Debug MPC5744P use U-MULTILINK to program 0x08FD0000 address range faillure
tonyxu
uses U-MULTILINK to debug MPC5744P, but can't program the constant data to flash address from 0x08FD0000 to 0x08FEFFFF. But uses Lauterbach tools thatt is ok. So can you help?
lukaszadrapa
do you use S32 Design Studio? You need to use the right pcp programming algorithm to be able to program the mirror area. It can be changed here:
Search for pcp files in installation folder of S32 Design Studio and use the right one (mirrored):
Lukas
