How to select a proper MCU for a specific application
caoguojun
How to select a MCU chip for a specific applicatio,just like automotive body control;
Expect for the interfaces,such as:
What is the proper max opperating Freqency,how to confirm if it can cover the needs(CAN、LIN....)
and the need for memory(flash and RAM).
THANK YOU!
davidtosenovjan
I could recommend following brochure as a starting point:
https://www.nxp.com/docs/en/product-selector-guide/BRAUTOPRDCTMAP.pdf
Then you can discuss it for instance here on our community pages.
caoguojun
Thanks for  your reply.
Actually,we want to know what is the proper max opperating freqency for the application,or how to evaluate the need of max opperating freqency.
davidtosenovjan
I am afraid this does not have any simple answer. It purely application dependent and a choice is up to you (what is key factor for the selection - performance, current consumption, etc.)
