Bootloader demo steup - USB DFU.pdf
Hi Team :
     Recently we are working on USB DFU , there are some experience to share with you .
David
Comments
Hello David:
Thanks a lot for sharing this, good teaching material. You may want to move it or repost to Kinetis Microcontrollers community space so more people can see it (just a suggestion).
Note: From what I know the DFU example in the USB stack is not supposed to work. It just shows the enumeration as DFU class, but it is missing the s19 parser and the flash programming routines. As you mentioned the working code is in AN4370.
Regards!
Jorge Gonzalez
Hi Jorge :
     You are welcome and thanks for your suggestion and sharing in note that helpful .
David
No ratings
Version history
Last update:
‎10-29-2014 07:34 PM
Updated by:
