ZigBee Stack code for KW24D
haimliberman
Is it possible to get ZigBee stack code  for KW24D, I am having issue with UART communication.
The UART stops responding and when I tried to run in debug mode I found that TS_ApsTask which is part of the compiled library is sending events to itself and never gives control to Uart_Task. To further investigate the issue we need the stack code.
estephania_mart
The currently supported stacks by KW24D are: Thread, 802.15.4 MAC and SMAC.
Currently the available devices with ZigBee support are the JN516x family.  ZigBee 3.0 supported on KW41Z , nonetheless,  currently there are no plans to support this stack in KW24D.
Still, We do not provide the source code of the libraries of the framework.
Sorry for the inconveniences this might cause you
Estephania
