FRDM-KL43Z I2S Sample Code
ellenlin
Now i am using KL27Z256 ( FRDM-KL43Z ) , About I2S module , i haven't see any Sample code in it SDK Sample ,
And , i saw the Flexio-Sai in TWRKL43 , in this case , have any different between FLEXIO-SAI and I2S ?
I don't know how to choose it , thanks a lot !!
if have some difference , please provide me a I2S Sample code can using on FRDM-KL43Z , Thanks !!
jorge_a_vazquez
Hi e Lin
The examples codes of I2S for the KL27Z256 are located in the SDK package, you can find them under:
SDK_2.4.1_MKL27Z256xxx4.zip\boards\twrkl43z48m\driver_examples\sai\
Those examples are for the TWR board and using the sgtl5000, but there shouldn't be any problem to migrate the project to the frdm board, the main difference is the connections.
Hope this helps
