S32DS Post-Build bat
yangdongyu
I want run a bat file,after build finished.
In S32DS for Power or S12Z, It works good.
But In S32DS for ARM, Post-Build a bat have problems like this
make --no-print-directory post-build
{my project path}\test.bat
{my project path}\test.bat: line 1: @echo: command not found
Test
It seems the S32DS doing the parse for my bat, and I can't passing parameters to bat normally.
yangdongyu
Use cmd /c {path}/bat
yangdongyu
