Thank you Peg,
i found about jB16, but JB16 has a preinstalled monitor code to connect via usb.
I have JB8 and i am a step behind. I have download an2398SW application note, i have programmed the firmware on the chip but i can't get the connection with the device. WinXP see the new hardware but icpexe program fails to connect (error in open_device()).
Usb routines must be programmed in user code before connecting??
Any help, thank you
Five
