No matter what I try, I cannot get #pragma INLINE to work.
The compiler constantly throws a "Warning : illegal #pragma"
I can see #pragma INLINE described in the CodeWarrior help file.
Any ideas ?
J
Solved! Go to Solution.
That pragma is for the HC08/S08/RS08, not for Coldfire.
Thanks Daniel.
Unfortunately, it's not very clear when I am using the CodeWarrior help system. It's hard to figure out which book you're viewing after you choose a particular Search result or item from the Index.
I guess this is one disadvantage of having an IDE that supports multiple processor families but implements certain features in different ways ... sigh !
