I.MX8 MINI CPLD Design ??
gap5228
Hi. I have a question while reviewing the use of the I.MX8 MINI.
I want to connect XC9572XL to I.MX8 MINI.
In case of using I.MX6 SOLO, CPLD is controlled by connecting to External Interface Module (EIM).
In case of I.MX8 MINI, EIM Interface group is not visible. How can I design with the same structure as above?
Rita_Wang
The I.MX8 MINI EIM Interface group is not visible, but you also can use CPLD, you can use such as mmc port. Here could you tell us which function do you want to make use the CPLD?
