我现在在IMX8QM板上使用HDMI,但是由于显示器分辨率不在内核支持的枚举内,所有启动时无法正常显示,该屏幕具有自己的EDID,但是linux没有应用它。请问大家有没有解决方式,必须修改内核配置EDID支持,还有添加异形屏参数的指导~
you should modify mxc_hdmi.c and mxc_edid.c according to your hdmi edid, but now imx8qm is under preproduction, we don't have further detailed information, if you need further help, pls contact professional service:
谢谢你的回复~
另外请问一下,android auto 9.0 怎么旋转显示内容,静态的180度(显示器反转了),我使用的是LVDS转HDMI的显示器。感谢~
I have already replied to you in your anther thread
