include fix datecode information. 11/01/2022 - Bulletin updated with clarification that mixed datecodes are RT600 only.
View full article
Wireless module combinations from Tables 2 and 3 are not updated with the latest SDK 2.12.1 in the user manual UM11441. Major updates in Table 2 and Table 3: u-blox modules are supported only on rt1060 Murata modules are only tested with i.MX RT1060 EVKB and i.MX RT1040 EVK platforms Modified Murata modules names Renamed i.MX RT685S EVK to IMXRT685-AUD-EVK Please refer to the attached PDF for updated information.
View full article
Note: for similar EVKs, see Using J-Link with MIMXRT1060-EVK or MIMXRT1064-EVK, or Using J-Link with MIMXRT1160-EVK or MIMXRT1170-EVK. This article provides details using a J-Link debug probe with this EVK.  There are two options: the onboard debug circuit can be updated with Segger J-Link firmware, or an external J-Link debug probe can be attached to the EVK.  Using the onboard debug circuit is helpful as no other debug probe is required.  However, the onboard debug circuit will no longer power the EVK when updated with the J-Link firmware.  Appnote AN13206 has more details on this, and the comparison of the firmware options for the debug circuit.  This article details the steps to use either J-Link option.     Using external J-Link debug probe Segger offers several J-Link probe options.  To use one of these probes with these EVKs, configure the EVK with these settings: Remove jumpers J9 and J10, to disconnect the SWD signals from onboard debug circuit.  These jumpers or installed by default. Use default power selection on J40 with pins 5-6 shorted. Connect the J-Link probe to J2, 20-pin dual-row 0.1" header. Power the EVK with one of the power supply options.  Typically USB connector J1 is used to power the board, and provides a UART/USB bridge through the onboard debug circuit.   Using onboard debug circuit with J-Link firmware Follow Appnote AN13206 to program the J-Link firmware to the EVK. Use jumper J12 to change the mode of the onboard debug circuit: Install J12 to force bootloader mode, to update the firmware image Remove J12 to use the onboard debugger Install jumpers J9 and J10, to connect the SWD signals from onboard debug circuit.  These jumpers or installed by default. Plug USB cable to J1.  This provides connection for J-Link debugger and UART/USB bridge.  However, with J-Link firmware, J1 no longer powers the EVK Power the EVK with another source.  Here we will use another USB port.  Move the jumper on J40 to short pins 3-4 (default shorts pins 5-6) Connect a 2nd USB cable to J48 to power the EVK.  The green LED next to J40 will be lit when the EVK is properly powered.
View full article
Note: for similar EVKs, see Using J-Link with MIMXRT1060-EVKB, or Using J-Link with MIMXRT1160-EVK or MIMXRT1170-EVK. This article provides details using a J-Link debug probe with either of these EVKs.  There are two options: the onboard debug circuit can be updated with Segger J-Link firmware, or an external J-Link debug probe can be attached to the EVK.  Using the onboard debug circuit is helpful as no other debug probe is required.  However, the onboard debug circuit will no longer power the EVK when updated with the J-Link firmware.  Appnote AN13206 has more details on this, and the comparison of the firmware options for the debug circuit.  This article details the steps to use either J-Link option.   Using external J-Link debug probe Segger offers several J-Link probe options.  To use one of these probes with these EVKs, configure the EVK with these settings: Remove jumpers J47 and J48, to disconnect the SWD signals from onboard debug circuit.  These jumpers or installed by default. Use default power selection on J1 with pins 5-6 shorted. Connect the J-Link probe to J21, 20-pin dual-row 0.1" header. Power the EVK with one of the power supply options.  Typically USB connector J41 is used to power the board, and provides a UART/USB bridge through the onboard debug circuit.   Using onboard debug circuit with J-Link firmware Follow Appnote AN13206 to program the J-Link firmware to the EVK Install jumpers J47 and J48, to connect the SWD signals from onboard debug circuit.  These jumpers or installed by default. Plug USB cable to J41.  This provides connection for J-Link debugger and UART/USB bridge.  However, with J-Link firmware, J41 no longer powers the EVK Power the EVK with another source.  Here we will use another USB port.  Move the jumper on J1 to short pins 3-4 (default shorts pins 5-6) Connect a 2nd USB cable to J9 to power the EVK.  The green LED next to J1 will be lit when the EVK is properly powered.
View full article
Note: for similar EVKs, see Using J-Link with MIMXRT1060-EVKB, or Using J-Link with MIMXRT1060-EVK or MIMXRT1064-EVK. This article provides details using a J-Link debug probe with either of these EVKs.  There are two options: the onboard debug circuit can be updated with Segger J-Link firmware, or an external J-Link debug probe can be attached to the EVK.  Using the onboard debug circuit is helpful as no other debug probe is required.  Appnote AN13206 has more details on this, and the comparison of the firmware options for the debug circuit.  This article details the steps to use either J-Link option.   Using external J-Link debug probe Segger offers several J-Link probe options.  To use one of these probes with these EVKs, configure the EVK with these settings: Remove jumpers J6 and J7, to disconnect the SWD signals from the onboard debug circuit.  These jumpers or installed by default. Power the EVK: the default option is connecting the power supply to barrel jack J43, and setting power switch SW5 to On position (3-6).  The green LED D16 next to SW5 will be lit when the EVK is properly powered. Connect the J-Link probe to J1, 20-pin dual-row 0.1" header.   Using onboard debug circuit with J-Link firmware Disconnect any USB cables from the EVK Power the EVK: the default option is connecting the power supply to barrel jack J43, and setting power switch SW5 to On position (3-6).  The green LED D16 next to SW5 will be lit when the EVK is properly powered. Short jumper J22 to force the debug circuit in DFU mode Connect a USB cable to J11, to the on-board debugger Follow Appnote AN13206 to program the J-Link firmware to the EVK Unplug the USB cable at J11 Remove the jumper at J22 Plug the USB cable back in to J11.  Now the on-board debugger should boot as a JLink. Install jumpers J6 and J7, to connect the SWD signals from onboard debug circuit.  These jumpers or installed by default. Note: with the JLink firmware loaded, USB J11 is no longer an option to power the EVK.  Another option is connecting the power supply to barrel jack J43, and setting power switch SW5 to On position (3-6).  For this power option, jumper J38 needs to short 1-2, which is the default setting.
View full article
Abstract Today I'd like to discuss a scenario that I will encounter in practical application. In the design phase, the Serial Nor flash is usually used as a code storage device for RT series MCUs, such as QSPI, HyperFlash, etc, as these devices all support XIP features. The flash usually is not only occupied by the code but also used to store data, such as device parameters, and log information, and even used as a file system. So we need to evaluate Flash's size. Is there any constraint to the manipulation of data space in the secure boot mode? And how to keep the data confidential? We'll talk about it below and let's get started. Secure boot mode HAB boot The bootable image is plaintext, and it may be changed after the writing operation of the FlexSPI module. If the digest algorithm obtains the different values will lead to the verification process fails, as the writing operation destroys the integrity of the data, regarding confidentiality, data is stored in plaintext in Serial Nor flash under HAB boot.   Fig1 Signature and verification process Encrypted XIP boot mode After enabling the Encrypted XIP boot mode, what is the impact on FlexSPI's read and write data operations? The first point is that the read data will be treated as encrypted data and decrypted by the BEE or OTFAD module. However, if a write operation is performed, the BEE or OTFAD module will be bypassed, in another word, the data will be written directly to the Serial Nor flash. in a short, it is not affected by the Encrypted XIP boot mode. 1) Read operation As shown in Fig 2, the encrypted code and data stored in Serial Nor flash need to be decrypted before they are sent to the CPU for execution. This is also the implementation mechanism of the Encrypted XIP boot mode. To enable the encrypted XIP boot mode, it needs to burn the keys to eFuse, after that, eFuse is impossible to restore, so the test cost seems a bit high, so I recommend you refer to the source code of the 《How to Enable the On-the-fly Decryption》application note to dynamically configure the key of the BEE module and read the encrypted array by DCP from Flash, then compare to plaintext array to verify BEE module participle the decryption flow. Fig 2 2) Write operation Modify the source code of the above application note, define s_nor_program_buffer [256], then set the values through the following code, and burn them to the 20th sector, the offset address is 0x14000. for (i = 0; i < 0xFFU; i++) { s_nor_program_buffer[i] = i; } status = flexspi_nor_flash_page_program(EXAMPLE_FLEXSPI, EXAMPLE_SECTOR * SECTOR_SIZE, (void *)s_nor_program_buffer); if (status != kStatus_Success) { PRINTF("Page program failure !\r\n"); return -1; } DCACHE_InvalidateByRange(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE, FLASH_PAGE_SIZE); memcpy(s_nor_read_buffer, (void *)(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE), sizeof(s_nor_read_buffer)); for(uint32_t i = 0; i < 256; i++) { PRINTF("The %d data in the second region is 0x%x\r\n", i, s_nor_read_buffer[i]); } After the programming finishes, connect to Jlink and use J-flash to check whether the burned array is correct. The results prove that the write operation will bypass the BEE or OTFAD module and write the data directly to the Serial Nor flash, which is consistent with Fig 2. Fig3 Sensitive data preservation As mentioned at the beginning, in the real project, we may need to use Flash to store data, such as device parameters, log information, or even as a file system, and the saved data is usually a bit sensitive and should prevent being easily obtained by others. For example, in SLN-VIZNAS-IoT, there is a dedicated area for storing facial feature data. Fig 4 Although the purely facial feature data is only meaningful for specific recognition algorithms, in another word, even if a third-party application obtains the original data, it is useless for hackers. In the development of real face recognization projects, it is usually to declare other data items associated with facial feature data, such as name, age, preferences, etc, as shown below: typedef union { struct { /*put char/unsigned char together to avoid padding*/ unsigned char magic; char name[FEATUREDATA_NAME_MAX_LEN]; int index; // this id identify a feature uniquely,we should use it as a handler for feature add/del/update/rename uint16_t id; uint16_t pad; // Add a new component uint16_t coffee_taste; /*put feature in the last so, we can take it as dynamic, size limitation: * (FEATUREDATA_FLASH_PAGE_SIZE * 2 - 1 - FEATUREDATA_NAME_MAX_LEN - 4 - 4 -2)/4*/ float feature[0]; }; unsigned char raw[FEATUREDATA_FLASH_PAGE_SIZE * 2]; } FeatureItem; // 1kB After enabling the Encrypted XIP boot mode, the above write operation test has proved that FlexSPI's write operation will program the data into Serial Nor flash directly, but during the reading process, the data will be decrypted by BEE or OTFAD, so we'd better use DCP or other modules to encrypt the data prior to writing, otherwise, the read operation will get the values that the plaintext goes through the decryption calculation. The risk of leakage Assume XIP encrypted boot is enabled, and whether it's okay to send the encrypted bootable image sent to the OEM for mass production. Moreover, is it able to allow the customers to access the encrypted bootable image without worrying about application image leakage? In order to verify the above guesses, I do the following testing on MIMXRT1060-EVK. Select the XIP encrypted mode in the MCUXpresso Secure Provisioning tool to generate and burn the bootable image of the Blink LED; Fig5 Observe the burned image through NXP-MCUBootUtility, you can find that the ciphertext image is very messy when compared to the plaintext image on the right border, so it seems like the NXP-MCUBootUtility can't obtain the plaintext image; Fig 6 Let's observe the ciphertext image in another way, read them through the pyocd command, as shown below; Fig 7 Open then 9_21_readback.Bin and compare it with the plain text image on the right border, they are the same actually, in other words, the plaintext image was leaked. Fig 8 Explanation As the above Fig 2 shows, the encrypted code and data stored in Serial Nor flash need to be decrypted before they are sent to the CPU for execution. When Jlink connects to the target MCU, it will load the corresponding flash driver algorithm to run in the FlexRAM. If the flash driver algorithm detects the boot type of the MCU just like the following code, then configures the BEE or OTFAD module according to the detecting result, after that, when reading the ciphertext in the Nor Flash, the data will be automatically decrypted. status = SLN_AUTH_check_context(SLN_CRYPTO_CTX_1); configPRINTF(("Context check status %d\r\n", status)); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash if (SLN_AUTH_NO_CONTEXT == status) { configPRINTF(("Ensuring context...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash // Load crypto contexts and make sure they are valid (our own context should be good to get to this point!) status = bl_nor_encrypt_ensure_context(); if (kStatus_Fail == status) { configPRINTF(("Failed to load crypto context...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash // Double check if encrypted XIP is enabled if (!bl_nor_encrypt_is_enabled()) { configPRINTF(("Not running in encrypted XIP mode, ignore error.\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a // crash // No encrypted XIP enabled, we can ignore the bad status status = kStatus_Success; } } else if (kStatus_ReadOnly == status) // Using this status from standard status to indicate that we need to split PRDB { volatile uint32_t delay = 1000000; // Set up context as needed for this application status = bl_nor_encrypt_split_prdb(); configPRINTF(("Restarting BOOTLOADER...\r\n")); while (delay--) ; // Restart DbgConsole_Deinit(); NVIC_DisableIRQ(LPUART6_IRQn); NVIC_SystemReset(); } } else if (SLN_AUTH_OK == status) { configPRINTF(("Ensuring context...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash // We will check to see if we need to update the backup to the reduced scope PRDB0 for bootloader space status = bl_nor_encrypt_ensure_context(); if (kStatus_Fail == status) { configPRINTF(("Failed to load crypto context...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash // Double check if encrypted XIP is enabled if (!bl_nor_encrypt_is_enabled()) { configPRINTF(("Not running in encrypted XIP mode, ignore error.\r\n")); // No encrypted XIP enabled, we can ignore the bad status status = kStatus_Success; } } else if (kStatus_Success == status) // We have good PRDBs so we can update the backup { bool isMatch = false; bool isOriginal = false; configPRINTF(("Checking backup context...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before a crash // Check if we have identical KIBs and initial CTR status = bl_nor_crypto_ctx_compare_backup(&isMatch, &isOriginal, SLN_CRYPTO_CTX_0); if (kStatus_Success == status) { if (isMatch && isOriginal) { configPRINTF(("Updating backup context with valid address space...\r\n")); // DEBUG_LOG_DELAY_MS(1000); // Optional delay, enable for debugging to ensure log is printed before // a crash // Update backup PRDB0 status = SLN_AUTH_backup_context(SLN_CRYPTO_CTX_0); } } } } How to handle Now we already understand the cause of the leak, we must prohibit external tools from loading flashloader or flash driver algorithms into the FlexRAM to run, so in addition to disabling the Debug port, we also need to disable the Serial download method to prevent the hackers take advantage of the Serial Downloader method to make the ROM code load a special flashloader to run in RAM, then configure the BEE or OTFAD module prior to reading the image. However, compared to simply prohibiting the debug port, I'd highly recommend you select the Secure Debug method, because the debug feature requirement is important to return/filed testing, Secure Debug just is like adding a sturdy lock to the debug port, and only the authorized one can open this lock to enter the debugging mode successfully. Reference AN12852:How to Enable the On-the-fly Decryption 《The trust chain of HAB boot》
View full article
Introduction NXP i.MX RT1xxx series provide the High Assurance Boot (HAB) feature which makes the hardware to have a mechanism to ensure that the software can be trusted, as the HAB feature enables the ROM to authenticate the program image by using digital signatures, which can assure the application image's integrity, authenticated and undeniable. So the OEM can utilize it to make their product reject any system image which is not authorized to run. However, what's the trust chain of HAB for implementing the purpose? How the key and certificate generate In the installation directory of MCUXpresso Secure Provisioning:  ~\nxp\MCUX_Provi_v3.1\bin\tools_scripts\keys , there are scripts for generating keys: hab4_pki_tree.sh and hab4_pki_tree.bat (both are applicable to Linux and Windows systems respectively), running any of the above scripts will generate 13 pairs of public and private keys in sequence through OpenSSL, which constitute the below tree structure. Fig1 Key Tree structure The public key and private key generated by OpenSSL are paired one by one, saving the private key and publishing the corresponding public key to the outside world can easily implement asymmetric encryption applications. But how to ensure that the obtained public key is correct and has not been tampered with? At this time, the intervention of authoritative departments is required. Just like everyone can print their resume and say who they are, but if they have the seal of the Public Security Bureau, only the household registration book can prove you are you. This issued by the authority is called a certificate. What's in the certificate? Of course, it should contain a public key, which is the most important; there is also the owner of the certificate, just like the household registration book with your name and ID number, indicating that the book is yours; in addition, there is the issuer of the certificate and the validity period of the ID card is a bit like the issuer institution on the ID card, and how many years of the validity period. If someone fakes a certificate issued by an authority, it's like having fake ID cards and fake household registration books. To generate a certificate, you need to initiate a certificate request, and then send the request to an authority for certification, which is called a CA(Certificate Authority). After sending this request to the authority, the authority will give the certificate a signature. Another question arises, how can the signature be guaranteed to be signed by a genuine authority? Of course, it can only be signed with something that is only in the hands of the authority, which is the CA's private key. The signature algorithm probably works like this: a Hash calculation is performed on the target information to obtain a Hash value. And this process is irreversible, that is to say, the original information content cannot be obtained through the Hash value. When the information is sent out, the hash value is encrypted and sent together with the information as a signature. The process is as follows. Fig2 Signature and verification process Looking at the content of the certificate (as shown below), we will find that there is an Issuer, that is, who issued the certificate; The subject is to who the certificate is issued; Validity is the certificate period; Public-key is the content of the public key, and related signature algorithm. You will find that in order to verify the certificate, the public key of the CA is required. Then a new question arises. How can we be sure that the public key of the CA is correct? This requires a superior CA to sign the CA's public key, and then form the CA's certificate. If you want to know whether a CA's certificate is reliable, you need to see if the public key of the CA's superior certificate can unlock the CA's signature. Just likes if you don’t trust the District Public Security Bureau, you can call the Municipal Public Security Bureau and ask the Municipal Public Security Bureau to confirm its legitimacy of the District Public Security Bureau. This goes up layer by layer until the root CA makes the final endorsement. Through this layer-by-layer credit endorsement method, the normal operation of the asymmetric encryption mode is guaranteed. How does the Root CA prove itself? At this time, Root CA will issue another certificate (as shown below), called the Self-Signed Certificate, which is to sign itself with its own private key, giving people a feeling of "I am me, whether you believe it or not", Therefore, its format content is slightly different from the above CA certificate. Its Issuer and Subject are the same, and its own public key can be used for authentication. So the certificate authentication process will also end here. In this way, in addition to generating the public key and private key through running the script, the OpenSSL will also generate the certificate chain shown below.  Fig3 certificates Boot flow of the HAB mode Figure 4 shows the boot flow of the HAB mode. And steps 1, 2, and 3 are essentially the signature verification process. Fig4 Boot flow of the HAB mode The verification process (as shown in Figure 2) can be used to detect data integrity, identity authentication, and non-repudiation when the public key is trusted, so hab4_pki_tree.sh and hab4_pki_tree.bat scripts can ensure the generated public key and private key pair and the certificate are trusted, it's the "perfectly closed loop". However, the Application image in Figure 4 is plaintext, and the confidentiality of the data is not implemented, so the encrypted boot is always a combination of the HAB boot and the encrypted boot is an advanced usage of an authenticated boot. Reference AN4581: i.MX Secure Boot on HABv4 Supported Devices AN12681: How to use HAB secure boot in i.MX RT10xx
View full article
1.  Abstract NXP EdgeReady solution can use RT106/5 S/L/A/F to achieve speech recognition, but the relevant support software libraries for the RT4-bit series are limited to the S/L/A/F series, if you want to use normal RT chips, how to achieve speech recognition functions? NXP officially launched the VIT software package in the SDK, which can support RT1060, RT1160, RT1170, RT600, RT500 to achieve SDK-based speech recognition functions. For the acquisition of weather information, usually customer can connect with a third-party platform or the cloud weather API, using http client method to access directly, the current weather API platforms, you can register it, then call the API directly, so you can use the RT SDK lwip socket client method to call the corresponding weather API, to achieve real-time specific geographical location weather forecast data.     This article will use MIMXRT1060-EVK to implement customer-defined wake-up word(WW) and voice recognition word recognition(VC) based on SDK VIT lib, and LWIP socket client to achieve real-time weather information acquisition in Shanghai, then print it to the terminal, this article mainly use the print to share the weather information, for the sound broadcasts, it also add the simple method to broadcast the fixed sound with mp3 audio data, but for the freely sound broadcast, it may need to use real-time TTS function, which is not added now.     The system block diagram of this document is as follows:   Fig 1 System Block diagram The VIT custom wake-up word of this system is "小恩小恩", and after waking up, one of the following recognition words can be recognized: ”开灯”("Turn on the lights"),“关灯”("Turn off the lights"),”今天天气”("Today's weather"),“明天天气”("Tomorrow's Weather"),“后天天气”("The day after tomorrow's weather"). Turn on the light or Turn off the lights , that is to control  the external LED red light on the EVK board. ”今天天气” gets today’s weather forecast, it is in the following format:                     "date": "2022-05-27",                     "week": "5",                     "dayweather": "阴",                     "nightweather": "阴",                     "daytemp": "28",                     "nighttemp": "21",                     "daywind": "东南",                     "nightwind": "东南",                     "daypower": "≤3",                     "nightpower": "≤3" “明天天气”,“后天天气” are the same format, but it is 1-2 days after the date of today. To get the weather data, the MIMXRT1060-EVK board needs to connect the network to achieve the acquisition of the Gaode Map(restapi.amap.com) Weather API data. 2.  Related preparations 2.1 Weather API Platform     At present, there are many third-party platforms that can obtain weather on the Internet for Chinese, such as: Baidu Intelligent Cloud, Baidu Map API, Huawei cloud platform, Juhe weather, Gaode Map API, and so on. This article tried several platform, the test results found: Baidu intelligent cloud, the number of daily free calls is small, the need for real-time synthesis of AK, SK, cumbersome to call; Baidu Map API needs to upload ID card information; Several others have a similar situation. In the end, the Gaode Map API with convenient registration, many daily calls and relatively full feedback weather data information was selected.     Here, we mainly talk about the Gaode Map API usage, the link is: https://lbs.amap.com/api/webservice/guide/api/weatherinfo Create the account and the API key, then add the relevant parameters to implement the call of the weather API, the application for API Key is as follows: Fig 2 Gaode map API key The following diagram shows the call volume:   Fig 3 Gaode Map API call volume This is the API calling format:   Fig 4 Weather API calling parameters So, the full Gaode Map API link should like this: https://restapi.amap.com/v3/weather/weatherInfo?key=xxxxxxx&city=xxx&extensions=all&output=JSON If need to test the Shanghai weather, city code is 310000. 2.2 Postman test weather API     Postman is an interface testing tool, when doing interface testing, Postman is equivalent to a client, it can simulate various HTTP requests initiated by users, send the request data to the server, obtain the corresponding response results, and verify whether the result data in the response matches the expected value. Postman download link: https://www.postman.com/   After finding the proper weather API platform and the calling link, use the postman do the http GET operation to capture the weather data, refer to the Fig 4, fill the related parameters to the postman: Fig 5 Postman call weather API Send Get command, we can find the weather information in the position 7, the complete all information is: {     "status": "1",     "count": "1",     "info": "OK",     "infocode": "10000",     "forecasts": [         {             "city": "上海市",             "adcode": "310000",             "province": "上海",             "reporttime": "2022-05-27 17:34:12",             "casts": [                 {                     "date": "2022-05-27",                     "week": "5",                     "dayweather": "阴",                     "nightweather": "阴",                     "daytemp": "28",                     "nighttemp": "21",                     "daywind": "东南",                     "nightwind": "东南",                     "daypower": "≤3",                     "nightpower": "≤3"                 },                 {                     "date": "2022-05-28",                     "week": "6",                     "dayweather": "小雨",                     "nightweather": "中雨",                     "daytemp": "24",                     "nighttemp": "20",                     "daywind": "东南",                     "nightwind": "东南",                     "daypower": "≤3",                     "nightpower": "≤3"                 },                 {                     "date": "2022-05-29",                     "week": "7",                     "dayweather": "大雨",                     "nightweather": "小雨",                     "daytemp": "23",                     "nighttemp": "20",                     "daywind": "南",                     "nightwind": "南",                     "daypower": "≤3",                     "nightpower": "≤3"                 },                 {                     "date": "2022-05-30",                     "week": "1",                     "dayweather": "小雨",                     "nightweather": "晴",                     "daytemp": "27",                     "nighttemp": "20",                     "daywind": "北",                     "nightwind": "北",                     "daypower": "≤3",                     "nightpower": "≤3"                 }             ]         }     ] }   We can see, it can capture the continuous 4 days information, with this information, we can get the weather information easily. From the postman, we also can see the Get code, like this: Fig 6 postman API HTTP code     With this API which already passed the testing, it can capture the complete weather information, here, we can consider adding the working http API to the MIMXRT1060-EVK code.    2.3 VIT custom commands     From the maestro code of the RT1060 SDK, we can know that the SDK already supports the VIT library, what is VIT?     VIT's full name: Voice Intelligent Technology, the library provides voice recognition services designed to wake up and recognize specific commands, control IOT, and the smart home. Fig 7 VIT system block diagram     In NXP RT1060 SDK code, the generated wake word and command word have been provided and placed in the VIT_Model.h file. If in the customer's project, how to customize the wake word and command word? With the NXP's efforts, we have made a web page form for customers to choose their own command, and then generate the corresponding VIT_Model.h file for code to call. VIT command word generation web page is: https://vit.nxp.com/#/home     Login the NXP account, choose the RT chip partn umber, wakeup word, voice command. Please note, the current supported RT chip is: RT1060,RT1160,RT1170,RT600,RT500 The following is the example for generating wakeup word and voice command:   Fig 8 Custom VIT configuration Fig 9 generated result Download the generated model, you can get VIT_Model_cn.h, open to see the command word information and related model data stored in the const PL_MEM_ALIGN (PL_UINT8 VIT_Model_cn[], VIT_MODEL_ALIGN_BYTES) array, the command word information is as follows: WakeWord supported : " 小恩 小恩 " Voice Commands supported     Cmd_Id : Cmd_Name       0    : UNKNOWN       1    : 开灯       2    : 关灯       3    : 今天 天气       4    : 明天 天气       5    : 后天 天气 Use the RT1060 SDK maestro_record demo to test this custom command result:   Fig 10 Custom Wakeup word and voice command test From the test result, we can see, both the wakeup word and voice command is detected. 3 Software code 3.1 LWIP socket client code capture weather API From chapter 2.2, we have been able to obtain the weather API and through testing, we can successfully achieve weather acquisition, so we need to add relevant commands in combination with the needs of our own system. For the acquisition of the weather API, the lwip code based on the RT1060 SDK is in the form of socket client. The relevant code is as follows: #define PORT 80 #define IP_ADDR "59.82.9.133" uint8_t get_weather[]= "GET /v3/weather/weatherInfo?key=xxx&city=310000&extensions=all&output=JSON HTTP/1.1\r\nHost: restapi.amap.com\r\n\r\n\r\n\r\n"; if (sys_thread_new("weather_main", weathermain_thread, NULL, HTTPD_STACKSIZE, HTTPD_PRIORITY) == NULL) LWIP_ASSERT("main(): Task creation failed.", 0); static void weathermain_thread(void *arg) { static struct netif netif; ip4_addr_t netif_ipaddr, netif_netmask, netif_gw; ethernetif_config_t enet_config = { .phyHandle = &phyHandle, .macAddress = configMAC_ADDR, }; LWIP_UNUSED_ARG(arg); mdioHandle.resource.csrClock_Hz = EXAMPLE_CLOCK_FREQ; IP4_ADDR(&netif_ipaddr, configIP_ADDR0, configIP_ADDR1, configIP_ADDR2, configIP_ADDR3); IP4_ADDR(&netif_netmask, configNET_MASK0, configNET_MASK1, configNET_MASK2, configNET_MASK3); IP4_ADDR(&netif_gw, configGW_ADDR0, configGW_ADDR1, configGW_ADDR2, configGW_ADDR3); tcpip_init(NULL, NULL); netifapi_netif_add(&netif, &netif_ipaddr, &netif_netmask, &netif_gw, &enet_config, EXAMPLE_NETIF_INIT_FN, tcpip_input); netifapi_netif_set_default(&netif); netifapi_netif_set_up(&netif); PRINTF("\r\n************************************************\r\n"); PRINTF(" TCP client example\r\n"); PRINTF("************************************************\r\n"); PRINTF(" IPv4 Address : %u.%u.%u.%u\r\n", ((u8_t *)&netif_ipaddr)[0], ((u8_t *)&netif_ipaddr)[1], ((u8_t *)&netif_ipaddr)[2], ((u8_t *)&netif_ipaddr)[3]); PRINTF(" IPv4 Subnet mask : %u.%u.%u.%u\r\n", ((u8_t *)&netif_netmask)[0], ((u8_t *)&netif_netmask)[1], ((u8_t *)&netif_netmask)[2], ((u8_t *)&netif_netmask)[3]); PRINTF(" IPv4 Gateway : %u.%u.%u.%u\r\n", ((u8_t *)&netif_gw)[0], ((u8_t *)&netif_gw)[1], ((u8_t *)&netif_gw)[2], ((u8_t *)&netif_gw)[3]); PRINTF("************************************************\r\n"); sys_thread_new("weather", weather_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); vTaskDelete(NULL); } static void weather_thread(void *arg) { int sock = -1,rece; struct sockaddr_in client_addr; char* host_ip; ip4_addr_t dns_ip; err_t err; uint32_t *pSDRAM= pvPortMalloc(BUF_LEN);// host_ip = HOST_NAME; PRINTF("host name : %s , host_ip : %s\r\n",HOST_NAME,host_ip); while(1) { sock = socket(AF_INET, SOCK_STREAM, 0); if (sock < 0) { PRINTF("Socket error\n"); vTaskDelay(10); continue; } client_addr.sin_family = AF_INET; client_addr.sin_port = htons(PORT); client_addr.sin_addr.s_addr = inet_addr(host_ip); memset(&(client_addr.sin_zero), 0, sizeof(client_addr.sin_zero)); if (connect(sock, (struct sockaddr *)&client_addr, sizeof(struct sockaddr)) == -1) { PRINTF("Connect failed!\n"); closesocket(sock); vTaskDelay(10); continue; } PRINTF("Connect to server successful!\r\n"); write(sock,get_weather,sizeof(get_weather)); while (1) { rece = recv(sock, (uint8_t*)pSDRAM, BUF_LEN, 0);//BUF_LEN if (rece <= 0) break; memcpy(weather_data.weather_info, pSDRAM,1500);//max 1457 } Weather_process(); memset(pSDRAM,0,BUF_LEN); closesocket(sock); vTaskDelay(10000); } }  3.2 VIT detect customer command code    Put the generated VIT_Model_cn.h to the maestro_record folder path:   vit\RT1060_CortexM7\Lib    The specific wake word and voice command related code can be viewed from the code vit_pro.c, mainly involving function is: int VIT_Execute(void *arg, void *inputBuffer, int size) The code is modified as follows, mainly to record the wake and wake word number, for specific function control, the command directly controlled here is the local "开灯:turn on the light", "关灯:turn off the light" command, as for the weather command needs to call the socket client API, so in the main lwip call area combined with the command word recognition number to call: if (VIT_DetectionResults == VIT_WW_DETECTED) { PRINTF(" - WakeWord detected \r\n"); weather_data.ww_flag = 1; //kerry } else if (VIT_DetectionResults == VIT_VC_DETECTED) { // Retrieve id of the Voice Command detected // String of the Command can also be retrieved (when WW and CMDs strings are integrated in Model) VIT_Status = VIT_GetVoiceCommandFound(VITHandle, &VoiceCommand); if (VIT_Status != VIT_SUCCESS) { PRINTF("VIT_GetVoiceCommandFound error: %d\r\n", VIT_Status); return VIT_Status; // will stop processing VIT and go directly to MEM free } else { PRINTF(" - Voice Command detected %d", VoiceCommand.Cmd_Id); weather_data.vc_index = VoiceCommand.Cmd_Id;//kerry 1:ledon 2:ledoff 3:today weather 4:tomorrow weather 5:aftertomorrow weather if(weather_data.vc_index == 1)//1 { GPIO_PinWrite(GPIO1, 3, 1U); //pull high PRINTF(" led on!\r\n"); } else if(weather_data.vc_index == 2)//2 { GPIO_PinWrite(GPIO1, 3, 0U); //pull low PRINTF(" led off!\r\n"); } // Retrieve CMD Name: OPTIONAL // Check first if CMD string is present if (VoiceCommand.pCmd_Name != PL_NULL) { PRINTF(" %s\r\n", VoiceCommand.pCmd_Name); } else { PRINTF("\r\n"); } } }  3.3 Voice recognize weather information    In the weather_thread while, check the wakeup word and voice command, if meet the requirement, then create the socket connection, write the API and capture the weather data.   The related code is: while(1) { //add the command request, only cmd == weather flag, then call it. if((weather_data.ww_flag == 1)) { if(weather_data.vc_index >= 3) { // create connection //write API and read API Weather_process(); } memset(weather_data.weather_info, 0, sizeof(weather_data.weather_info)); weather_data.ww_flag = 0; weather_data.vc_index = 0; } vTaskDelay(10000); } void Weather_process(void) { char * datap, *datap1; datap = strstr((char*)weather_data.weather_info,"date"); if(datap != NULL) { memcpy(today_weather, datap,184);//max 1457 if(weather_data.vc_index == 3) { PRINTF("\r\n*******************today weather***********************************\n\r"); PRINTF("%s\r\n",today_weather); return; } } else return; datap1 = strstr(datap+4,"date"); if(datap1 != NULL) { memcpy(tomorr_weather, datap1,184);//max 1457 if(weather_data.vc_index == 4) { PRINTF("\r\n*******************tomorrow weather*******************************\n\r"); PRINTF("%s\r\n",tomorr_weather); return; } } else return; datap = strstr(datap1+4,"date"); if(datap != NULL) { memcpy(aftertom_weather, datap,184);//max 1457 if(weather_data.vc_index == 5) { PRINTF("\r\n*******************after tomorrow weather**************************\n\r"); PRINTF("%s\r\n",aftertom_weather); } } else return; }   Function Weather_process is used to refer to the voice recognized weather number to get the related date’s weather, and printf it. 4 Test result  the test result video: Print the log results as shown in Figure 11, after testing, you can see that the wakeup word and voice command can be successfully recognized, in the recognition of word sequence numbers 3, 4, 5 is the weather acquisition, you can successfully call the lwip socket client API, successfully obtain weather information and printf it.   Fig 11 system test print result  evkmimxrt1060_maestro_weather_backup.zip is the project without sound playback, weather information will print to the terminal! 5 Meet issues conclusion 5.1 LWIP failed to get weather    When creating the code, call the postman provided http code: GET /v3/weather/weatherInfo?key=8f777fc7d867908eebbad7f96a13af10&amp; city=310000&amp; extensions=all&amp; output=JSON HTTP/1.1 Host: restapi.amap.com    Add it to the socket API function: uint8_t get_weather[]= "GET /v3/weather/weatherInfo?key=xxx&amp;city=310000&amp;extensions=all&amp;output=JSON HTTP/1.1\r\nHost: restapi.amap.com\r\n\r\n\r\n\r\n";    The test result is:   Fig 12 socket weather API return issues     We can see, server connection is OK, http also return back the data, but it report the parameter issues, after checking, we use the postman C code, and put it to the get_weather: uint8_t get_weather[]= "GET /v3/weather/weatherInfo?key=xxx&city=310000&extensions=all&output=JSON HTTP/1.1\r\nHost: restapi.amap.com\r\n\r\n\r\n\r\n"; Then, it can capture the weather data, the same as postman test result. 5.2 VIT LWIP merger memory is not enough     After combining the maestro_record and lwip socket code together, compile it, it will meet the DTCM memory overflow issues. Fig 13 memory overflow After optimize, still meet the DTCM overflow issues, so, at last, choose to reconfigure the FlexRAM: OCRAM 192K, DTCM 256K, ITCM 64K Compile it, and the memory overflow issues disappear:   Fig 14 FlexRAM recofiguration 5.3 Print Chinese word in tera    Directly use teraterm, when the weather API returns the Chinese word, the print out information is the garbled code, and then after the following configuration, to achieve Chinese printing: Setup  ->  Terminal Locale    : american->chinese Codepage : 65001 ->936 Fig 15 Tera Term Chinese word print In summary, after various data collection and problem solving, in MIMXRT1060-EVK board  combined with the official SDK complete the function of customizing VIT voice commands to obtain real-time weather and local control.So, even if the ordinary RT series which is not S/L/A/F series, you also can use VIT to implement speech recognition functions. 6 Add the sound broadcast    This chapter mainly gives the method how to add the sound broadcast with the mp3 video data which is stored in the memory, but to the realtime weather data playback, it is not very freely, it needs to check the weather data, and use the video mp3 data lib get the correct mp3 data, as it is not the online TTS method.     So, here, just share one example add the sound broadcast, eg: WW : “小恩小恩”    ->   “小恩来了,请吩咐!” VC  :“今天天气”   ->   “温度32.1度” VC playback is fixed now, if need to play real data, it needs to generate the mp3 voice data lib, then according to the feedback weather information, to generate the correct weather mp3 data array, and play it, as this is a little complicated, but not difficult, so here, just use one fixed sound give an example of it. 6.1 MP3 playback audio data preparation     For audio broadcasting which need to convert the Chinese word into MP3 files, you can use some online speech synthesis software, here use Baidu online speech synthesis function, you can view the previous article, chapter 2.2.2 online speech synthesis: https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT106L-S-voice-control-system-based-on-the-Baidu-cloud/ta-p/1363295     If use the Baidu online speech synthesis generated mp3 file to convert to the c array directly, it will meet the first audio play issues, so, here we use the Audacity to convert the mp3 file, the convert configuration is like this:  Fig 16 Audacity convert configuration     After the regeneration of mp3, you can use xxd .exe to convert the mp3 file to an array of C files, and then put it into RT-related memory or external flash , xxd .exe can be found at the following link: https://github.com/baldram/ESP_VS1053_Library/issues/18 The convert command like this: xxd -i your-sound.mp3 ready-to-use-header.c Convert the xiaoencoming.mp3 and temptest.mp3 file to the C array, then modify the data to the C file, save file as: xiaoencoming.h and temptest.h. Here, take xiaoencoming.c as an example: #define XIAOEN_MP3_SIZE  6847 unsigned char xiaoencoming_mp3[XIAOEN_MP3_SIZE] = {   0x49, 0x44, 0x33, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21, 0x54, 0x58, …   0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55 }; unsigned int xiaoencoming1_mp3_len = XIAOEN_MP3_SIZE;//6847; Until now, the playback audio data is finished.     Copy xiaoencoming.h and temptest.h to project path: evkmimxrt1060_maestro_weather_mp3\source 6.2 Play the MP3 data from memory    Here, share the related code. 6.2.1 app_streamer.c added code    #include "xiaoencoming.h" #include "temptest.h" void *voice_inBuf = NULL; void *voice_outBuf = NULL; status_t STREAMER_file_Create(streamer_handle_t *handle, char *filename, int eap_par) { STREAMER_CREATE_PARAM params; OsaThreadAttr thread_attr; int ret; ELEMENT_PROPERTY_T prop; MEMSRC_SET_BUFFER_T inBufInfo = {0}; SET_BUFFER_DESC_T outBufInfo = {0}; PRINTF("Kerry test begin!\r\n"); if(filename == "temptest.mp3") inBufInfo = (MEMSRC_SET_BUFFER_T){.location = (int8_t *)temptest_mp3, .size = TEMPtest_MP3_SIZE}; else if(filename == "xiaoencoming.mp3") inBufInfo = (MEMSRC_SET_BUFFER_T){.location = (int8_t *)xiaoencoming_mp3, .size = XIAOEN_MP3_SIZE}; /* Create message process thread */ osa_thread_attr_init(&thread_attr); osa_thread_attr_set_name(&thread_attr, STREAMER_MESSAGE_TASK_NAME); osa_thread_attr_set_stack_size(&thread_attr, STREAMER_MESSAGE_TASK_STACK_SIZE); ret = osa_thread_create(&msg_thread, &thread_attr, STREAMER_MessageTask, (void *)handle); osa_thread_attr_destroy(&thread_attr); if (ERRCODE_NO_ERROR != ret) { return kStatus_Fail; } /* Create streamer */ strcpy(params.out_mq_name, APP_STREAMER_MSG_QUEUE); params.stack_size = STREAMER_TASK_STACK_SIZE; params.pipeline_type = STREAM_PIPELINE_MEM; params.task_name = STREAMER_TASK_NAME; params.in_dev_name = "buffer"; params.out_dev_name = "speaker"; handle->streamer = streamer_create(&params); if (!handle->streamer) { return kStatus_Fail; } prop.prop = PROP_DECODER_DECODER_TYPE; prop.val = (uintptr_t)DECODER_TYPE_MP3; ret = streamer_set_property(handle->streamer, prop, true); if (ret != STREAM_OK) { streamer_destroy(handle->streamer); handle->streamer = NULL; return kStatus_Fail; } prop.prop = PROP_MEMSRC_SET_BUFF; prop.val = (uintptr_t)&inBufInfo; ret = streamer_set_property(handle->streamer, prop, true); if (ret != STREAM_OK) { streamer_destroy(handle->streamer); handle->streamer = NULL; return kStatus_Fail; } handle->audioPlaying = false; error: PRINTF("End STREAMER_file_Create\r\n"); PRINTF("Kerry test end!\r\n"); return kStatus_Success; }   The code implements the thread build, creates a streamer, defines it as playing from memory, decodes the properties for MP3, and specifies an array of MP3 files in memory. Specify a different array of mp3 files in memory based on the calling file name. 6.2.2 cmd.c added code void play_file(char *filename, int eap_par) { STREAMER_Init(); int ret = STREAMER_file_Create(&streamerHandle, filename, eap_par); if (ret != kStatus_Success) { PRINTF("STREAMER_file_Create failed\r\n"); goto file_error; } STREAMER_Start(&streamerHandle); PRINTF("Starting playback\r\n"); file_playing = true; while (streamerHandle.audioPlaying) { osa_time_delay(100); } file_playing = false; file_error: PRINTF("[play_file] Cleanup\r\n"); STREAMER_Destroy(&streamerHandle); osa_time_delay(100); }   Play file, it calls the STREAMER_file_Create API function, start play, and wait the play finished, then release the STREAMER. shellRecMIC API function add the VIT recorded flag, which is used to play feedback audio file. static shell_status_t shellRecMIC(shell_handle_t shellHandle, int32_t argc, char **argv) { … //kerry PRINTF("Kerry MP3 stream data test!\r\n"); PRINTF("---weather_data.ww_flag =%d--\r\n ", weather_data.ww_flag); PRINTF("---weather_data.vc_inde =%d--\r\n ", weather_data.vc_index); PRINTF("---weather_data.mp3_flag =%d--\r\n ", weather_data.mp3_flag); if(weather_data.ww_flag == 1) { play_file("xiaoencoming.mp3", 0); } if(weather_data.vc_index == 3) { play_file("temptest.mp3", 0); } if(weather_data.mp3_flag != 0) { weather_data.ww_flag = 0; weather_data.vc_index = 0; } weather_data.mp3_flag = 0; /* Delay for cleanup */ osa_time_delay(100); return kStatus_SHELL_Success; } If detect the Wakeup Word: “小恩小恩”, play feedback audio: “小恩来了请吩咐”. If detect the voice command: “今天天气”, play feedback audio: “温度32.1度”, please note, this playback just an example, it is the fixed audio, you also can create audio word lib, then according to the received weather information, combine the related word audio together, then playback it. This is a little complicated, but not difficult. So, if need to play the free audio, also can consider the online TTS method in real time. 6.2.3 VIT WW and VC flag VIT_Execute function int VIT_Execute(void *arg, void *inputBuffer, int size) { … if (VIT_DetectionResults == VIT_WW_DETECTED) { PRINTF(" - WakeWord detected \r\n"); weather_data.ww_flag = 1; //kerry weather_data.mp3_flag = 1; } else if (VIT_DetectionResults == VIT_VC_DETECTED) { // Retrieve id of the Voice Command detected // String of the Command can also be retrieved (when WW and CMDs strings are integrated in Model) VIT_Status = VIT_GetVoiceCommandFound(VITHandle, &VoiceCommand); if (VIT_Status != VIT_SUCCESS) { PRINTF("VIT_GetVoiceCommandFound error: %d\r\n", VIT_Status); return VIT_Status; // will stop processing VIT and go directly to MEM free } else { PRINTF(" - Voice Command detected %d", VoiceCommand.Cmd_Id); weather_data.vc_index = VoiceCommand.Cmd_Id;//kerry 1:ledon 2:ledoff 3:today weather 4:tomorrow weather 5:aftertomorrow weather weather_data.mp3_flag = 2; if(weather_data.vc_index == 1)//1 { GPIO_PinWrite(GPIO1, 3, 1U); //pull high PRINTF(" led on!\r\n"); } else if(weather_data.vc_index == 2)//2 { GPIO_PinWrite(GPIO1, 3, 0U); //pull low PRINTF(" led off!\r\n"); } // Retrieve CMD Name: OPTIONAL // Check first if CMD string is present if (VoiceCommand.pCmd_Name != PL_NULL) { PRINTF(" %s\r\n", VoiceCommand.pCmd_Name); } else { PRINTF("\r\n"); } } } return VIT_Status; }   Until now, all the code is added. 6.2.4  playback audio test result     This is the audio playback test result:   Fig 17 playback audio log   From the test result, we can see, we also can use the mp3 data which is stored in the memory and play it as audio playback.   The code project is: evkmimxrt1060_maestro_weather_mp3.zip.
View full article
RT10xx image reserve the APP FCB methods 1. Abstract     Regarding RT10XX programming, it is mainly divided into two categories: 1) Serial download mode with blhost proramming     To this method, we can use the MCUBootUtility tool, or blhost+elftosb+sdphost cmd method, we also can use the NXP SPT(MCUXpresso secure provisional Tool). This programming need to enter the serial download mode, then use the flashloader supported UART or the USB HID interface. 2) Use Programmer or debugger with flashdriver programming This method is usually through the SWD/JTAG download interface combined with the debugger + IDE, or directly software burning, the chip mode can be in the internal boot, or in the serial download mode, with the help of the flashloader to generate the flash burning algorithm file. Method 2, The burning method using the debugger tool usually ensures that the burning code is consistent with the original APP.     Method 1, Uses the blhost method to download, usually blhost will regenerate an FCB with a full-featured LUT to burn to the external flash, and then burn the app code with IVT, that is, without the FCB header of the original APP, and re-assemble a blhost generated FCB header and burn it separately. However, for some customers who need to read out the flash image and compare with the original APP image to check the difference after burning, the commonly used blhost method will have the problem of inconsistent FCB area matching. If the customer needs to use the blhost burning method in serial download mode, how to ensure that the flash image after burning is consistent with the original burning file? This article will take the MIMXRT1060-EVK development board as an example, and give specific methods for the command mode and SPT tool mode. 2 Blhost programming reserve APP FCB     From the old RT1060 SDK FCB file (below SDK2.12.0), evkmimxrt1060_flexspi_nor_config.c, we can see:   const flexspi_nor_config_t qspiflash_config = { .memConfig = { .tag = FLEXSPI_CFG_BLK_TAG, .version = FLEXSPI_CFG_BLK_VERSION, .readSampleClksrc=kFlexSPIReadSampleClk_LoopbackFromDqsPad, .csHoldTime = 3u, .csSetupTime = 3u, .sflashPadType = kSerialFlash_4Pads, .serialClkFreq = kFlexSpiSerialClk_100MHz, .sflashA1Size = 8u * 1024u * 1024u, .lookupTable = { // Read LUTs FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEB, RADDR_SDR, FLEXSPI_4PAD, 0x18), FLEXSPI_LUT_SEQ(DUMMY_SDR, FLEXSPI_4PAD, 0x06, READ_SDR, FLEXSPI_4PAD, 0x04), }, }, .pageSize = 256u, .sectorSize = 4u * 1024u, .blockSize = 64u * 1024u, .isUniformBlockSize = false, };   This FCB LUT just contains the basic read command, normally, to the app booting, the FCB just need to provide the read command to the ROM, then it can boot normally.     But what happens to the memory downloaded by blhost? Based on the MIMXRT1060-EVK development board, the following shows how to use the command line mode corresponding to blhost to burn the SDK led_blinky project app, and read out the corresponding flash burning code to analysis. 2.1 Normal blhost download command line    This command line also the same as MCUBootUtility download log, source code is attached rt1060 cmd.bat. elftosb.exe -f imx -V -c imx_application_gen.bd -o ivt_evkmimxrt1060_iled_blinky_FCB.bin evkmimxrt1060_iled_blinky.s19 sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- write-file 0x20208200 ivt_flashloader.bin sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- jump-address 0x20208200 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 1 0 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 24 0 blhost.exe -t 5242000 -u 0x15A2,0x0073 -j -- fill-memory 0x20202000 4 0xc0000007 word  //option 0 blhost.exe -t 5242000 -u 0x15A2,0x0073 -j -- fill-memory 0x20202004 4 0 word                 //option1 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- configure-memory 9 0x20202000                    blhost -t 2048000 -u 0x15A2,0x0073 -j -- flash-erase-region 0x60000000 0x8000 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- fill-memory 0x20203000 4 0XF000000F word  blhost -t 50000 -u 0x15A2,0x0073 -j -- configure-memory 9 0x20203000                    blhost -t 5242000 -u 0x15A2,0x0073 -j -- write-memory 0x60001000 ivt_evkmimxrt1060_iled_blinky_FCB_nopadding.bin 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 0x8000 flexspiNorCfg.dat 9 The normal blhost programming is to use the cmd line method, and provide an app which is without the FCB header(Even app with the FCB, will exclude the FCB header at first), then use the elftosb.exe generate the app with IVT, eg ivt_evkmimxrt1060_iled_blinky_FCB_nopadding.bin, download the flashloader file ivt_flashloader to internal RAM, and jump to the flashloader, then use the fill-memory to fill option0, option1 to choose the proper external flash, and use the configure-memory to configure the flexSPI module, with the SFDP table which is got from get configure command, then fill the flexSPI LUT internal buffer. Next, fill-memory 0x20203000 4 0XF000000F associate with configure-memory will generate the full FCB header, burn it from flash address 0x60000000. At last, burn the app which contains IVT from flash address 0X60001000, until now, realize the whole app image programming. Pic 1 shows the comparison between the data read after programming and the original app data. It can be seen that the LUT of the FCB actually programmed on the left is not only contains read, but also contains read status, write enable, program and erase commands. The one on the right is the original app with FCB. The LUT of FCB only contains read commands for boot. So, if you want to keep the FCB header of the original APP instead of the header generated and burned by option0,1 configure-memory, how to do it? The method is that you can also use Option0, 1 to generate and fill in the LUT for flexSPI for communication use, but do not burn the corresponding generated FCB, just burn the FCB that comes with the original APP. pic1 2.2 Reuse option0 and option1 to program the original APP LUT The following command gives reuse option0 and option1, generates LUT and fills in flexSPI LUT for connection with external flash interface, but does not call:  fill-memory 0x20203000 4 0XF000000F and configure-memory 9 0x20203000, so that the generated FCB will not be burned to external memory.    Source file is attached rt1060 cmd_option01.bat. elftosb.exe -f imx -V -c imx_application_gen.bd -o ivt_evkmimxrt1060_iled_blinky_FCB.bin evkmimxrt1060_iled_blinky.s19 sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- write-file 0x20208200 ivt_flashloader.bin sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- jump-address 0x20208200 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 1 0 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 24 0 blhost.exe -t 5242000 -u 0x15A2,0x0073 -j -- fill-memory 0x20202000 4 0xc0000007 word blhost.exe -t 5242000 -u 0x15A2,0x0073 -j -- fill-memory 0x20202004 4 0 word blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- configure-memory 9 0x20202000 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 1024 flexspiNorCfg.dat 9 blhost -t 2048000 -u 0x15A2,0x0073 -j -- flash-erase-region 0x60000000 0x8000 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 1024 flexspiNorCfg.dat 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- write-memory 0x60000000 evkmimxrt1060_iled_blinky_FCB.bin 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 0x8000 flexspiNorCfg.dat 9 Pic 2 is the comparison between the read data after programming and the original programming data. It can be seen that the FCB programmed at this time is exactly the same as the original code FCB. Pic 2 2.3 use 1bit FCB file to configure LUT    The used file cfg_fdcb_RTxxx_1bit_sdr_flashA.bin is copied from MCUBOOTUtility: \NXP-MCUBootUtility-3.4.0\src\targets\fdcb_model . The configuration of Option0 and Option1 is usually for chips that can support SFDP table, but some flash chips cannot support SFDP table. At this time, you need to fill in the flexSPI LUT for the full LUT manually. The so-called full LUT command is not only read commands, but also supports erasing, program, etc. In this way, the flexSPI interface can be successfully connected to the external FLASH, and the corresponding functions of reading, erasing, and writing can be realized. Therefore, the method in this chapter is to use a single-line command, which is also a command supported by general chips, to enable the corresponding function of flexSPI, so it can complete the subsequent APP code programming.   Pic 3     We can see: 03H is read, 05H is read status register, 06H is write enable, D8H is the block 64K erase, 02H is the page program, 60H is the chip erase. This is the 1bit SPI method full function LUT command, which can realize the chip read, write and erase function.     The command line is, source file is attached rt1060 cmd_fdcb_1bit_sdr_flashA.bat: elftosb.exe -f imx -V -c imx_application_gen.bd -o ivt_evkmimxrt1060_iled_blinky_FCB.bin evkmimxrt1060_iled_blinky.s19 sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- write-file 0x20208200 ivt_flashloader.bin sdphost.exe -t 50000 -u 0x1FC9,0x0135 -j -- jump-address 0x20208200 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 1 0 blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- get-property 24 0 blhost -t 5242000 -u 0x15A2,0x0073 -j -- write-memory 0x20202000 cfg_fdcb_RTxxx_1bit_sdr_flashA.bin blhost.exe -t 50000 -u 0x15A2,0x0073 -j -- configure-memory 9 0x20202000 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 1024 flexspiNorCfg.dat 9 blhost -t 2048000 -u 0x15A2,0x0073 -j -- flash-erase-region 0x60000000 0x8000 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 1024 flexspiNorCfg.dat 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- write-memory 0x60000000 evkmimxrt1060_iled_blinky_FCB.bin 9 blhost -t 5242000 -u 0x15A2,0x0073 -j -- read-memory 0x60000000 0x8000 flexspiNorCfg.dat 9 In the command line, where option0,1 was previously filled in, instead of filling in the data of option0,1, the 512-byte Bin file of the complete FCB LUT command is directly given, and then the configure-memory command is used to configure the flashloader’s FlexSPI LUT with the FCB file. so that it can support read and write erase commands, etc. The comparison between the flash data and the original APP data when burning and reading is in the Pic 4, we can see, the readout data from the flash is totally the same as the original APP FCB. Pic 4 3,SPT program reserve APP FCB The NXP officially released MCUXPresso Secure Provisional Tool can support the function of retaining the customer's FCB, but the SPT tool currently uses the APP FCB to fill in the flashloader FlexSPI FCB. Therefore, if the customer directly uses the old SDK demo which just contains the read command in the LUT to generate an APP with FCB, then use the SPT tool to burn the flash, and choose to keep the customer FCB in the tool, you will encounter the problem of erasing failure. In this case, analyze the reason, we can know the FCB on the customer APP side needs to fill in the full FCB LUT command, that is, including reading, writing, erasing, etc. The following shows how the old original SDK led_blinky generates an image with an FCB header and writes it in the SPT tool. As you can see in Pic 5, the tool has information that if you use APP FCB, you need to ensure that the FCB LUT contains the read, erase, program commands. Pic 6 shows the programming situation of APP FCB LUT only including read. It has failed when doing erase. The reason is that there is no erase, program and other commands in the FlexSPI LUT command, so it will fail when doing the corresponding erasing or programming.   Pic 5 Pic 6 Pic 7 If you look at the specific command, as shown in Pic 7, you can find that the SPT tool directly uses the FCB header extracted from the APP image to flash the LUT of the flashloader FlexSPI, so there will be no erase and write commands, and it will fail when erasing. The following is how to fill in the LUT in the FCB of the SDK, open evkmimxrt1060_flexspi_nor_config.c, and modify the FCB as follows: const flexspi_nor_config_t qspiflash_config = {     .memConfig =         {             .tag              = FLEXSPI_CFG_BLK_TAG,             .version          = FLEXSPI_CFG_BLK_VERSION,             .readSampleClksrc=kFlexSPIReadSampleClk_LoopbackFromDqsPad,             .csHoldTime       = 3u,             .csSetupTime      = 3u,             .sflashPadType    = kSerialFlash_4Pads,             .serialClkFreq    = kFlexSpiSerialClk_100MHz,             .sflashA1Size     = 8u * 1024u * 1024u,             .lookupTable =                 {                   // Read LUTs                   FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEB, RADDR_SDR, FLEXSPI_4PAD, 0x18),                   FLEXSPI_LUT_SEQ(DUMMY_SDR, FLEXSPI_4PAD, 0x06, READ_SDR, FLEXSPI_4PAD, 0x04),                   // Read status                   [4*1] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x05, READ_SDR, FLEXSPI_1PAD, 0x04),                   //write Enable                   [4*3] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x06, STOP, FLEXSPI_1PAD, 0),                   // Sector Erase byte LUTs                   [4*5] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x20, RADDR_SDR, FLEXSPI_1PAD, 0x18),                   // Block Erase 64Kbyte LUTs                   [4*8] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xD8, RADDR_SDR, FLEXSPI_1PAD, 0x18),                    //Page Program - single mode                   [4*9] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x02, RADDR_SDR, FLEXSPI_1PAD, 0x18),                   [4*9+1] = FLEXSPI_LUT_SEQ(WRITE_SDR, FLEXSPI_1PAD, 0x04, STOP, FLEXSPI_1PAD, 0x0),                   //Erase whole chip                   [4*11] =FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x60, STOP, FLEXSPI_1PAD, 0),                                       },         },     .pageSize           = 256u,     .sectorSize         = 4u * 1024u,     .blockSize          = 64u * 1024u,     .isUniformBlockSize = false, }; Please note, after the internal SDK team modification, from SDK_2_12_0_EVK-MIMXRT1060, the evkmimxrt1060_flexspi_nor_config.c already add LUT cmd to the full FCB LUT function. Use the above FCB to generate the APP, then use the SPT tool to burn the app with customer FCB again, we can see, the programming is working now. Pic 8 In summary, if you need to reserve the customer FCB, you can use the above method, but if you use the SPT tool, you need to add read, write, and erase commands to the LUT of the code FCB to ensure that flexSPI successfully operates the external flash.
View full article
RT1170 Octal flash enablement 1. Abstract The MIMXRT1170-EVK hardware can directly support two types of flash: QSPI flash IS25WP128 and Octal flash MX25UM51345GXDI00. QSPI flash is used by default, so the FCB of the related SDK and some IDE debugger download flash drivers are also default to the QSPI flash. In practical usage, some customers need to use Octal flash with RT1170, but after modifying the EVK hardware to Octal flash MX25UM51345GXDI00, they may encounter various issues, such as download issues, boot issues, debug issues, and when the flash is empty or there is a valid boot code in the flash, the download result is different and so on. This article will be based on NXP's official MIMXRT1170-EVK REV C1, modify the hardware onboard flash from QSPI flash to Octal flash MX25UM51345GXDI00, and modify the SDK project FCB, do ROM API test, do related tool download, do the debugger related flashloader modification and test with different IDE, so that customers who need it can refer to it. This article is not limited to EVK, but also applies to RT1170+Octal flash MX25UM51345GXDI00 with customer-defined board Pic 1 2. Hardware modification MIMXRT1170-EVK board modify flash to the octal flash, it needs to disconnect the QSPI flash pins, and connect the octal flash pins, the related modification points are: OPTION2: USE Octal Flash( Mount R381/R378/R382/R389/R402/R377/R388/R391, DNP R380/R399/R386/R390/R392/R385) Pic 2 The octal flash BOOT_CFG pin configuration are as follows: Pic 3 Pic 4 After modifying the hardware related resistors to choose the octal flash, SW1, SW2 should be configured to internal boot, and boot from octal flash, then it is controlled by the software part. 3. Octal flash APP FCB 3.1 Test SDK ROM API run from RAM To verify the board hardware can run from the octal flash, we can test the SDK attached fsl_romapi project: \SDK_2_12_0_MIMXRT1170-EVK\boards\evkmimxrt1170\driver_examples\fsl_romapi\cm7 Please note, can’t test the default project directly, as this project configuration is used by the QSPI flash, not the octal flash, if need to use the octal flash, customer need to modify the code at first, and add the GPIO to control the Flash_RST pin, which is used to reset the octal flash. The option0,1 value need to be modified to the octal flash values. 3.1.1 Octal flash option value     Pic 5 We can use the following option0 for testing, don’t need to configure the option1, as the octal flash is connected to the primary pin. option0= 0Xc0400007, option1 = 0 //query_pad =1, cmd_pad=1,133MHz option0= 0Xc0433007, option1 = 0 //query_pad =8, cmd_pad=8,133MHz option0= 0Xc0403007, option1 = 0 //query_pad =1, cmd_pad=8,133MHz 3.1.2 fsl_romapi project testing    The modified code for the ROM API project are as follows, before call ROM_FLEXSPI_NorFlash_GetConfig API, it needs to use the GPIO to reset the external octal flash at first, so, here add the Flash_RST=GPIO_AD_03=GPIO09_IO02 pin GPIO configuration. Pinmux.c related code:     gpio_pin_config_t gpio9_pinP15_config = { .direction = kGPIO_DigitalOutput, .outputLogic = 1U, .interruptMode = kGPIO_NoIntmode }; GPIO_PinInit(GPIO9, 02U, &gpio9_pinP15_config); IOMUXC_SetPinMux( IOMUXC_GPIO_AD_03_GPIO9_IO02, 0U); IOMUXC_SetPinConfig( IOMUXC_GPIO_AD_03_GPIO9_IO02,//OD,it is a workaround for EVK HW bug 0X12);     Flexspi_romapi.c added code:     static serial_nor_config_option_t option_1bit = { .option0.U = 0xc0400007U, .option1.U = 0U, }; static serial_nor_config_option_t option_8bit = { .option0.U = 0xc0433007, .option1.U = 0U, }; static serial_nor_config_option_t option_1_8bit = { .option0.U = 0xC0403007, .option1.U = 0U, }; GPIO_PinWrite(GPIO9, 02U, 0U); // Delay some time to reset external flash with Flash_RST pin for (uint32_t i = 0; i < 60000; i++) __asm volatile ("nop"); GPIO_PinWrite(GPIO9, 02U, 1U); status = ROM_FLEXSPI_NorFlash_GetConfig(FlexSpiInstance, &norConfig, &option_8bit); if (status == kStatus_Success) { PRINTF("\r\n Successfully get FLEXSPI NOR configuration block with option_8bit\r\n "); } else { status = ROM_FLEXSPI_NorFlash_GetConfig(FlexSpiInstance, &norConfig, &option_1_8bit); if (status == kStatus_Success) { PRINTF("\r\n Successfully get FLEXSPI NOR configuration block with option_1_8bit\r\n "); } else { status = ROM_FLEXSPI_NorFlash_GetConfig(FlexSpiInstance, &norConfig, &option_1bit); if (status == kStatus_Success) { PRINTF("\r\n Successfully get FLEXSPI NOR configuration block with option_1bit\r\n "); } else { PRINTF("\r\n Get FLEXSPI NOR configuration block failure!\r\n"); error_trap(); } } }     The test result is: Pic 6 Pic 7 From the test result, we can see, after using the GPIO to reset the external flash, the practical used option value is: option0= 0xc0403007, option1 = 0 //query_pad =1, cmd_pad=8,133MHz It can read the SFDP successfully, get the flash config data to the norConfig, then use these values to configure the flexSPI module, at last, it realizes the octal flash related address area erase-write-read-erase operation. From the above test result, it means, the modified hardware is totally working. Please note, as we can’t confirm the external flash hardware is working, so this project FCB is still the default for the QSPI flash, not the octal flash, then when testing this fsl_romapi project, it’s better to run it from RAM not the external flash. The following picture is how to run the project from the internal RAM, not download the flash directly: Pic 8    Here, for the configuration, we also have one point that needs to note, why configure the GPIO pin Flash_RST: GPIO_AD_03 as OD(open drain)?    It is caused by the current MIMXRT1170-EVK hardware having a bug, so this OD configuration is used as the workaround. Octal flash MX25UM51345GXDI00 power supply voltage is 1.8V, but the GPIO_AD_03 bank voltage is 3.3V, between these two modules, no voltage convert hardware, so it will have the following situation: a) Default GPIO_AD_03 is input mode, this pin has the internal PD(pull down) 35K resistor,  and the external PU(pull up) 10K resistor to the 1.8V, Flash_RST=1.8V*35K/(10K+35K)=1.4V, this voltage also can be used as the enable signal. To the normal boot, as the ROM didn’t control the octal flash Flash_RST pin, then this pin can be freely chose by any pin in the practical usage, so, the reset pin default is input, the voltage is 1.4V, it can enable the octal flash, no influence. b) When need to control the octal flash reset, then it needs to use the GPIO control GPIO_AD_03 pin, if want to output 0, it is OK. But if want to output high level, use the internal PULL resistor, it will output 3.3V to the Flash_RST pin, this voltage already higher than the octal flash 1.8V, and the octal flash datasheet defines the max voltage is 2V, although the flash chip has the voltage buffer, input 3.3V in short time, won’t damage the chip, but after long time working, the chip normal working can’t be guaranteed, this will cause the risk. So, to solve this issues, we can do some workaround in the flashloader, rom API, when output the Flash_RST pin to higher, we can use OD mode, then the detail pin voltage is totally determined by the external pull circuit, and the EVK also have the external 10K PU to 1.8V, so it can output 1.8V not the 3.3V. Pic 9   In the NXP new MIMXRT1170-EVKB board, the hardware adds the voltage convert chip to solve these issues, it can realize the 3.3V and 1.8V conversion: Pic 10 3.2 MCUBootUtility program octal flash We can use the MCUBootUtility to test MIMXRT1170-EVK+octal flash in serial download mode, normally for the chip connect, memory erase, read and program. This method also can use the tool to generated the correct FCB header for the octal flash, then can test the boot situation in the internal boot mode. Serial download-> SW1:1-OFF,2-OFF,3-OFF,4-ON Internal boot-> SW1:1-OFF,2-OFF,3-ON,4-OFF The MCUBootUtility configuration is: Pic 11 This configuration is: option0=0Xc0403007,query 1wire, cmd 8 wire. Then app image can use the MCUBootUtility attached code: NXP-MCUBootUtility-3.5.0\apps\NXP_MIMXRT1170-EVK_Rev.A\cm7\led_blinky_0x3000a000.srec Pic 12   We can see, the code downloading is finished, after this, reset device, configure the board as internal boot mode, then do the POR or the HW reset, we can see the on board LED D34 is blinking, it means the hardware also can boot from the octal flash. 3.3 SDK APP FDCB modification If you need to debug the SDK APP demo from octal flash, you must ensure that the app correct FDCB is provided, then how to modify the app FDCB to octal flash? You can refer to the FDCB which is burned by the MCUBootUtility tool and the datasheet of the octal flash. Here is the FDCB that has been tested for many times. The key point is to provide the correct LUT table. Taking the RT1170 SDK led_blinky project as an example, the evkmimxrt1170_flexspi_nor_config.c file in the project xip file is modified as follows:     const flexspi_nor_config_t octalflash_config = { .memConfig = { .tag = FLEXSPI_CFG_BLK_TAG, .version = FLEXSPI_CFG_BLK_VERSION, .readSampleClksrc=kFlexSPIReadSampleClk_ExternalInputFromDqsPad, .csHoldTime = 3, .csSetupTime = 3, .deviceModeCfgEnable = 1, .deviceModeType = kDeviceConfigCmdType_Spi2Xpi, .waitTimeCfgCommands = 1, .deviceModeSeq = { .seqNum = 1, .seqId = 6, /* See Lookup table for more details */ .reserved = 0, }, .deviceModeArg = 2, /* Enable OPI DDR mode */ .controllerMiscOption = (1u << kFlexSpiMiscOffset_SafeConfigFreqEnable) | (1u << kFlexSpiMiscOffset_DdrModeEnable), .deviceType = kFlexSpiDeviceType_SerialNOR, .sflashPadType = kSerialFlash_8Pads, .serialClkFreq = kFlexSpiSerialClk_133MHz, .sflashA1Size = 64ul * 1024u * 1024u, .dataValidTime = { [0] = {.time_100ps = 16}, }, .busyOffset = 0u, .busyBitPolarity = 0u, .lookupTable = { /* Read */// EEH+11H+32bit addr+20dummy cycles+ 4Bytes read data //133Mhz 20 dummy=10+10 [0 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0xEE, CMD_DDR, FLEXSPI_8PAD, 0x11),//0x871187ee, [0 + 1] = FLEXSPI_LUT_SEQ(RADDR_DDR, FLEXSPI_8PAD, 0x20, DUMMY_DDR, FLEXSPI_8PAD, 0x0A),//0xb30a8b20, [0 + 2] = FLEXSPI_LUT_SEQ(DUMMY_DDR, FLEXSPI_8PAD, 0x0A, READ_DDR, FLEXSPI_8PAD, 0x04),//0xa704b30a, /* Read Status SPI */// SPI 05h+ status data 0X24 maybe 0X04 [4*1 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR , FLEXSPI_1PAD, 0x05, READ_SDR, FLEXSPI_1PAD, 0x24),//0x24040405, /* Read Status OPI *///05H+FAH+ 4byte 00H(addr)+4Byte read [4*2 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x05, CMD_DDR, FLEXSPI_8PAD, 0xFA),//0x87fa8705, [4*2 + 1] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x00, CMD_DDR, FLEXSPI_8PAD, 0x00),//0x87008700, [4*2 + 2] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x00, CMD_DDR, FLEXSPI_8PAD, 0x00),//0x87008700, [4*2 + 3] = FLEXSPI_LUT_SEQ(READ_DDR , FLEXSPI_8PAD, 0x04, STOP_EXE, FLEXSPI_1PAD, 0x00),//0x0000a704, /* Write enable SPI *///06h [4*3 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR , FLEXSPI_1PAD, 0x06, STOP_EXE, FLEXSPI_1PAD, 0x00),//0x00000406, /* Write enable OPI *///06h+F9H [4*4 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x06, CMD_DDR, FLEXSPI_8PAD, 0xF9),//0x87f98706, /* Erase sector */ //21H+DEH + 32bit address [4*5 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x21, CMD_DDR, FLEXSPI_8PAD, 0xDE),//0x87de8721, [4*5 + 1] = FLEXSPI_LUT_SEQ(RADDR_DDR , FLEXSPI_8PAD, 0x20, STOP_EXE, FLEXSPI_1PAD, 0x00),//0x00008b20, /*Write Configuration Register 2 =01, Enable OPI DDR mode*/ //72H +32bit address + CR20x00000000 = 0x01 [4*6 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR , FLEXSPI_1PAD, 0x72, CMD_SDR, FLEXSPI_1PAD, 0x00),//0x04000472, [4*6 + 1] = FLEXSPI_LUT_SEQ(CMD_SDR , FLEXSPI_1PAD, 0x00, CMD_SDR, FLEXSPI_1PAD, 0x00),//0x04000400, [4*6 + 2] = FLEXSPI_LUT_SEQ(CMD_SDR , FLEXSPI_1PAD, 0x00, WRITE_SDR, FLEXSPI_1PAD, 0x01),//0x20010400, /*block erase*/ //DCH+23H+32bit address [4*8 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0xDC, CMD_DDR, FLEXSPI_8PAD, 0x23),//0x872387dc, [4*8 + 1] = FLEXSPI_LUT_SEQ(RADDR_DDR, FLEXSPI_8PAD, 0x20, STOP_EXE, FLEXSPI_1PAD, 0x00),//0x00008b20, /*page program*/ //12H+EDH+32bit address+ write data 4bytes [4*9 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x12, CMD_DDR, FLEXSPI_8PAD, 0xED),//0x87ed8712, [4*9 + 1] = FLEXSPI_LUT_SEQ(RADDR_DDR, FLEXSPI_8PAD, 0x20, WRITE_DDR, FLEXSPI_8PAD, 0x04),//0xa3048b20, /* Chip Erase (CE) Sequence *///60H+9FH [4*11 + 0] = FLEXSPI_LUT_SEQ(CMD_DDR , FLEXSPI_8PAD, 0x60, CMD_DDR, FLEXSPI_8PAD, 0x9F),//0x879f8760, }, }, .pageSize = 256u, .sectorSize = 4u * 1024u, .blockSize = 64u * 1024u, .isUniformBlockSize = false, };     The LUT here is the full function LUT table, it includes: 8 wire read, 1/8 wire status read, 1/8 wire write enable, 8 wire sector erase, 1 wire write configuration enable for OPI DDR mode, 8 wire block erase, 8 wire page program, 8 wire chip erase. The detail command is the same as the MX25UM51345GXDI00 datasheet, and also the same as the MCUBootUtility tool generated FCB. 4. CMSIS DAP Flashloader MIMXRT1170-EVK default use the CMSIS DAP debugger, take the MCUXPresso IDE as an example, it will call the flashloader named as .cfx file, flashloader source code can be found from this path: C:\nxp\MCUXpressoIDE_11.6.0_8187\ide\Examples\Flashdrivers\NXP\iMXRT\ iMXRT117x_FlexSPI_SFDP.zip The exist .cfx file which can be used directly, the path is: C:\nxp\MCUXpressoIDE_11.6.0_8187\ide\binaries\Flash\ MIMXRT1170_SFDP_QSPI.cfx:  QSPI flash MIMXRT1170_SFDP_MXIC_OPI.cfx: octal flash Pic 13 When use flashloader + CMSIS DAP + MCUXpresso debug result is: Pic 14 One point need to note, mcuxpresso IDE flashloader source code iMXRT117x_FlexSPI_SFDP.zip, the project configured to the octal flash, the related Flash_RST control code need to be modified, otherwise, when it output high, the voltage will be 3.3V. Pic 15 In the above picture, add code: MEM_WriteU32(0x400E835CU, 0x12); Which is SW_PAD_CTL_PAD_GPIO_AD_03 register = 0x12, OD mode, then generate the mxic MX25UM51345GXDI00 octal flash .cfx file again, which is used for the mcuxpresso+CMSIS DAP debugger. 5. JLINK Flashloader with RT-UFL In actual use, many customers not only use the on-board CMSIS-DAP debugger, but also like to use external JLINK/JLINK plus, or use the on-board JLINK firmware (use LPCScrypt modify firmware, pay attention to update the JINK firmware according to the instructions on the webpage), or use the external JLINK firmware (need to disconnect the onboard debugger jumper). But if the JLINK flash driver is called directly, it will be QSPI flash. Here is how to use the flash driver of the octal flash in JLINK. Now the JLINK driver uses JLinkARM.dll to define the flash used by different chips, unlike the old JLINK driver. The firmware of the flash is called by JLinkDevices.xml. The .dll file cannot allow users to directly modify the corresponding flash of the device, so it is necessary to provide a flash driver file that supports RT1170 octal flash, and add a calling command in JLinkDevices.xml to override the default QSPI definition in JLinkARM.dll. NXP AE has developed a very useful full-function flash driver called RT-UFL, which can support general QSPI, hyperflash, octaflash, etc. Users can use JLINK to call RT-UFL flash driver, and then use JFLASH, JLINK commander, or IDE (MCUXpresso, IAR, MDK) to realize the debugging and downloading of RT chips combined with different flashes RT-UFL download link: https://github.com/JayHeng/RT-UFL More detail usage of RT-UFL, please check this blog link:   https://www.cnblogs.com/henjay724/ After downloading, install the RT-UFL to the JLINK driver, copy the following folder file: RT-UFL-1.0\algo\SEGGER\JLink_Vxxx to the JLINK driver install path: C:\Program Files\SEGGER\JLINKV768B The JLINK driver link is: https://www.segger.com/downloads/jlink/JLink_Windows_x86_64.exe Now, use the original RT-UFL firmware combined with JFLASH to test the octal flash in RT1170 directly, and the debugger is JLINK plus, just to check whether it can be run, device selection: MIMXRT1170_UFL_L0. _L0 suffix algorithm is suitable for QSPI Flash and Octal Flash (Page size is 256 Bytes, Sector size is 4KB), _L1/2 suffix algorithm is suitable for Hyper Flash (Page size is 512 Bytes, Sector size is 4KB/64KB). 5.1 RT-UFL JFlash Test Generate a .srec file for the led_blinky project which FCB has been modified to octal flash before, it will be used by JFLASH or JLINK commander later. Use JFLASH combined with JLINK plus to create a new JFLASH project. The chip is selected as MIMXRT1170_UFL_L0 which can support octal flash. The test situation is as follows, you can see that the connect can be successful, and the ARM CortexM7 core can be found, but the programming, reading, and erasing functions will fail. It can be said that the connection to the external octal flash is not successful at all: Pic 16 If the used JLINK is not the JLINK plus, due to the license can’t support the JFLASH, then customer can use the JLINK commander to test it, but here, the test result with the original RT-UFL is totally the same as the JFLASH: Pic 17 It can still meet the issues of “Failed to initialize RAMCode”, even use the mem32 readout the address data, sometimes, the data is not correct, not the real flash data, customer can compare the memory which the data which is readout from the MCUBootUtility. So, the RT-UFL flashdriver code need to be modified to the octal flash, to let the octal flash works. 5.2 RT-UFL Flashloader source code modification     From the analysis of the original RT-UFL combined with the octal flash test, after many modifications and tests, the modification points are listed one by one, the new flashloader file generated by the modified RT-UFL is tested using JFlash, JLINK commander, IDE, etc. JLINK tools are divided into external JLINK plus and onboard JLINK firmware (JFLASH is not supported). 5.2.1 Flashloader modification points 1) RAMCode errors In the JLinkDevices.xml file, define the RAM location to the OCRAM address:     <Device> <ChipInfo Vendor="NXP" Name="MIMXRT1170_UFL_octalFlash" WorkRAMAddr="0x20240000" WorkRAMSize="0x00040000" Core="JLINK_CORE_CORTEX_M7" JLinkScriptFile="Devices/NXP/iMXRT_UFL/iMXRT117x_CortexM7.JLinkScript" Aliases="MIMXRT1176xxx8_M7; MIMXRT1176xxxA_M7" /> <FlashBankInfo Name="Octal Flash" BaseAddr="0x30000000" MaxSize="0x01000000" Loader="Devices/NXP/iMXRT_UFL/MIMXRT_FLEXSPI_UV5_UFL.FLM" LoaderType="FLASH_ALGO_TYPE_OPEN" /> </Device>     2) Add erase sector ROM API The JLINK calls the erase sector, so add the related sector erase API: ufl_main.c     static void ufl_fill_flash_api(void) { ... case kChipId_RT117x: uflTargetDesc->flashDriver.init = g_bootloaderTree_imxrt117x->flexspiNorDriver->init; uflTargetDesc->flashDriver.page_program= g_bootloaderTree_imxrt117x->flexspiNorDriver->page_program; uflTargetDesc->isFlashPageProgram = true; uflTargetDesc->flashDriver.erase_all = g_bootloaderTree_imxrt117x->flexspiNorDriver->erase_all; uflTargetDesc->flashDriver.erase = g_bootloaderTree_imxrt117x->flexspiNorDriver->erase; uflTargetDesc->flashDriver.erase_sector= g_bootloaderTree_imxrt117x->flexspiNorDriver->erase_sector;//kerry add uflTargetDesc->flashDriver.read = g_bootloaderTree_imxrt117x->flexspiNorDriver->read; uflTargetDesc->flashDriver.set_clock_source = NULL; uflTargetDesc->flashDriver.get_config= g_bootloaderTree_imxrt117x->flexspiNorDriver->get_config; uflTargetDesc->iarCfg.enablePageSizeOverride = true; break; … }     ufl_flexspi_nor_flash_imxrt117x.h     typedef struct _flexspi_nor_flash_driver_imxrt117x { uint32_t version; status_t (*init)(uint32_t instance, flexspi_nor_config_t *config); status_t (*page_program)(uint32_t instance, flexspi_nor_config_t *config, uint32_t dst_addr, const uint32_t *src); status_t (*erase_all)(uint32_t instance, flexspi_nor_config_t *config); status_t (*erase)(uint32_t instance, flexspi_nor_config_t *config, uint32_t start, uint32_t lengthInBytes); status_t (*read)(uint32_t instance, flexspi_nor_config_t *config, uint32_t *dst, uint32_t addr, uint32_t lengthInBytes); void (*clear_cache)(uint32_t instance); status_t (*xfer)(uint32_t instance, flexspi_xfer_t *xfer); status_t (*update_lut)(uint32_t instance, uint32_t seqIndex, const uint32_t *lutBase, uint32_t seqNumber); status_t (*get_config)(uint32_t instance, flexspi_nor_config_t *config, serial_nor_config_option_t *option); status_t (*erase_sector)(uint32_t instance, flexspi_nor_config_t *config, uint32_t address);//kerry add status_t (*erase_block)(uint32_t instance, flexspi_nor_config_t *config, uint32_t address); const uint32_t reserved0; status_t (*wait_busy)(uint32_t instance, flexspi_nor_config_t *config, bool isParallelMode, uint32_t address); const uint32_t reserved1[2]; } flexspi_nor_flash_driver_imxrt117x_t;     3) Speed up the erase and program speed FlashDev.c     struct FlashDevice const FlashDevice = { FLASH_DRV_VERS, // Driver Version, do not modify! "MIMXRT_FLEXSPI_RT1170", // Device Name EXTSPI, // Device Type 0x30000000, // Device Start Address 0x01000000, // Device Size in Bytes (16mB) 256*4, // Programming Page Size 0, // Reserved, must be 0 0xFF, // Initial Content of Erased Memory 100, // Program Page Timeout 100 mSec 15000, // Erase Sector Timeout 15000 mSec // Specify Size and Address of Sectors 4096*8, 0x00000000, // Sector Size 4kB (256 Sectors) SECTOR_END };       FlashPrg.c:     int EraseSector (unsigned long adr) { uint32_t instance = g_uflTargetDesc.flexspiInstance; uint32_t baseAddr = g_uflTargetDesc.flashBaseAddr; /*Erase Sector*/ status_t status = flexspi_nor_flash_erase(instance, (void *)&flashConfig, adr - baseAddr, FLASH_DRV_SECTOR_SIZE*8);//kerry *8, 4096 if (status != kStatus_Success) { return (1); } else { return (0); } } int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) { status_t status = kStatus_Success; uint32_t instance = g_uflTargetDesc.flexspiInstance; uint32_t baseAddr = g_uflTargetDesc.flashBaseAddr; uint32_t loadaddr = adr - baseAddr; unsigned char *buffer; buffer = buf; int i; for(i = 0; i < 4; i ++) // kerry add 256*4 { status = flexspi_nor_flash_page_program(instance, (void *)&flashConfig, loadaddr, (uint32_t *)buffer); if (status != kStatus_Success) { return (1); } buffer+=256; loadaddr+=256; } return (0); }     The principle is to reduce the times it takes for the PC to send commands to JLINK and then send to the board, now, one command can directly erase and program multiple blocks. 4) Octal Flash option value polling It should be noted that after Flash Reset, or the first programming, it is necessary to read SFDP in a single-line manner. If it is not reset and there is a valid FCB in the flash, the flash is initialized to OPT mode and needs to be read in 8-line mode. At this time, the valid SFDP table of the flash chip cannot be read in the single-line mode. RT-UFL is a flashloader that supports multiple chips, and it does not use specific GPIO as the chip flash_RST. For RT-UFL, GPIO is not added to control flash_RST pin, and a large degree of freedom is reserved. Otherwise, once the customer uses the RST pins that are different from EVK still have problems, and even require customers to spend time modifying the flashloader source code, increasing development time. Therefore, in view of the above considerations, modify the code here, do not add RESET signal control, do not fix option value for single-line or 8-line, but polling the option with single-line and 8-line to read SPDF. ufl_main.c     static void ufl_set_target_property(void) case kChipId_RT117x: uflTargetDesc->flexspiInstance = MIMXRT117X_1st_FLEXSPI_INSTANCE; uflTargetDesc->flexspiBaseAddr = MIMXRT117X_1st_FLEXSPI_BASE; uflTargetDesc->flashBaseAddr = MIMXRT117X_1st_FLEXSPI_AMBA_BASE; // uflTargetDesc->configOption.option0.U = 0xc0433007; // uflTargetDesc->configOption.option1.U = 0x0; break;     Make sure that the above option are not configured, otherwise the option configuration will be fixed and the polling option function will no longer be enabled. ufl_auto_probe_flash.c     static const serial_nor_config_option_t s_flashConfigOpt[] = { // 1st Pinmux, PortA for octal 1 bit SFDP for no FCB in flash eg. MX25UM51345G {.option0.U = 0xc0403007, .option1.U = 0x00000000}, // 1st Pinmux, PortA for octal 8 bit SFDP for FCB in flash eg. MX25UM51345G {.option0.U = 0xc0433007, .option1.U = 0x00000000}, // 1st Pinmux, PortA for octal 1 bit SFDP &1 bit CMD for no FCB in flash eg. MX25UM51345G {.option0.U = 0xc0400007, .option1.U = 0x00000000}, ..}     After the above modifications, compile the source code project of RT-UFL: RT-UFL-1.0\build\mdk\MIMXRT_FLEXSPI_UV5.uvprojx, Generate a new MIMXRT_FLEXSPI_UV5_UFL.FLM programming algorithm and copy it to the following path: C:\Program Files\SEGGER\JLINKV768B\Devices\NXP\iMXRT_UFL The device name defined in JLinkDevices.xml is: MIMXRT1170_UFL_octalFlash. JLinkDevices.xml path: C:\Program Files\SEGGER\JLINKV768B modify the .xml, and add the above-mentioned "RAMCode error" section. After the modification is completed, refresh the JLinkDLLUpdater.exe file, so that several IDEs can synchronize the firmware defined by the updated xml file. 5.2.2 JFlash Test As can be seen from the test results of Jflash below, it can be successfully erased, and the app image can be downloaded to octal flash. After the download is successful, reset it, and you can see the onboard led is flashing. It shows that the modified RT-UFL flashloader has worked. It should be noted here that the use of JFLASH requires the use of an external Segger JLINK Plus. Some customers use normal JLINK or RT EVK onboard JLINK firmware, then they can try the JLINK commander method. Pic 18 5.2.3 JLINK command Test Use the JLINK plus associated with JLINK commander test result is: Pic 19 You can see that the firmware can be downloaded successfully. Now uses the EVK onboard JLINK firmware to test as follows, it can be seen that the programming is normal, so if users don’t have external JLINK can also directly use the RT EVK onboard JLINK firmware. One thing need to pay attention to is when using the onboard JLINK firmware, the firmware will cause the debugger port USB to not directly supply power to the RT chip, so it needs to be configured that J38 is connected to 3-4, and then find another USB cable to connect J20 to supply power to the board. Pic 20 5.3 MCUXpresso + JLINK +Modified RT-UFL Testing At first, select the MCUXPresso IDE JLINK debug path, add the JLINK driver path which is already added RT-UFL firmware, windows->preferences, then the path should like this: Pic 21 When downloading, still need to configure RUN->Debugger configurations, the JLINK configuration should be: Pic 22 Please note, don’t check the item “Reset before running” in the debug configuration, as this item is checked in default. Pic 23 If checked “Reset before running”, when debug it, the code will be blocked after downloading the code, and can’t jump to the main function. If customer click halt button, it will meet the issues that the code is stop at 0x223104, but after exit the debug mode, and do the POR again, you will find the flash already downloaded with the app successfully. Pic 24 This problem is related to the impact of RT1170 security policy on JLINK. For details, please refer to the following link: https://www.cnblogs.com/henjay724/p/15725966.html When JLink is connected to the chip, as long as the reset command is executed, it will directly enter the safe debugging mode (the PC stops at 0x223104). Therefore, make sure that "Reset before running" is not checked, so that you can enter the debug and main functions normally, and the test results are as follows: Pic 25 5.4  MDK+JLINK+Modified RT-UFLTesting Next, use the MCUXPresso CFG tool combined with the SDK package to export an MDK project, also based on the led_blinky project, and modify the FCB code for Octal flash, and then call the modified RT-UFL flashloader, the device name is: MIMXRT1170_UFL_octalFlash. Note, be sure to refresh: C:\Program Files\SEGGER\JLINKV768B\JLinkDLLUpdater.exe Make sure the IDE is using the latest firmware link. The following is a specific MDK project related configuration pictures: Pic 26 The project is selected as flexspi_nor_debug, and after compiling, the debug tool is configured as JLINK, the JLINK simulation sequence can be found, and the updated target before debugging in utilities should not be checked: Pic 27 Pic 28 Pic 29 Modify JlinkSettings.ini,configure override =1, device as the RT-UFL modified firmware device name: MIMXRT1170_UFL_octalFlash. Pic 30 Pic 31 As can be seen from the above picture, the modified RT-UFL Octal flash has been successfully used to run the MDK project. It should be noted that do not use the download button, because this button cannot use the overwritten and modified RT-UFL programming algorithm, it will still call the programming algorithm of the deleted area of ​​the interface, and an error will be reported if it cannot be found. 5.5 IAR + JLINK + Modified RT-UFL Testing Here is the use of IAR combined with JLINK to debug RT1170 octal flash, using the modified RT-UFL programming algorithm. The specific configuration is as follows: Pic 32 Don’t check “use flash loaders”, it means don’t use the IAR attached .out download algorithm, and use the JLINK driver’s modified RT-UFL octal flash flashdriver. Pic 33 Reset can choose core, if it is normal, debug will meet the same issues with the MCUXPresso which checked reset item, PC will stop to 0x223104. Pic 34 Here, modify project settings folder ->.jlink file, use the RT-UFL device name: MIMXRT1170_UFL_octalFlash, And override =1, then it will call the modified RT-UFL flashloader. If you can’t find the .jlink in the new created project, just select the JLINK debugger, click download at first, then it will generate the .jlink file, then modify it and debug it again. Pic 35 After modify the RT-UFL program algorithm to the octal flash, click “download and debug” button, it will enter the debug mode, in the following picture, the code is running successfully: Pic 36 6. Conclusion After the above details, the code download of the MIMXRT1170-EVK on-board octalflash can be realized, and the fsl_romspi project is used to run in RAM, which can verify the normal reading and writing of the hardware octalflash, and MCUBootutility to verify the programming and boot conditions. The modification of APP FCB is matched octal flash. The debugger uses JLINK or CMSIS DAP, and the correct flashdriver programming algorithm needs to be used. In particular, JLINK needs to use the RT-UFL as flashloader, but the source code needs to be modified. Finally, you can see that the combination of RT-UFL download algorithm and JLINK, successfully realize the download and operation of octal flash code on MCUXpresso, IAR, MDK three IDEs. This article is not limited to MIMXRT1170-EVK, but also applies to customer design boards using RT1170+ MX25UM51345GXDI00 octal flash. The attachment adds the modified RT-UFL programming algorithm and the octal flash project of the three major IDEs.
View full article
This guide will walk through how to do connect the camera and LCD modules to i.MX RT boards and how to test to ensure the camera and LCD are connected properly. Update May 2022: There are now updated versions of these LCD panels that have an impact on software. See this post for more details. The physical connections are the same for both the original and new panels however so there are no changes to this guide.   This first part of this guide is for the i.MX RT1050, i.MX RT1060, i.MX RT1064 EVKs. The second part of this guide is for i.MX RT595, i.MX RT1160 and i.MX RT1170 EVKs.      Part 1: Camera and LCD for i.MX RT1050, i.MX RT1060, and i.MX RT1064:  The camera used by the RT1050, RT1060, and R1064 EVKs are the same. However this camera only comes with the RT1060 and RT1064 EVKs. There are alternatives available for the RT1050 as discussed in this blog post.    The LCD screen compatible with these boards is the RK043FN66HS-CTG    Camera:  1) The camera connector is on the front of the board. Flip the black connector up so it's 90 degrees from its original position.  2) Then slide in the flat ribbon connector of the camera 3) Flip the black connector back down. It should keep the ribbon cable snug.   LCD: 1) On the back of the board, slide the black connector for the LCD ribbon forward. 2) Then slide in the flat LCD ribbon cable underneath the black connector. 3) Slide the black connector back to its original position. The cable should be snug. 4) Do the same for the touch controller connector and slide the black connector forward 4)Then insert the cable between the black connector and the white top so that the cable is in the middle. It might take a few tries as its somewhat difficult. You could also use needle nose pliers to help guide in the cable but be careful about damaging the cable. 5) Then slide the black connector back to the original position. The cable should be snug. 6) It should look like the following when complete.   Testing: 1) To test the camera and LCD, use the CSI driver examples in the MCUXpresso SDK.  2) The camera will likely be out of focus the first time you use it. Adjust it by rotating the lens clockwise until the image is in focus. You can use your fingers or some needle nose pliers. It could take up to two rotations and it should turn easily. Also remove the plastic cover.    3) To test the touch controller, use the emwin temperature control example in the MCUXpresso SDK   Tape: 1) Once the LCD has been confirmed to work, you can use two layers of thick double sided foam tape to securely attach it to the board.      Part 2: Camera and LCD for i.MX RT1160 and i.MX RT1170 EVKs:  The i.MX RT1160 and i.MX RT1170 EVKs both come with a OV5640 MIPI camera module in the box.    The LCD screen compatible with the i.MX RT1160 and i.MX RT1170-EVK is the RK055HDMIPI4MA0 and it can be found here.   i.MX RT1170-EVK Camera:  1) The camera connector is on the front of the board at J2. It connects by simply pressing the camera down onto the connector. It takes a bit of force but should not be too difficult.    i.MX RT1170-EVK LCD: 1) On the back of the board, slide the black connector (J40) for the LCD ribbon forward towards the edge of the board.    2) Then carefully slide in the flat LCD ribbon cable into the connector. The blue writing should be facing up like in the photo. It should go above the black part of the connector that you just slid out, and under the white part of the connector.  3) Slide the black plastic connector back to its original position. The cable should be snug if pulled. It should look like the following:    i.MX RT1170-EVK Power: 1) If using the LCD, then the external power adapter must be used with the board. Connect the barrel connector to J43 on the board. 2) Also change the jumper on J38 to be on pins 1-2 so that it uses the external power.  3) Connect a micro-USB cable to J11, which will cause the board to enumerate as a COM port and as a debug interface for downloading and debugging code   i.MX RT1170-EVK Camera and LCD Testing: 1) To test the camera and LCD, use the csi_mipi_rgb_cm7 driver example that can be found in the MCUXpresso SDK for i.MX RT1170. The camera input should be displayed on the LCD screen if everything is connected properly.
View full article
Face recognition Actually, face recognition technology is used in many scenes in our daily life, for instance, when taking pictures with the mobile phone, the camera software will automatically recognize the faces in the lens and focus, scan face for real-name verification when registering the App and scan face for pay, etc. The basic steps of face recognition are shown in the below figure. Firstly, the camera captures image data, then through preprocessing such as noise elimination and image format conversion, the image data will be transmitted to the processor for face detection and recognition calculations. After recognizing the face successful, continue to do the follow-up operations. Fig1 The basic steps of face recognition i.MX RT106F MCU based solution for face recognition The below figure is the block diagram of i.MX RT106F MCU-based solution for face recognition provided by the NXP. Comparing with the general processor (CPU) solution, it has comparative advantages in cost and power consumption. Further, the PCB size will be smaller too and the MCU usually can boot up within a few hundred milliseconds even with RTOS, versus to the boot-up speed of the processor (CPU) equipped with a Linux system that is about 10 seconds, it will give customers a better user experience. Fig2 i.MX RT106F MCU based solution for face recognition Of course, the i.MX RT106F MCU-based solution face recognition solution is not intended to replace the solution based on the processor (CPU). As aforementioned, face recognition technology has a lot of application cases, and it will definitely be used in more fields in the future, so the MCU-based face recognition solution provides customers and the market with another choice. i.MX RT106F MCU The i.MX RT106F face recognition crossover processor is an EdgeReady™ solution-specific variant of the i.MX RT1060 family of crossover processors, targeting face recognition applications. It features NXP’s advanced implementation of the Arm Cortex®-M7 core, which operates at speeds up to 600 MHz to provide high CPU performance and the best real-time response. i.MX RT106F based solutions enable system designers to easily and inexpensively add face recognition capabilities to a wide variety of smart appliances, smart homes, smart retail, and smart industrial devices. The i.MX RT106F is licensed to run the OASIS Lite library for face recognition (as the below figure shows) which include: Face detection Anti-spoofing Face tracking Face alignment Glass detection Face recognition Confidence measure Face recognition quantified results, etc Fig3 OASIS Recognition Software Pipeline sln_viznas_iot_elock_oobe The sln_viznas_iot_elock_oobe project is the application on the SLN-VIZNAS-IOT (as the below figure shows, regarding the Bootstrap and Bootloader in the software flowchart, I will introduce them in the future). The following development work is based on the sln_viznas_iot_elock_oobe project, however, I need to sketch the basic workflow of it prior to starting real development work. Fig4 SLN-VIZNAS-IOT software flowchart sln_viznas_iot_elock_oobe's workflow flow In the Camera_Start() function, the task (Camera_Init_Task) completes the initialization of the RGB and IR cameras, then creates a task (Camera_Task); In the Display_Start() function, after the task (Display_Init_Task) completes the initialization of the display medium (USB or LCD), it immediately creates the task (Display_Task) and sends the message queue s_DisplayReqMsg.id = QMSG_DISPLAY_FRAME_REQ to the task (Camera_Task), then the pDispData will point to the s_BufferLcd[0] array for storing the image data to be displayed; In the Oasis_Start() function, firstly, OASISLT_init() completes the initialization of the OAISIT library, then creates a task (Oasis_Task) to send the message queues gFaceDetReqMsg.id = QMSG_FACEREC_FRAME_REQ and gFaceInfoMsg.id = QMSG_FACEREC_INFO_UPDATE to the task (Camera_Task) to make the pDetIR and pDetRGB point to the face block diagram captured by the RGB and IR cameras, and update the content pointed by infoMsgIn. After the camera is initialized, the RGB camera works at first. After the image data is captured, an interrupt is triggered and the callback function Camera_Callback() sends the message queue DQMsg.id = QMSG_CAMERA_DQ to the task (Camera_Task), and DQIndex++; CAMERA_RECEIVER_GetFullBuffer() extracts the image data captured by the RGB camera, and sends the message queue DPxpMsg.id = QMSG_PXP_DISPLAY to the task (PXP_Task) created in the APP_PXP_Start() function and EQIndex++, meanwhile switch the camera from RGB to IR. After the APP_PXPStartCamera2Display() function in the task (PXP_Task) completes processing, it sends the message queue s_DResMsg.id = QMSG_PXP_DISPLAY to the task (Camera_Task), and the task (Camera_Task) sends the message queue DresMsg.id = QMSG_DISPLAY_FRAME_RES to the task (Display_Task) after receiving the above message queue. The task (Display_Task) completes display, then it sends the message queue s_DisplayReqMsg.id = QMSG_DISPLAY_FRAME_REQ to the task (Camera_Task) to make pDispData point to the s_BufferLcd[1] array; After the IR camera completes capturing work, CAMERA_RECEIVER_GetFullBuffer() extracts the image data and sends the message queue DPxpMsg.id = QMSG_PXP_DISPLAY to the (PXP_Task) task created in the APP_PXP_Start() function, continue to execute EQIndex++ and switch to RGB camera again, and repeat the steps 5. Finally, send the message queue FPxpMsg.id = QMSG_PXP_FACEREC to the task (PXP_Task) and set irReady = true. After the task (PXP_Task) receives the above message queue, it calls APP_PXPStartCamera2DetBuf() and after completes the processing, sends the message queue s_FResMsg.id = QMSG_PXP_FACEREC to the task (Camera_Task); CAMERA_RECEIVER_GetFullBuffer() extracts the image data collected by the RGB camera, repeat step 5, when (pDetRGB && irReady) condition is met, send the message queue FPxpMsg.id = QMSG_PXP_FACEREC to the task (PXP_Task) and set irReady = false, pDetRGB = NULL, pDetIR = NULL. After the task (PXP_Task) receives the above message queue, it calls APP_PXPStartCamera2DetBuf() and after completes the processing, sends the message queue s_FResMsg.id = QMSG_PXP_FACEREC to the task (Camera_Task). At this time, the (!pDetIR && !pDetRGB) condition is met and the Queue message FResMsg.id = QMSG_FACEREC_FRAME_RES is sent to the task (Oasis_Task), run OASISLT_run_extend to perform face recognition calculation, and send the message queue gFaceDetReqMsg.id = QMSG_FACEREC_FRAME_REQ to the task (Camera_Task) to make the pDetIR and pDetRGB point to the face block diagram captured by the RGB and IR cameras again. keep repeat steps 6 and 7; Fig5 sln_viznas_iot_elock_oobe's workflow flow Smart Coffee machine Fig 6 is the workflow of the smart coffee machine that I want to develop for, as there is no LCD board on hand, in the below development process, I will select Win10's camera (as the below figure shows) to output the captured image, further, take advantage of the Shell command to simulate the LCD's touch feature to interact with the board.   Fig6 workflow of the smart coffee machine Fig7 Camera Code modification In the commondef.h, add a new member variable 'uint16_t coffee_taste' in Union FeatureItem to stand for the favorite coffee taste; typedef union { struct { /*put char/unsigned char together to avoid padding*/ unsigned char magic; char name[FEATUREDATA_NAME_MAX_LEN]; int index; // this id identify a feature uniquely,we should use it as a handler for feature add/del/update/rename uint16_t id; uint16_t pad; // Add a new component uint16_t coffee_taste; /*put feature in the last so, we can take it as dynamic, size limitation: * (FEATUREDATA_FLASH_PAGE_SIZE * 2 - 1 - FEATUREDATA_NAME_MAX_LEN - 4 - 4 -2)/4*/ float feature[0]; }; unsigned char raw[FEATUREDATA_FLASH_PAGE_SIZE * 2]; } FeatureItem; // 1kB   In featuredb.h, add two member functions into class FeatureDB:  set_taste()  and  get_taste() , and add the definition of the above two member functions in featuredb.cpp; class FeatureDB { public: FeatureDB(); ~FeatureDB(); int add_feature(uint16_t id, const std::string name, float *feature); int update_feature(uint16_t id, const std::string name, float *feature); int del_feature(uint16_t id, std::string name); int del_feature(const std::string name); int del_feature_all(); std::vector<std::string> get_names(); int get_name(uint16_t id, std::string &name); std::vector<uint16_t> get_ids(); int ren_name(const std::string oldname, const std::string newname); int feature_count(); int get_free(int &index); int database_save(int count); int get_feature(uint16_t id, float *feature); void set_autosave(bool auto_save); bool get_autosave(); //Add two customize member functions int set_taste(const std::string username, uint16_t taste_number); int get_taste(const std::string username); private: bool auto_save; int load_feature(); int erase_feature(int index); int save_feature(int index = 0); int reassign_feature(); int get_free_mapmagic(); int get_remain_map(); }; int FeatureDB::set_taste(const std::string username, uint16_t taste_number) { int index = FEATUREDATA_MAX_COUNT; for (int i = 0; i < FEATUREDATA_MAX_COUNT; i++) { if (s_FeatureData.item[i].magic == FEATUREDATA_MAGIC_VALID) { if (!strcmp(username.c_str(), s_FeatureData.item[i].name)) { index = i; } } } if (index != FEATUREDATA_MAX_COUNT) { s_FeatureData.item[index].coffee_taste = taste_number; return 0; } else { return -1; } } int FeatureDB::get_taste(const std::string username) { int index = FEATUREDATA_MAX_COUNT; int taste_number; for (int i = 0; i < FEATUREDATA_MAX_COUNT; i++) { if (s_FeatureData.item[i].magic == FEATUREDATA_MAGIC_VALID) { if (!strcmp(username.c_str(), s_FeatureData.item[i].name)) { index = i; } } } if (index != FEATUREDATA_MAX_COUNT) { taste_number = s_FeatureData.item[index].coffee_taste; return taste_number; } else { return -1; } }   In database.h, add the declarations of  DB_Set_Taste()  and  DB_Get_Taste()  functions, and in database.cpp, add the related codes of the above two functions. These two functions are equivalent to encapsulating the newly added member functions set_taste() and get_taste() of the FeatureDB class; int DB_Del(uint16_t id, std::string name); int DB_Del(string name); int DB_DelAll(); int DB_Ren(const std::string oldname, const std::string newname); int DB_GetFree(int &index); int DB_GetNames(std::vector<std::string> *names); int DB_Count(int *count); int DB_Save(int count); int DB_GetFeature(uint16_t id, float *feature); int DB_Add(uint16_t id, float *feature); int DB_Add(uint16_t id, std::string name, float *feature); int DB_Update(uint16_t id, float *feature); int DB_GetIDs(std::vector<uint16_t> &ids); int DB_GetName(uint16_t id, std::string &names); int DB_GenID(uint16_t *id); int DB_SetAutoSave(bool auto_save); // Add two customize functions int DB_Set_Taste(const std::string username, const uint16_t taste); int DB_Get_Taste(const std::string username); int DB_Set_Taste(const std::string username, const uint16_t taste) { int ret = DB_MGMT_FAILED; ret = DB_Lock(); if (DB_MGMT_OK == ret) { ret = s_DB->set_taste(username, taste); DB_UnLock(); } return ret; } int DB_Get_Taste(const std::string username) { int ret = DB_MGMT_FAILED; ret = DB_Lock(); if (DB_MGMT_OK == ret) { ret = s_DB->get_taste(username); DB_UnLock(); } return ret; } In sln_api.h, add the declarations of the functions  VIZN_SetTaste() ,  VIZN_GetTaste()  and  VIZN_Is_Rec_User() , and add the codes of the above three functions in sln_api.cpp. The VIZN_SetTaste() and VIZN_GetTaste() functions are equivalent to the encapsulation of the DB_Set_Taste() and DB_Get_Taste() functions. Why is it so complicated? To follow the code layering mechanism of the elock_oobe project and reduce the difficulty of code implementation through code layered encapsulation. /** * @brief Set user's favorite coffee taste. * * @Param clientHandle The client handler which required this action * @Param userName Pointer to a buffer which contains the name of the new user. * @Param taste Coffee taste */ vizn_api_status_t VIZN_SetTaste(VIZN_api_client_t *clientHandle, char *UserName, cfg_Coffee_taste taste); /** * @brief Set user's favorite coffee taste. * * @Param clientHandle The client handler which required this action * @Param userName Pointer to a buffer which contains the name of the new user. * @Param taste Pointer to the Coffee taste */ vizn_api_status_t VIZN_GetTaste(VIZN_api_client_t *clientHandle, char *UserName, int *taste); vizn_api_status_t VIZN_Is_Rec_User(VIZN_api_client_t *clientHandle, char *UserName); ~~~~~~~~~ vizn_api_status_t VIZN_SetTaste(VIZN_api_client_t *clientHandle, char *UserName, cfg_Coffee_taste taste) { int32_t status; if (!IsValidUserName(UserName)) { return kStatus_API_Layer_RenameUser_InvalidUserName; } status = DB_Set_Taste(std::string(UserName), (uint16_t)taste); if (status == 0) { return kStatus_API_Layer_Success; } else if (status == -1) { return kStatus_API_Layer_SetTaste_Failed; } } vizn_api_status_t VIZN_GetTaste(VIZN_api_client_t *clientHandle, char *UserName, int *taste) { int32_t status; if (!IsValidUserName(UserName)) { return kStatus_API_Layer_RenameUser_InvalidUserName; } *taste = DB_Get_Taste(std::string(UserName)); if (*taste != -1) { return kStatus_API_Layer_Success; } else { return kStatus_API_Layer_GetTaste_Failed; } } vizn_api_status_t VIZN_Is_Rec_User(VIZN_api_client_t *clientHandle, char *UserName) { if (!IsValidUserName(UserName)) { return kStatus_API_Layer_RenameUser_InvalidUserName; } return kStatus_API_Layer_Success; } In sln_api_init.cpp, declare the variable:  std::string Current_User = "" ; which is used to store the name corresponding to the face after recognition, and add the processing function  Coffee_Rec()  after successful face recognition in the structure variable ops2; std::string Current_User = " "; //Add customize function int Coffee_Rec(VIZN_api_client_t *pClient, face_info_t face_info); client_operations_t ops2 = { .detect = NULL, .recognize = Coffee_Rec,//NULL, .enrolment = NULL, }; //Add customize function int Coffee_Rec(VIZN_api_client_t *pClient, face_info_t face_info) { Current_User = face_info.name; return 1; } In sln_timers.h, increase MS_SYSTEM_LOCKED to extend the locked status time to 25 seconds; ~~~~~~~~ #define MS_SYSTEM_LOCKED 25000 //2000 // MS in which the board is in a locked state after a reg/rec. ~~~~~~~~ In sln_cli.cpp, add three Shell commands: order, set_taste, get_taste to stand for the operations of brewing coffee, setting coffee taste, and checking coffee taste; SHELL_COMMAND_DEFINE(set_taste, (char *)"\r\n\"set_taste username <0|1|2|3|~>\": set user's favorite taste\r\n" "0 - Cappuccino\r\n" "1 - Black Coffee\r\n" "2 - Coffee latte\r\n" "3 - Flat White\r\n" "4 - Cortado\r\n" "5 - Mocha\r\n" "6 - Con Panna\r\n" "7 - Lungo\r\n" "8 - Ristretto\r\n" "9 - Others \r\n", FFI_CLI_SetTasteCommand, SHELL_IGNORE_PARAMETER_COUNT); SHELL_COMMAND_DEFINE(get_taste, (char *)"\r\n\"get_taste username\": return user's favorite taste \r\n", FFI_CLI_GetTasteCommand, SHELL_IGNORE_PARAMETER_COUNT); SHELL_COMMAND_DEFINE(order, (char *)"\r\n\"order <0|1|2|3|~>\": order a favorite taste \r\n", FFI_CLI_OrderCommand, SHELL_IGNORE_PARAMETER_COUNT); ~~~~~~ static shell_status_t FFI_CLI_SetTasteCommand(shell_handle_t shellContextHandle, int32_t argc, char **argv) { if (argc != 3) { SHELL_Printf(shellContextHandle, "Wrong parameters\r\n"); return kStatus_SHELL_Error; } return UsbShell_QueueSendFromISR(shellContextHandle, argc, argv, SHELL_EV_FFI_CLI_SET_TASTE); } static shell_status_t FFI_CLI_GetTasteCommand(shell_handle_t shellContextHandle, int32_t argc, char **argv) { if (argc != 2) { SHELL_Printf(shellContextHandle, "Wrong parameters\r\n"); return kStatus_SHELL_Error; } return UsbShell_QueueSendFromISR(shellContextHandle, argc, argv, SHELL_EV_FFI_CLI_GET_TASTE); } shell_status_t FFI_CLI_OrderCommand(shell_handle_t shellContextHandle, int32_t argc, char **argv) { if (argc > 2) { SHELL_Printf(shellContextHandle, "Wrong parameters\r\n"); return kStatus_SHELL_Error; } return UsbShell_QueueSendFromISR(shellContextHandle, argc, argv, SHELL_EV_FFI_CLI_ORDER); } ~~~~~~ shell_status_t RegisterFFICmds(shell_handle_t shellContextHandle) { SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(list)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(add)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(del)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(rename)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(verbose)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(camera)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(version)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(save)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(updateotw)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(reset)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(emotion)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(liveness)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(detection)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(display)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(wifi)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(app_type)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(low_power)); // Add three Shell commands SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(order)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(set_taste)); SHELL_RegisterCommand(shellContextHandle, SHELL_COMMAND(get_taste)); return kStatus_SHELL_Success; } In sln_cli.cpp, it needs to add corresponding codes for handle order, set_taste, get_taste instructions in task UsbShell_CmdProcess_Task else if (queueMsg.shellCommand == SHELL_EV_FFI_CLI_SET_TASTE) { int coffee_taste = atoi(queueMsg.argv[2]); if (coffee_taste >= Cappuccino && coffee_taste <= Others) { status = VIZN_SetTaste(&VIZN_API_CLIENT(Shell),(char *)queueMsg.argv[1], (cfg_Coffee_taste)coffee_taste); if (status == kStatus_API_Layer_Success) { SHELL_Printf(shellContextHandle, "User: %s like coffee taste: %s \r\n", queueMsg.argv[1], Coffee_type[coffee_taste]); } else { SHELL_Printf(shellContextHandle, "Cannot set coffee taste\r\n"); } } else { SHELL_Printf(shellContextHandle, "Unsupported coffee taste\r\n"); } } else if (queueMsg.shellCommand == SHELL_EV_FFI_CLI_GET_TASTE) { int get_taste_num = 0; status = VIZN_GetTaste(&VIZN_API_CLIENT(Shell),(char *)queueMsg.argv[1], &get_taste_num); if (status == kStatus_API_Layer_Success) { SHELL_Printf(shellContextHandle, "User: %s like coffee taste: %s \r\n", queueMsg.argv[1], Coffee_type[(cfg_Coffee_taste)(get_taste_num)]); } else { SHELL_Printf(shellContextHandle, "Cannot get coffee taste\r\n"); } } else if (queueMsg.shellCommand == SHELL_EV_FFI_CLI_ORDER) { status = VIZN_Is_Rec_User(&VIZN_API_CLIENT(Shell),(char *)Current_User.c_str()); if (status == kStatus_API_Layer_Success) { if (queueMsg.argc == 1) { int get_taste_num = 0; status = VIZN_GetTaste(&VIZN_API_CLIENT(Shell),(char*)Current_User.c_str(), &get_taste_num); if (status == kStatus_API_Layer_Success) { SHELL_Printf(shellContextHandle, "User: %s order the a cup of %s \r\n", Current_User.c_str(), Coffee_type[(cfg_Coffee_taste)(get_taste_num)]); } else { SHELL_Printf(shellContextHandle, "Sorry, please order again, Current user is %s\r\n",Current_User.c_str()); } } else if(queueMsg.argc == 2) { int coffee_taste = atoi(queueMsg.argv[1]); if (coffee_taste >= Cappuccino && coffee_taste <= Others) { status = VIZN_SetTaste(&VIZN_API_CLIENT(Shell),(char*)Current_User.c_str(), (cfg_Coffee_taste)coffee_taste); if (status == kStatus_API_Layer_Success) { SHELL_Printf(shellContextHandle, "User: %s order a cup of %s \r\n", Current_User.c_str(), Coffee_type[coffee_taste]); } else { SHELL_Printf(shellContextHandle, "Cannot set coffee taste, Current user is %s\r\n",Current_User.c_str()); } } else { SHELL_Printf(shellContextHandle, "Unsupported coffee taste\r\n"); } } } } Use the cafe logo of《Friends》to replace the original Welcome_home picture, use the BmpCvt tool to convert the picture into the corresponding array, and add it to welcomehome_320x122.h. static const unsigned short Coffee_shop_320_122[] = { 0x59E6, 0x6227, 0x6247, 0x59C5, 0x59C5, 0x59A5, 0x4103, 0x6A67, 0x6A47, 0x6227, 0x6A47, 0x6A68, 0x7268, 0x6A67, 0x6A67, 0x6A47, 0x72A9, 0x6A68, 0x7268, 0x6A48, 0x5A06, 0x6A88, 0x6A68, 0x6247, 0x6A47, 0x7289, 0x7289, 0x6A47, 0x6A47, 0x6A47, 0x6227, 0x6A68, 0x6206, 0x6A47, 0x5A26, 0x6247, 0x6227, 0x6A27, 0x4924, 0x836D, 0x5207, 0x7BAC, 0x5247, 0x83ED, 0x4A47, 0x2923, 0x7B8C, 0x49E5, 0x49E5, 0x4A05, 0x28C1, 0x5226, 0x6267, 0x6A87, 0x72E9, 0x6267, 0x6AA9, 0x5A27, 0x6AA9, 0x6AA9, 0x5A47, 0x6A88, 0x5A06, 0x5A47, 0x6AA9, 0x5A47, 0x62A9, 0x5206, 0x6288, 0x6268, 0x5A47, 0x5A27, 0x5A47, 0x5A27, 0x49E6, 0x4A07, 0x4A07, 0x5A89, 0x49C6, 0x5A48, 0x5A28, 0x5A47, 0x5226, 0x49E6, 0x49C6, 0x41A6, 0x5208, 0x2082, 0x52A8, 0x6B6B, 0x39A5, 0x39A5, 0x3964, 0x49E7, 0x3104, 0x49C7, 0x3945, 0x41A6, 0x28A2, 0x2061, 0x3965, 0x28E3, 0x1881, 0x3944, 0x3103, 0x3103, 0x3903, 0x4145, 0x51A6, 0x51C6, 0x4985, 0x51E6, 0x51E6, 0x61E7, 0x6A48, 0x6A28, 0x6A28, 0x6A27, 0x61E6, 0x6207, 0x6A68, 0x59E7, 0x4185, 0x51E6, 0x51A6, 0x6228, 0x5A07, 0x6228, 0x5A08, 0x4184, 0x41A5, 0x4164, 0x3944, 0x3944, 0x736B, 0x83ED, 0x41A5, 0x83ED, 0x6288, 0x8BAB, 0x836A, 0x6287, 0x6B2A, 0x5267, 0x83CD, 0x5A68, 0x5228, 0x3986, 0x3985, 0x7B0A, 0x6A67, 0x7267, 0x832B, 0x49A5, 0x6206, 0x8AC9, 0x72A8, 0x82C9, 0x82E9, 0x8309, 0x6A46, 0x8B2B, 0x3860, 0x8329, 0x6A67, 0x7288, 0x7268, 0x61E6, 0x7267, 0x6A67, 0x59C5, 0x51A4, 0x6A46, 0x7AA8, 0x6A26, 0x7287, 0x7AA8, 0x72A8, 0x72A9, 0x51C5, 0x5A27, 0x5A27, 0x3923, 0x ~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~ 0x7B8C, 0x734B, 0x6B0A, 0x83CD, 0x83ED, 0x8C0E, 0x7B8C, 0x7B6C, 0x20C2, 0x5227, 0x83ED, 0x6AE9, 0x734B, 0x62A9, 0x7B6B, 0x7B8C, 0x62E9, 0x7BAC, 0x7B6B, 0x732A, 0x940D, 0x83AC, 0x732A, 0x7309, 0x8BCC, 0x7309, 0x8BCD, 0x83AC, 0x7B6B, 0x940D, 0x3943, 0x942E, 0x7B6B, 0x734A, 0x7B8B, 0x62C8, 0x7B8B, 0x7B6A, 0x7BAB, 0x732A, 0x7B6B, 0x7B6B, 0x83CC, 0x6B09, 0x6AA9, 0x6AE9, 0x7B6B, 0x7B8B, 0x83AC, 0x734B, 0x6AC9, 0x6B0A, 0x734B, 0x734A, 0x62A8, 0x732A, 0x8C0E, 0x8BCD, 0x944F, 0x734B, 0x7B8B, 0x732A, 0x942E, 0x8BCD, 0x83AD, 0x732B, 0x6B0A, 0x6AEA, 0x62C9, 0x9C90, 0x28C2, 0x8BEE, 0x93EE, 0x8BCD, 0x4183, 0x838B, 0x7B6A, 0x6287, 0x8BCB }; Programming the new project After saving the modified code and recompile the sln_viznas_iot_elock_oobe project (as shown in the figure below), then connect the MCU-LINK to J6 on the SLN-VIZNAS-IOT, just like Fig9 shows. Fig8 Recompile code Fig9 MCU-LINK (Note: it needs to reselect the Flash driver, as the below figure shows.) Fig10 Flash driver After that, it's able to program the code project to the on-board Hyperflash. Test & Summary When the new code project boot-up, please refer to Get Started with the SLN-VIZNAS-IOT to use the serial terminal to test the newly added three Shell commands: orders, set_taste, and get_taste. Once a face is successfully recognized, the cafe logo will appear up (as shown in Fig11). Fig11 Cafe logo Definitely, this smart coffee machine seems like a 'toy' demo, and there is a lot of work to improve it. Below is the list of my future work plans, Use the LCD panel instead of USB to display; Connect an external amplifier to enable voice prompt feature; Enable the Wifi feature to connect to the App; Use the GUI library to enhance UI experience; Add a voice recognition feature to control; And I'll be glad to hear any comments from you.
View full article
Background: The CAAM manufacturing protection feature provides a mechanism to authenticate the chip to the OEM's server. The manufacturing protection feature can be used to ensure that the chip:  Is a genuine NXP SoC  Is the correct device type and part number  Has been properly configured by means of fuses  Is running authenticated OEM software  Is currently in the secure or trusted mode The CAAM manufacturing protection feature is based on an ECC private key generated by the High Assurance Boot (HAB) code on every boot cycle. The Manufacturing Protection (MP) private key generation takes as input several fixed secrets and the MANUFACTURE_PROTECTION_KEY[255:0] being one of them in SoC fuses.   Issue Description: On certain i.MX RT117x and RT116x devices the MANUFACTURE_PROTECTION_KEY[255:0] fuses were incorrectly programmed at the NXP factory. During the MP private key generation, the CAAM block validates the inputs provided and fails as the MANUFACTURE_PROTECTION_KEY[255:0] provided is not a valid one. As the MPPubK-generation and MPSign CAAM functions depends on the result of MPPrivK-generation function the CAAM manufacturing protection feature cannot be used on the impacted devices. Details regarding manufacturing protection functions can be found in the section "Manufacturing-protection chip-authentication process" in the security reference manuals (SRM).  Please note that in closed mode the CAAM MPPrivK-generation function can be only executed once in the same power-on session. Running a second time returns a CAAM error (0x40000481) undefined protocol command which is not related to the issue described in this document.   Checking if your device is impacted: Customers can check if their device is impacted by following the 3 steps below: Checking the date code: Devices from datecodes prior to 2213 are impacted. Checking HAB events: The HAB code logs a warning event in the HAB persistent memory region after detecting a failure in the MP private key generation. This warning is logged independently regardless of whether HAB is enabled (SEC_CONFIG =1) or not. Customers can parse the HAB persistent memory region at 0x20242000 in order to get the warning events.  Impacted devices should report the event below: Event    | 0xdb | 0x0024 | 0x45 |  SRCE Field: 69 30 e1 1d             |         |             |         |             STS = HAB_WARNING (0x69)             |         |             |         |             RSN = HAB_ENG_FAIL (0x30)             |         |             |         |            CTX = HAB_CTX_ENTRY (0xE1)             |         |             |         |            ENG = HAB_ENG_CAAM (0x1d)             |         |             |         |  Evt Data (hex):             |         |             |         |   00 01 00 02 40 00 04 cc 00 00 00 0f 00 00 00 00             |         |             |         |   00 00 00 00 00 00 00 00 00 00 00 01 3. Checking the CAAM SCFGR register: After running the MPPrivK-generation function the CAAM block stores in the CAAM SCFGR register the elliptic curve that was selected when the MPPrivK generation protocol was executed. Users can check the MPCURVE field [31:28] in the CAAM SCFGR register and on impacted devices this field will be 0.    List of impacted devices:  All i.MX RT117x and RT116x devices prior to 2213 datecode are impacted.   Workaround: No Software Workaround can be implemented. Customers planning to use the Manufacturing Protection feature should request for SoC's that have the correct fuse programming. Please Note: This issue does not impact the Secure Boot flow and does not compromise security.
View full article
Issue: 802.11 IEEE station Power Save mode is not working as expected with the latest SDK 2.11.1, supporting NXP wireless solutions 88W8987/88W8977/IW416.   Solution: Modify the structure in file : middleware/wifi/wifidriver/incl/mlan_fw.h, Replace  “ENH_PS_MODES action” to “uint16_t action”.    Note: This fix will officially be part of SDK: 2.12.0
View full article
Introduction  This document is an extension of section 3.1.3, “Software implementation” from the application note AN12077, using the i.MX RT FlexRAM. It's important that before continue reading this document, you read this application note carefully.  Link to the application note.  Section 3.1.3 of the application note explains how to reallocate the FlexRAM through software within the startup code of your application. This document will go into further detail on all the implications of making these modifications and what is the best way to do it.  Prerequisites RT10xx-EVK  The latest SDK which you can download from the following link: Welcome | MCUXpresso SDK Builder MCUXpresso IDE Internal SRAM  The amount of internal SRAM varies depending on the RT. In some cases, not all the internal SRAM can be reallocated with the FlexRAM.  RT  Internal SRAM FlexRAM RT1010 Up to 128 KB Up to 128 KB RT1015 Up to 128 KB Up to 128 KB RT1020 Up to 256 KB Up to 256 KB RT1050 Up to 512 KB Up to 512 KB RT1060 Up to 1MB  Up to 512 KB RT1064 Up to 1MB Up to 512 KB   In the case of the RT106x, only 512 KB out of the 1MB of internal SRAM can be reallocated through the FlexRAM as DTCM, ITCM, and OCRAM. The remaining 512 KB are from OCRAM and cannot be reallocated. For all the other RT10xx you can reallocate the whole internal SRAM either as DTCM, ITCM, and OCRAM. Section 3.1.3.1 of the application note explains the limitations of the size when reallocating the FlexRAM. One thing that's important to mention is that the ROM bootloader in all the RT10xx parts uses the OCRAM, hence you should keep some  OCRAM when reallocating the FlexRAM, this doesn't apply to the RT106x since you will always have the 512 KB of OCRAM that cannot be reallocated. To know more about how many OCRAM each RT family needs please refer to section 2.1.1.1 of the application note. Implementation in MCUXpresso IDE First, you need to import any of the SDK examples into your MCUXpresso IDE workspace. In my case, I imported the igpio_led_output example for the RT1050-EVKB. If you compile this project, you will see that the default configuration for the FlexRAM on the RT1050-EVKB is the following:  SRAM_DTC 128 KB SRAM_ITC 128 KB SRAM_OC 256 KB   Now we need to go to the Reset handler located in the file startup_mimxrt1052.c. Reallocating the FlexRAM has to be done before the FlexRAM is configured, this is why it's done inside the Reset Handler.  The registers that we need to modify to reallocate the FlexRAM are IOMUXC_GPR_GPR16, and IOMUXC_GPR_GPR17. So first we need to have in hand the addresses of these three registers. Register Address IOMUXC_GPR_GPR16 0x400AC040 IOMUXC_GPR_GPR17 0x400AC044   Now, we need to determine how we want to reallocate the FlexRAM to see the value that we need to load into register IOMUXC_GPR_GPR17. In my case, I want to have the following configuration:  SRAM_DTC 256 KB SRAM_ITC 128 KB SRAM_OC 128 KB   When choosing the new sizes of the FlexRAM be sure that you choose a configuration that you can also apply through the FlexRAM fuses, I will explain the reason for this later. The configurations that you can achieve through the fuses are shown in the Fusemap chapter of the reference manual in the table named "Fusemap Descriptions", the fuse name is "Default_FlexRAM_Part".  Based on the following explanation of the IOMUXC_GPR_GPR17 register: The value that I need to load to the register is 0xAAAAFF55. Where the first  4 banks correspond to the 128KB of SRAM_OC, the next 4 banks correspond to the 128KB of SRAM_ITC and the last 8 banks are the 256KB of SRAM_DTC.  Now, that we have all the addresses and the values that we need we can start writing the code in the Reset handler. The first thing to do is load the new value into the register IOMUXC_GPR_GPR17. After, we need to configure register IOMUXC_GPR_GPR16 to specify that the FlexRAM bank configuration should be taken from register IOMUXC_GPR_GPR17 instead of the fuses. Then if in your new configuration of the FlexRAM either the SRAM_DTC or SRAM_ITC are of size 0, you need to disable these memories in the register IOMUXC_GPR_GPR16. At the end your code should look like the following:    void ResetISR(void) { // Disable interrupts __asm volatile ("cpsid i"); /* Reallocating the FlexRAM */ __asm (".syntax unified\n" "LDR R0, =0x400ac044\n"//Address of register IOMUXC_GPR_GPR17 "LDR R1, =0xaaaaff55\n"//FlexRAM configuration DTC = 265KB, ITC = 128KB, OC = 128KB "STR R1,[R0]\n" "LDR R0,=0x400ac040\n"//Address of register IOMUXC_GPR_GPR16 "LDR R1,[R0]\n" "ORR R1,R1,#4\n"//The 4 corresponds to setting the FLEXRAM_BANK_CFG_SEL bit in register IOMUXC_GPR_GPR16 "STR R1,[R0]\n" #ifdef FLEXRAM_ITCM_ZERO_SIZE "LDR R0,=0x400ac040\n"//Address of register IOMUXC_GPR_GPR16 "LDR R1,[R0]\n" "AND R1,R1,#0xfffffffe\n"//Disabling SRAM_ITC in register IOMUXC_GPR_GPR16 "STR R1,[R0]\n" #endif #ifdef FLEXRAM_DTCM_ZERO_SIZE "LDR R0,=0x400ac040\n"//Address of register IOMUXC_GPR_GPR16 "LDR R1,[R0]\n" "AND R1,R1,#0xfffffffd\n"//Disabling SRAM_DTC in register IOMUXC_GPR_GPR16 "STR R1,[R0]\n" #endif ".syntax divided\n"); #if defined (__USE_CMSIS) // If __USE_CMSIS defined, then call CMSIS SystemInit code SystemInit(); ...‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍   If you compile your project you will see the memory distribution that appears on the console is still the default configuration.  This is because we did modify the Reset handler to reallocate the FlexRAM but we haven't modified the linker file to match these new sizes. To do this you need to go to the properties of your project. Once in the properties, you need to go to C/C++ Build -> MCU settings. Once you are in the MCU settings you need to modify the sizes of the SRAM memories to match the new configuration.  When you make these changes click Apply and Close. After making these changes if you compile the project you will see the memory distribution that appears in the console is now matching the new sizes.  Now we need to modify the Memory Protection Unit (MPU) to match these new sizes of the memories. To do this you need to go to the function BOARD_ConfigMPU inside the file board.c. Inside this function, you need to locate regions 5, 6, and 7 which correspond to SRAM_ITC, SRAM_DTC, and SRAM_OC respectively. Same as for register IOMUXC_GPR_GPR14, if the new size of your memory is not 32, 64, 128, 256, or 512 you need to choose the next greater number. Your configuration should look like the following:    /* Region 5 setting: Memory with Normal type, not shareable, outer/inner write back */ MPU->RBAR = ARM_MPU_RBAR(5, 0x00000000U); MPU->RASR = ARM_MPU_RASR(0, ARM_MPU_AP_FULL, 0, 0, 1, 1, 0, ARM_MPU_REGION_SIZE_128KB); /* Region 6 setting: Memory with Normal type, not shareable, outer/inner write back */ MPU->RBAR = ARM_MPU_RBAR(6, 0x20000000U); MPU->RASR = ARM_MPU_RASR(0, ARM_MPU_AP_FULL, 0, 0, 1, 1, 0, ARM_MPU_REGION_SIZE_256KB); /* Region 7 setting: Memory with Normal type, not shareable, outer/inner write back */ MPU->RBAR = ARM_MPU_RBAR(7, 0x20200000U); MPU->RASR = ARM_MPU_RASR(0, ARM_MPU_AP_FULL, 0, 0, 1, 1, 0, ARM_MPU_REGION_SIZE_128KB);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍   We need to change the image entry address to the Reset handler. To do this, you need to go to the file fsl_flexspi_nor_boot.c inside the xip folder. You need to declare the ResetISR and change the entry address in the image vector table.  Finally, we need to place the stack at the start of the DTCM memory. To do this, we need to go to the properties of your project. From there, we have to C/C++ Build and Manage Linker Script.  From there, we will need to add two more assembly instructions in our ResetISR function. We have to add these two instructions at the beginning of our assembly code:  In the attached c file, you'll find all the assembly instructions mentioned above.  That's it, these are all the changes that you need to make to reallocate the FlexRAM during the startup.  Debug Session  To verify that all the modifications that we just did were correct we will launch the debug session. As soon as we reach the main, before running the application, we will go to the peripheral view to see registers IOMUXC_GPR_GPR16, and IOMUXC_GPR_GPR17 and verify that the values are the correct ones. In register IOMUXC_GPR_GPR16 as shown in the image below we configure the FLEXRAM_BANK_CFG_SEL as 1 to use the use register IOMUXC_GPR_GPR17 to configure the FlexRAM.  Finally, in register IOMUXC_GPR_GPR17 we can see the value 0xAAAAFF55 that corresponds to the new configuration.  Reallocating the FlexRAM through the Fuses  We just saw how to reallocate the FlexRAM through software by writing some code in the Reset Handler. This procedure works fine, however, it's recommended that you use this approach to test the different sizes that you can configure but once you find the correct configuration for your application we highly recommend that you configure these new sizes through the fuses instead of using the register IOMUXC_GPR_GPR17. There are lots of dangerous areas in reconfiguring the FlexRAM in code. It pretty much all boils down to the fact that any code/data/stack information written to the RAM can end up changing location during the reallocation.  This is the reason why once you find the correct configuration, you should apply it through the fuses. If you use the fuses to configure the FlexRAM, then you don't have the same concerns about moving around code and data, as the fuse settings are applied as a hardware default.  Keep in mind that once you burn the fuses there's no way back! This is why it's important that you first try the configuration through the software method. Once you burn the fuses you won't need to modify the Reset handler, you only need to modify the MPU to change the size of regions as we saw before and the MCU settings of your project to match the new memory sizes that you configured through the fuses.  The fuse in charge of the FlexRAM configuration is Default_FlexRAM_Part, the address of this fuse is 0x6D0[15:13]. You can find more information about this fuse and the different configurations in the Fusemap chapter of the reference manual.  To burn the fuses I recommend using either the blhost or the MCUBootUtility.  Link to download the blhost.  Link to the MCUBootUtility webpage.    I hope you find this document helpful!  Víctor Jiménez
View full article
RT106L_S voice control system based on the Baidu cloud 1 Introduction     The NXP RT106L and RT106S are voice recognition chip which is used for offline local voice control, SLN-LOCAL-IOT is based on RT106L, SLN-LOCAL2-IOT is a new local speech recognition board based on RT106S. The board includes the murata 1DX wifi/BLE module, the AFE voice analog front end, the ASR recognition system, the external flash, 2 microphones, and the analog voice amplifier and speakers. The voice recognition process for SLN-LOCAL-IOT and SLN-LOCAL2-IOT is different and the new SLN-LOCAL2-IOT is recommended.     This article is based on the voice control board SLN-LOCAL/2-IOT to implement the following block diagram functions: Pic 1 Use the PC-side speed model tool (Cyberon DSMT) to generate WW(wake word) and VC(voice command) Command related voice engine binary files , which will be used by the demo code. This system is mainly used for the Chinese word recognition, when the user says Chinese word: "小恩小恩", it wakes up SLN-LOCAL/2-IOT, and the board gives feedback "小恩来了,请吩咐". Then system enter the voice recognition stage, the user can say the voice recognition command: “开红灯”,“关红灯”,“开绿灯”,“关绿灯”,“灯闪烁”,“开远程灯”,“关远程灯”, after recognition, the board gives feedback "好的". Among them, “开红灯”,“关红灯”,“开绿灯”,“关绿灯”,“灯闪烁”,the five commands are used for the local light switch, while the 开远程灯”,“关远程灯“two commands can through network communication Baidu cloud control the additional MIMXRT1060-EVK development board light switch. SLN-LOCAL/2-IOT through the WIFI module access to the Internet with MQTT protocol to achieve communication with Baidu cloud, when dectect the remote control command, publish the json packets to Baidu cloud, while MIMRT1060-EVK subscribe Baidu cloud data, will receive data from the IOT board and analyze the EVK board led control. PC side can use MQTT.fx software to subscribe the Baidu cloud data, it also can send data to the device to achieve remote control function directly.  Now, will give the detail content about how to use the SLN-LOCAL/2-IOT SDK demo realize the customized Chinese wake command and voice command, and remote control the MIMXRT1060-EVK through the Baidu Cloud.     2 Platform establish 2.1 Used platform SLN-LOCAL-IOT/SLN-LOCAL2-IOT MIMXRT1060-EVK MQTT.fx SDK_2_8_0_SLN-LOCAL2-IOT MCUXPresso IDE Segger JLINK Baidu Smart Cloud: Baidu cloud control+ TTS Audacity:audio file format convert tool WAVToCode:wav convert to the c array code, which used for the demo tilte play MCUBootUtility: used to burn the feedback audio file to the filesystem Cyberon DSMT: wake word and voice detect command generation tool DSMT is the very important tool to realize the wake word and voice dection, the apply follow is: Pic 2 2.2 Baidu Smart cloud 2.2.1 Baidu cloud IOT control system Enter the IoT Hub: https://cloud.baidu.com/product/iot.html     Click used now. 2.2.1.1 Create device project Create a project, select the device type, and enter the project name. Device types can use shadows as images of devices in the cloud to see directly how data is changing. Once created, an endpoint is generated, along with the corresponding address: Pic 3 2.2.1.2 Create Thing model The Thing model is mainly to establish various properties needed in the shadow, such as temperature, humidity, other variables, and the type of value given, in fact, it is also the json item in the actual MQTT communication.    Click the newly created device-type project where you can create a new thing model or shadow: Pic 4    Here create 3 attributes:LEDstatus,humid,temp It is used to represent the led status, humidity, temperature and so on, which is convenient for communication and control between the cloud and RT board. Once created, you get the following picture:   Pic 5   2.2.1.3 Create Thing shadow In the device-type project, you can select the shadow, build your own shadow platform, enter the name, and select the object model as the newly created Thing model containing three properties, after the create, we can get the details of the shadow:   Pic 6 At the same time will also generate the shadow-related address, names and keys, my test platform situation is as follows: TCP Address: tcp://rndrjc9.mqtt.iot.gz.baidubce.com:1883 SSL Address: ssl://rndrjc9.mqtt.iot.gz.baidubce.com:1884 WSS Address: wss://rndrjc9.mqtt.iot.gz.baidubce.com:443 name: rndrjc9/RT1060BTCDShadow key: y92ewvgjz23nzhgn Port 1883, does not support transmission data encryption Port 1884, supports SSL/TLS encrypted transmission Port 8884, which supports wesockets-style connections, also contains SSL encryption. This article uses a 1883 port with no transmission data encryption for easy testing. So far, Baidu cloud device-type cloud shadow has been completed, the following can use MQTTfx tools to connect and test. In practice, it is recommended that customers build their own Baidu cloud connection, the above user key is for reference only.   2.2.2 Online TTS    SLN-LOCAL/2-IOT board recognizes wake-up words, recognition words, or when powering on, you need to add corresponding demo audio, such as: "百度云端语音测试demo ", "小恩来啦!请吩咐“,"好的". These words need to do a text-to-wav audio file synthesis, here is Baidu Smart Cloud's online TTS function, the specific operation can refer to the following documents: https://ai.baidu.com/ai-doc/SPEECH/jk38y8gno   Once the base audio library is opened, use the main.py provided in the link above and modify it to add the Chinese field you want to convert to the file "TEXT" and add the audio file to be converted in "save_file" such as xxx .wav, using the command: python main.py to complete the conversion, and generate the audio format corresponding to the text, such as .mp3, .wav. Pic 7   After getting the wav file, it can’t be used directly, we need to note that for SLN-LOCAL/2-IOT board, you need to identify the audio source of the 48K sample rate with 16bit, so we need to use the Audioacity Audio tool to convert the audio file format to 48K16bit wav. Import 16K16bit wav files generated by Baidu TTS into the Audioacity tool, select project rate of 48Khz, file->export->export as WAV, select encoding as signed 16bit PCM, and regenerate 48Khz16bit wav for use. Pic 8 “百度云端语音测试demo“:Used for power-on broadcasting, demo name broadcasting, it is stored in RT demo code, so you need to convert it to a 16bit C code array and add it to the project. "小恩来啦!请吩咐",“好的“:voice detect feedback, it is saved in the filesystem ZH01,ZH02 area. 2.3 playback audio data prepare and burn   There are two playback audio file, it is "小恩来啦!请吩咐",“好的“,it is saved in the filesystem ZH01,ZH02 area. Filesystem memory map like this: Pic 9 So, we need to convert the 48K16bit wav file to the filesystem needed format, we need to use the official tool::Ivaldi_sln_local2_iot Reference document:SLN-LOCAL2-IOT-DG chapter 10.1 Generating filesystem-compatible files Use bash input the commands like the following picture: Pic10 Use the convert command to get the playback bin file: python file_format.py -if xiaoencoming_48k16bit.wav -of xiaoencoming_48k16bit.bin -ft H At last, it will generate the file: "小恩来啦!请吩咐"->xiaoencoming_48k16bit.bin,burn to flash address 0x6184_0000 “好的”->OK_48k16bit.bin, burn to flash address 0x6180_0000 Then, use MCUBootUtility tool burn the above two file to the related images. Here, take OK_48k16bit.bin as an example, demo enter the serial download mode(J27-0), power off and power on. Flash chip need to select hyper flash IS26KSXXS, use the boot device memory windows, write button to burn the .bin file to the related address, length is 0X40000 Pic11 Pic12 xiaoencoming_48k16bit.bin can use the same method to download to 0x6184_0000,Length is 0X40000.   2.4 Demo audio prepare and add The prepared baiduclouddemo_48K16bit.wav(“百度云端语音测试demo “) need to convert to the 16bit C array code, and put to the project code, calls by the code, this is used for the demo mode play. The convert need to use the WAVToCode, the operation like this: Pic 13 The generated baiducloulddemo_48K16bit.c,add it to the demo project C files: sln_local_iot_local_demo->audio->demos->smart_home.c。 2.5 WW and VC prepare Wake-up word are generated through the cyberon DSMT tool, which supports a wide range of language, customers can request the tool through Figure 2. The Chinese wake-up words and voice command words in this article are also generated through DSMT. DSMT can have multiple groups, group1 as a wake-up word configuration, CmdMapID s 1. Other groups act as voice command words, such as CMD-IOT in this article, cmdMapID=2. Pic 14   Pic 15 Wake word continuously detects the input audio stream, uses group1, and if successfully wakes up, will do the voice command detection uses group2, or other identifying groups as well as custom groups. The wake-up words using the DSMT tool, the configuration are as follows: Pic 16 The WW can support more words, customer can add the needed one in the group 1. Use the DSMT configure VC like this: Pic 17 Then, save the file, code used file are: _witMapID.bin, CMD_IOT.xml,WW.xml. In the generated files, CYBase.mod is the base model, WW.mod is the WW model, CMD_IOT.mod is the VC model. After Pic 16,17, it finishes the WW and VC command prepare, we can put the DSMT project to the RT106S demo project folder: sln_local2_iot_local_demo\local_voice\oob_demo_zh 3 Code prepare Based on the official SLN-LOCAL2-IOT SDK local_demo, the code in this article modifies the Chinese wake-up words and recognition words (or you can build a new customer custom group directly), add local voice detect the led status operations, Then feedback Chinese audio, demo Chinese audio, Wifi network communication MQTT protocol code, and Baidu cloud shadow connection publish. Source reference code SDK path: SDK_2_8_0_SLN-LOCAL2-IOT\boards\sln_local2_iot\sln_voice_examples\local_demo   SDK_2_8_0_SLN-LOCAL2-IOT\boards\sln_local2_iot\sln_boot_apps SLN-LOCAL2-IOT and SLN-LOCAL-IOT code are nearly the same, the only difference is that the ASR library file is different, for RT106S (SLN-LOCAL2-IOT) using SDK it’s own libsln_asr.a library, for RT106L (SLN-LOCAL-IOT) need to use the corresponding libsln_asr_eval.a library.    Importing code requires three projects: local_demo, bootloader, bootstrap. The three projects store in different spaces. See SLN-LOCAL2-IOT-DG .pdf, chapter 3.3 Device memory map    This is the 3 chip project boot process: Pic 18 This document is for demo testing and requires debug, so this article turns off the encryption mechanism, configures bootloader, bootstrap engineering macro definition: DISABLE_IMAGE_VERIFICATION = 1, and uses JLINK to connect SLN-LOCAL/2-IOT's SWD interface to burn code. The following is to add modification code for app local_demo projects. 3.1 sln-local/2-iot code Sln-local-iot, sln-local2-iot platform, the following modification are the same for the two platform. 3.1.1 Voice recognition related code 1)Demo audio play Play content:“百度云端语音测试demo“ sln_local2_iot_local_demo_xe_ledwifi\audio\demos\ smart_home.c content is replaced by the previously generated baiducloulddemo_48K16bit.C. audio_samples.h,modify: #define SMART_HOME_DEMO_CLIP_SIZE 110733 This code is used for the main.c announce_demo API play:         case ASR_CMD_IOT:             ret = demo_play_clip((uint8_t *)smart_home_demo_clip, sizeof(smart_home_demo_clip));   2)command print information #define NUMBER_OF_IOT_CMDS      7 IndexCommands.h static char *cmd_iot_en[] = {"Red led on", "Red led off", "Green led on", "Green led off",                              "cycle led",        "remote led on",         "remote led off"}; static char *cmd_iot_zh[] = {"开红灯", "关红灯", "开绿灯", "关绿灯", "灯闪烁", "开远程灯", "关远程灯"}; Here is the source code modification using IOT, you can actually add your own speech recognition group directly, and add the relevant command identification.   3)sln_local_voice.c Line757 , add led-related notification information in ASR_CMD_IOT mode. oob_demo_control.ledCmd = g_asrControl.result.keywordID[1];     The code is used to obtain the recognized VC command data, and the value of keywordID[1] represents the number. This number can let the code know which detail voice is detected. so that you can do specific things in the app based on the value of ledcmd. The value of keywordID[1] corresponds to Command List in Figure 17. For example, “开远程灯“, if woke up, and recognized "开远程灯", then keywordID[1] is 5, and will transfer to oob_demo_control.ledCmd, which will be used in the appTask API to realize the detail control. 4) main.c void appTask(void *arg) Under case kCommandGeneric: if the language is Chinese, then add the recognition related control code, at first, it will play the feedback as “好的”. Then, it will check the voice detect value, give the related local led control. else if (oob_demo_control.language == ASR_CHINESE) { // play audio "OK" in Chinese #if defined(SLN_LOCAL2_RD) ret = audio_play_clip((uint8_t *)AUDIO_ZH_01_FILE_ADDR, AUDIO_ZH_01_FILE_SIZE); #elif defined(SLN_LOCAL2_IOT) ret = audio_play_clip(AUDIO_ZH_01_FILE); #endif //kerry add operation code==================================================begin RGB_LED_SetColor(LED_COLOR_OFF); if (oob_demo_control.ledCmd == LED_RED_ON) { RGB_LED_SetColor(LED_COLOR_RED); vTaskDelay(5000); } else if (oob_demo_control.ledCmd == LED_RED_OFF) { RGB_LED_SetColor(LED_COLOR_OFF); vTaskDelay(5000); } else if (oob_demo_control.ledCmd == LED_BLUE_ON) { RGB_LED_SetColor(LED_COLOR_BLUE); vTaskDelay(5000); } else if (oob_demo_control.ledCmd == LED_BLUE_OFF) { RGB_LED_SetColor(LED_COLOR_OFF); vTaskDelay(5000); } else if (oob_demo_control.ledCmd == CYCLE_SLOW) { for (int i = 0; i < 3; i++) { RGB_LED_SetColor(LED_COLOR_RED); vTaskDelay(400); RGB_LED_SetColor(LED_COLOR_OFF); RGB_LED_SetColor(LED_COLOR_GREEN); vTaskDelay(400); RGB_LED_SetColor(LED_COLOR_OFF); RGB_LED_SetColor(LED_COLOR_BLUE); vTaskDelay(400); } } … } In addition to local voice recognition control, this article also add remote control functions, mainly through wifi connection, use the mqtt protocol to connect Baidu cloud server, when local speech recognition get the remote control command, it publish the corresponding control message to Baidu cloud, and then the cloud send the message to the client which subscribe this message,  after the client get the message, it will refer to the message content do the related control.   3.1.3 Network connection code 1)sln_local2_iot_local_demo_xe_ledwifi\lwip\src\apps\mqtt     Add mqtt.c 2)sln_local2_iot_local_demo_xe_ledwifi\lwip\src\include\lwip\apps Add mqtt.h, mqtt_opts.h,mqtt_prv.h The related mqtt driver is from the RT1060 sdk, which already added in the attachment project. 3)sln_tcp_server.c   Add MQTT application layer API function code, client ID, server host, MQTT server port number, user name, password, subscription topic, publishing topic and data, etc., more details, check the attachment code.    The MQTT application code is ported from the mqtt project of the RT1060 SDK and added to the sln_tcp_server.c. TCP_OTA_Server function is used to initialize the wifi network, realize wifi connection, connect to the network, resolve Baidu cloud server URL to get IP, and then connect Baidu cloud server through mqtt, after the successful connection, publish the message at first, so that after power-up through mqttfx to see whether the power on network publishing message is successful. TCP_OTA_Server function code is as follows: static void TCP_OTA_Server(void *param) //kerry consider add mqtt related code { err_t err = ERR_OK; uint8_t status = kCommon_Failed; #if USE_WIFI_CONNECTION /* Start the WiFi and connect to the network */ APP_NETWORK_Init(); while (status != kCommon_Success) { status_t statusConnect; statusConnect = APP_NETWORK_Wifi_Connect(true, true); if (WIFI_CONNECT_SUCCESS == statusConnect) { status = kCommon_Success; } else if (WIFI_CONNECT_NO_CRED == statusConnect) { APP_NETWORK_Uninit(); /* If there are no credential in flash delete the TPC server task */ vTaskDelete(NULL); } else { status = kCommon_Failed; } } #endif #if USE_ETHERNET_CONNECTION APP_NETWORK_Init(true); #endif /* Wait for wifi/eth to connect */ while (0 == get_connect_state()) { /* Give time to the network task to connect */ vTaskDelay(1000); } configPRINTF(("TCP server start\r\n")); configPRINTF(("MQTT connection start\r\n")); mqtt_client = mqtt_client_new(); if (mqtt_client == NULL) { configPRINTF(("mqtt_client_new() failed.\r\n");) while (1) { } } if (ipaddr_aton(EXAMPLE_MQTT_SERVER_HOST, &mqtt_addr) && IP_IS_V4(&mqtt_addr)) { /* Already an IP address */ err = ERR_OK; } else { /* Resolve MQTT broker's host name to an IP address */ configPRINTF(("Resolving \"%s\"...\r\n", EXAMPLE_MQTT_SERVER_HOST)); err = netconn_gethostbyname(EXAMPLE_MQTT_SERVER_HOST, &mqtt_addr); configPRINTF(("Resolving status: %d.\r\n", err)); } if (err == ERR_OK) { configPRINTF(("connect to mqtt\r\n")); /* Start connecting to MQTT broker from tcpip_thread */ err = tcpip_callback(connect_to_mqtt, NULL); configPRINTF(("connect status: %d.\r\n", err)); if (err != ERR_OK) { configPRINTF(("Failed to invoke broker connection on the tcpip_thread: %d.\r\n", err)); } } else { configPRINTF(("Failed to obtain IP address: %d.\r\n", err)); } int i=0; /* Publish some messages */ for (i = 0; i < 5;) { configPRINTF(("connect status enter: %d.\r\n", connected)); if (connected) { err = tcpip_callback(publish_message_start, NULL); if (err != ERR_OK) { configPRINTF(("Failed to invoke publishing of a message on the tcpip_thread: %d.\r\n", err)); } i++; } sys_msleep(1000U); } vTaskDelete(NULL); } Please note the following published json data, it can’t be publish directly in the code. {   "reported": {     "LEDstatus": false,     "humid": 88,     "temp": 22   } } Which need to use this web https://www.bejson.com/ realize the json data compression and convert: {\"reported\" : {     \"LEDstatus\" : true,     \"humid\" : 88,     \"temp\" : 11    } }   4)main appTask Under case kCommandGeneric: , if the language is Chinese, then add the corresponding voice recognition control code. "开远程灯": turn on the local yellow light, publish the “remote led on” mqtt message to Baidu cloud, control remote 1060EVK board lights on. "关远程灯": turn on the local white light, publish the “remote led off” mqtt message to Baidu cloud, control the remote 1060EVK board light off. Related operation code: else if (oob_demo_control.ledCmd == LED_REMOTE_ON) { RGB_LED_SetColor(LED_COLOR_YELLOW); vTaskDelay(5000); err_t err = ERR_OK; err = tcpip_callback(publish_message_on, NULL); if (err != ERR_OK) { configPRINTF(("Failed to invoke publishing of a message on the tcpip_thread: %d.\r\n", err)); } } else if (oob_demo_control.ledCmd == LED_REMOTE_OFF) { RGB_LED_SetColor(LED_COLOR_WHITE); vTaskDelay(5000); err_t err = ERR_OK; err = tcpip_callback(publish_message_off, NULL); if (err != ERR_OK) { configPRINTF(("Failed to invoke publishing of a message on the tcpip_thread: %d.\r\n", err)); } } 3.2 MIMXRT1060-EVK code The main function of the MIMXRT1060-EVK code is to configure another client in the cloud, subscribe to the message published by SLN-LOCAL/2-IOT which detect the remote command, and then the LED on the control board is used to test the voice recognition remote control function, this code is based on Ethernet, through the Ethernet port on the board, to achieve network communication, and then use mqtt to connect baidu cloud, and subscribe the message from local2, This enables the reception and execution of the Local2 command. the network code part is similar to SLN-LOCAL2-IOT board network code, the servers, cloud account passwords, etc. are all the same, the main function is to subscribe messages. See the code from attachment RT1060, lwip_mqtt_freertos.c file. When receives data published by the server, it needs to do a data analysis to get the status of the led light and then control it. Normal data from Baidu cloud shadow sent as follows Received 253 bytes from the topic "$baidu/iot/shadow/RT1060BTCDShadow/update/accepted": "{"requestId":"2fc0ca29-63c0-4200-843f-e279e0f019d3","reported":{"LEDstatus":false,"humid":44,"temp":33},"desired":{},"lastUpdatedTime":{"reported":{"LEDstatus":1635240225296,"humid":1635240225296,"temp":1635240225296},"desired":{}},"profileVersion":159}" Then you need to parse the data of LEDstatus from the received data, whether it is false or true. Because the amount of data is small, there is no json-driven parsing here, just pure data parsing, adding the following parsing code to the mqtt_incoming_data_cb function: mqtt_rec_data.mqttindex = mqtt_rec_data.mqttindex + len; if(mqtt_rec_data.mqttindex >= 250) { PRINTF("kerry test \r\n"); PRINTF("idex= %d", mqtt_rec_data.mqttindex); datap = strstr((char*)mqtt_rec_data.mqttrecdata,"LEDstatus"); if(datap != NULL) { if(!strncmp(datap+11,strtrue,4))//char strtrue[]="true"; { GPIO_PinWrite(GPIO1, 3, 1U); //pull high PRINTF("\r\ntrue"); } else if(!strncmp(datap+11,strfalse,5))//char strfalse[]="false"; { GPIO_PinWrite(GPIO1, 3, 0U); //pull low PRINTF("\r\nfalse"); } } mqtt_rec_data.mqttindex =0; It use the strstr search the “LEDstatus“ in the received data, and get the pointer position, then add the fixed length to get the LED status is true or flash. If it is true, turn on the led, if it is false, turn off the led. 4 Test Result    This section gives the test results and video of the system. Before testing the voice function, first use MQTTfx to test baidu cloud connection, release, subscription is no problem, and then test sln-local2-iot combined with mimxrt1060-evk voice wake-up recognition and remote control functions.    For SLN-LOCAL2-IOT wifi hotspot join, enter the command in the print terminal: setup AWS kerry123456   4.1 MQTT.fx test baidu cloud connection MQTT.fx is an EclipsePaho-based MQTT client tool written in the Java language that supports subscription and publishing of messages through Topic.    4.1.1 MQTT fx configuration     Download and install the tool, then open it, at first, need to do the configuration, click edit connection: Pic19 Profile name:connect name Profile type: MQTT broker Broker address: It is the baidu could generated broker address, with 1883 no encryption transfer. Broker port:1883 No encryption Client ID: RT1060BTCDShadow, here need to note, this name should be the same as the could shadow name, otherwise, on the baidu webpage, the connection is not be detected. If this Client ID name is the same as the shadow name, then when the MQTT fx connect, the online side also can see the connection is OK. User credentials: add the thing User name and password from the baidu cloud. After the configuration, click connect, and refresh the website. Before conection: Pic 20 After connection: Pic 21 4.1.2 MQTT fx subscribe When it comes to subscription publishing, what is the topic of publishing subscriptions?  Here you can open your thing shadow, select the interaction, and see that the page has given the corresponding topic situation: Pic 22 Subscribe topic is: $baidu/iot/shadow/RT1060BTCDShadow/update/accepted  Publish topic is: $baidu/iot/shadow/RT1060BTCDShadow/update Pic 23 Click subscribe, we can see it already can used to receive the data.   4.1.3 MQTT fx publish Publish need to input the topic: $baidu/iot/shadow/RT1060BTCDShadow/update It also need to input the content, it will use the json content data. Pic 24 Here, we can use this json data: {   "reported" : {     "LEDstatus" : true,     "humid" : 88,     "temp" : 11    } } The json data also can use the website to check the data: https://www.bejson.com/jsonviewernew/ Pic 25 Input the publish data, and click pubish button: Pic 26 4.1.4 Publish data test result   Before publish, clean the website thing data: Pic 27 MQTT fx publish data, then check the subscribe data and the website situation: Pic 28 We can see, the published data also can be see in the website and the mqttfx subscribe area. Until now, the connection, data transfer test is OK.   4.2 Voice recognition and remote control test This is the device connection picture: Pic 29 4.2.1 voice recognition local control Pic 30 This is the SLN-LOCAL2-IOT print information after recognize the voice WW and VC. Red led on: led cycle: 4.2.2 voice recognition remote control   Following test, wakeup + remote on, wakeup+remote off, and also give the print result and the video. Pic 31 remote control:
View full article
  RT1176 has two core. Normally, the CM7 core is the main core. When boot up, CM7 will boot up first. Then it will copy CM4’s image to RAM and kick off CM4 core. The details can be found in AN13264. In RT1176, CM4 has 128K ITCM and 128K DTCM. This space is not big. It is enough for CM4 to do some auxiliary work. But sometimes, customer need CM4 to do more. For example, the CM7 may run an ML algorithm and CM4 to deal with USB/ENET and camera. That need more code space than 128K. In this case, CM4 image should be moved to OCRAM1/2 or SDRAM. OCRAM and SDRAM are both connect to a NIC-301 AXI bus arbiter IP. They have similar performance and character. This article will try to use SDRAM because it is more difficult to move to. Before moving, customer should know an important thing. the R/W speed of CM4 accessing OCRAM/SDRAM is slow. Because the CM4 requests data from SDRAM through XB (LPSR domain - AHB protocol) and then through NIC (WAKEUPMIX domain AXI protocol) and the clock limitation is BUS / BUS_LPSR. If both code and data placed in SDRAM the performance will significantly be reduced. SDRAM is accessible only via SYSTEM bus (so, in such case no harward possible). If any other bus masters are accessing the same memory the performance is even more degraded due to arbitration (on XB or NIC). So, user should arrange the whole memory space very well to eliminate access conflict.   Prepare for the work 1.1 Test environment: • SDK: 2.9.1 for i.MX RT1170 • MCUXpresso: 11.4.0 Example: SDK_root\boards\evkmimxrt1170\multicore_examples\hello_world. Set hardware and software Set the board to XIP boot mode by setting SW1 to OFF OFF ON OFF. Import the hello_world example from SDK. Build the project.   Moving to SDRAM for debug option In CM7 project, add SDRAM space in properties->MCU settings->Memory detail   Then in properties->settings->Multicore, change the CM4 master memory region to SDRAM.   Unlike other IDE, MCUXpresso can wake up M4 project thread and download M4 image by IDE itself. it calls implicit. This field tell IDE where to place CM4 image. In properties->settings->Preprocessor, add XIP_BOOT_HEADER_DCD_ENABLE. This is to add DCD to image's head. DCD can be used to program the SDRAM controller for optimal settings, improving the boot performance. Next, switch to CM4 project. Add SDRAM space to memory table, just like what we do in CM7 project.     In properties-> Managed Linker Script, it’s better to announce Heap and stack space in DTCM. It also can be placed in SDRAM, but this should be careful. After that, we can start debugging. You can see that the SDRAM has been filled with CM4 image. Click Resume button, the CM4 project will stop at the beginning of the Main.   Moving to SDRAM for release option To compile the project in release mode, CORE1_IMAGE_COPY_TO_RAM should be added to Defined symbols table. But that is not enough. The CM7 project of SDK doesn’t copy the CM4 image. We must add this to CM7 project. 3.1 Create a new file named incbin.S. This is the code .section .core_m4slave , "ax" @progbits @preinit_array .global dsp_text_image_start .type dsp_text_image_start, %object .align 2 dsp_text_image_start: .incbin "evkmimxrt1170_hello_world_cm4.bin" .global dsp_text_image_end .type dsp_text_image_end, %object dsp_text_image_end: .global dsp_data_image_start .type dsp_data_image_start, %object .align 2 dsp_ncache_image_end: .global dsp_text_image_size .type dsp_text_image_size, %object .align 2 dsp_text_image_size: .int dsp_text_image_end - dsp_text_image_start 3.2 In hello_world_core0.c, add these code #ifdef CORE1_IMAGE_COPY_TO_RAM extern const char dsp_text_image_start[]; extern int dsp_text_image_size; #define CORE1_IMAGE_START ((uint32_t *)dsp_text_image_start) #define CORE1_IMAGE_SIZE ((int32_t)dsp_text_image_size) #endif 3.3 Right click the evkmimxrt1170_hello_world_cm4.axf in Project Explorer window, select Binary Utilities->Create Binary. A binary file called evkmimxrt1170_hello_world_cm4.bin will be created. Copy it to the release folder of CM7 project. If you want this work to be done automatically, you can add the command to properties->settings->Build stepes->Post-build steps   Compile the project and download. Press reset button. After a while, you will see a small led blinking. This led is driven by CM4. Debug the CM4 project on SDRAM only As we know that CM4 can debug alone without CM7 starting. But that is in ITCM and DTCM. Can it also work in SDRAM. Yes, but the original debug script file is not support this function. I attached a new script file. It can initialize SDRAM before downloading CM4 code. Replace the old .scp file with this one, nothing else need to be changed.
View full article
