Simple FLASH access in C language, for 9S08GT, it's possible?
hernanEche
It's posible from C language to simple write/read a byte in FLASH  (as if were an EEPROM)?
The micro is 9S08GT
I need to store a value that
  • Keep value after power off
  • Can be changed in runtime
The normal answer is : an external EEPROM
but, can it be done with FLASH and avoid external EEPROM?
peg
Senior Contributor IV
Hello and welcome to the fora.
Yes you certainly can do this.
Do a search in the 8 bit microcontroller forum for the multitude of threads on this subject to be found there.
Good Luck!
peg
Good Luck!
hernanEche
I am glad that is possible, I will search those threads, thanks!
