LTIB-ERROR-MPC5125
LTIB-ERROR-MPC5125
geekdarcy
I am trying to install LTIB from MPC512xADS_20090603-ltib.ISO for MPC5125 under Ubuntu 12.04 32 bit.
the build fails and I get the following error:
Processing: rpm-fs
ERROR: /tmp/rpm-geekdarcy/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm
would clobber '/reescale/ltib'
traceback:
 main::check_host_clobber:2665
  main::build_rpm:906
   main::f_buildrpms:980
    main::check_rpm_setup:2396
     main::host_checks:1423
      main:542
Started: Mon Nov  5 22:32:49 2018
Ended:   Mon Nov  5 22:32:49 2018
Elapsed: 0 seconds
Build Failed
And I have installed ubuntu-ltib-patch.
This is my first time using LTIB to build a BSP.
Does anyone know what I am doing wrong? Any clue about that error?
Kind regards!
Tags (2)
