ls1046ardb support is not present in downloads page
ashish_kumar
Hi all
I have download the LS1046ARDB source ISO , i am trying  to install
". ./fsl-setup-env -m ls1046ardb" , but I did n't see the support for machine ls1046ardb
& source is : Source: QorIQ Linux SDK v2.0
can  you please provide proper version of source to build for Ls1046ARDB.
I want to get pre built images for LS1046ARDB & Build procedure for LS1046ARDB using SDK
can you please provide the same.
I am not identifying the device LS1046ARDB connected to My ubuntu pc & windows pc , both are not identified
can you please help on that.
Thanks & Regards
Satish G
yipingwang
Hello Ashish Kumar ,
Please download and install "QorIQ Linux SDK v2.0-1703" Patch release from Linux® SDK for QorIQ® Processors | NXP .
Yiping
ashish_kumar
Hi YiPing
I am using "Update: QorIQ Linux SDK v2.0-1703"   from https://nxp.flexnetoperations.com/control/frse/download?element=7726177 , having issues with this
error log which I have added is from 1703 build only.
Could you please provide me successful build release  "Ubuntu 18.04 for LS 1046 ARDB",
Thanks & Regards
Satish G
yipingwang
Ubuntu release for LS1046ARDB, you need to download and install LSDK 19.09 from Layerscape SDK | NXP .
