MCU MKE04Z128VLK frozen after power up
ricardcomas
Hello mates, I haveing some trouble with this MCU,due something, my MCU doesn't work after power up (only sometimes it does), However, MCU has been configured as another of same family. I often disable NMI PIN from CPU Component (processor expert), so far, I never haven't had any problem.
Could somebody help me?
Thanks so much folk!
Labels (2)
Tags (2)
ricardcomas
We just fix this issue, we forgot place a resistor that was necessary for work.
Thanks so much
ricardcomas
Thanks so much
Alexis_A
Hi Ricard,
Are you using a custom board?
If this is the case, could you share the reset section of your schematic?
Alexis Andalon
