There are some demo binaries for imx8mq-evk. I found them in output folder after building source. I am using meta-fsl-bsp-release (4.9.88-2.0.0)
IMAGE_BOOTFILES += "imx8mq_m4_TCM_hello_world.bin imx8mq_m4_TCM_rpmsg_lite_pingpong_rtos_linux_remote.bin imx8mq_m4_TCM_rpmsg_lite_str_echo_rtos.bin"
My question is "Is there any document or user guide that help me flashing these firmware to M4 core?" I don't know how to use these firmware. Many thanks for help!
Solved! Go to Solution.
Hi Thinx
please download SDK on below link, follow sect.6 Running an application by U-Boot
Getting Started with MCUXpresso SDK for i.MX 8M Quad.pdf which is also attached
Hi Thinx
please look in documentation included ini.MX8M SDK;
Board Support Packages (11)
SDK_2.3_MX8MQ_Beta
i.MX 8M Evaluation Kit|NXP
Hi Igor,
I follow your instruction. It takes me to download "iar_segger_support_patch_imx8". Though It is useful, I am looking for another way. Eg. use u-boot to start M4 core (correct me if i am wrong).
Hi Thinx
