Cyclone Universal CRC-16 problem
sutas_j
1. Why the CRC are different with another program?
2. Could explain about cyclone CRC (polynomial, algorithm)?
3. Can the cyclone generate another CRC type (CRC-8,CRC-32)?
Background
Before create .SAP file for storage in the cyclone memory, We can see the CRC of the .S19 file.
After that we use CRC-16 (see detail as below ) for control the software.
and then we need to confirm the CRC-16 before production but can’t (we use another program for check it) see detail as below.
mahi
Although several distributors (e.g. digikey, mouser) list the Cyclone devices as manufactured by NXP, they are from PE Micro --> PEmicro | Experts in Embedded tools for Flash Programming and Development
danielmartynek
Could you please contact PE Micro support, they should provide you with the answers.
Cyclone PRO is not an NXP product.
Thank you,
BR, Daniel
sutas_j
Thank you for your suggestion.
