NXP NTAG I2C can't be accessed via RF anymore
xnormanw
Hi NXP-forum,
After trying out some things with the NC_REG, NS_REG and Lockbytes, I can't write anything on the NTAG via RF/NFC. I've tried out several apps and also included the .xml-file from the Tag Info App. I also tried to reverse all my settings (reset NC_REG, dynamic & static lockbytes), but I still get the error "write tag failed" on the app, and any other app I tried out. Resetting the tag and trying to change the NS_REG doesn't work, since the NTAG can't be written by RF anymore.
I'm thankful for every help!
Kind regards
Norman
xnormanw
Does no one have another solution for this? I still can't get it to work and it happened to two ntags already after writing to them via pass-through.
Kan_Li
Hi Norman,
If just writing failed on your side, please check the static lock bytes as well as the dynamic lock bytes as below , maybe you lock some space by accident.
Kan
Kan_Li
Hi Norman,
Did you ever try the NTAG I2C Demo App? it should be available from google play or App store.
Kan
xnormanw
Hi Kan_Li,
thank you for your response.
I also tried the NTAG I2C Demo App for phone and PC, both can't write on the eeprom. Reading registers however works.
Kind regards
Norman
