The Capture feature of eFlexPWM module
Document created by xiangjun.rong Employee on May 22, 2018Last modified by xiangjun.rong Employee on May 22, 2018
Version 2Show Document
  • View in full screen mode
The eFlexPWM module is an important module, integrated in DSC, Kinetis KV, i.mxrt, MPC56xx families, it can output PWM signals. But it has capture function, can accept synchronous captured signal(synchronous  with it's output PWM signal) and accept asynchronous captured signal, can generate interrupt once the captured signal arrives, can figure out the duty cycle and cycle time of the captured signal.
The DOC introduces the capture feature, capture mechanism, it also describes how to configure the PWM pin as capture pin, how to generate capture interrupt, how to figure out duty cycle and cycle time. in the end, it gives the code snippet.
1 person found this helpful
Outcomes
