What is the part number for a 4P16T analog switch suitable for switching between up to 16 smart cards?
jsmoot
I'm designing a device to switch between up to 16 smart cards. Only Vcc, data, clock and reset will be switched. What part number would be suitable for this application?
guoweisun
For your similar application we have Dual SIM Card Switching w/ NX3DV2567.
jsmoot
In order to use the NX3DV2567 it would require 15 of them to switch between 16 SIM cards. That seems about as inelegant a solution as using the required number of motorcyles welded together to haul a the amount of cargo a semi truck could haul.
I'm trying to find a part that would require only one IC or at worst, a SP16T which would only require a quantity of 4 to accomplish the task.
guoweisun
We only have this one NX3DV2567 for SIM Card analog switch!
