Is there a isolate debuger and programmer
wushenhui
When I modify the code in the "Generate Code" dir. The IDE will erase my modification, I would like to edit the code use my favorite editor and compile the code in the command line. it finally generate an *.elf. Is there any utility to use this elf to start debug and program the chip?
BlackNight
You can disable code generation, see Disable my Code Generation | MCU on Eclipse
I hope this helps,
Erich
ZhangJennie
HI Wu,
elf file includes burning code, so you can use it directly to program flash. But you can't modify it if you don't have source code.
Here is an article tell you how to program elf/s19 with CW simple flash.
Standalone Flash Programmer | MCU on Eclipse
Does this answer your question?
Jennie Zhang
wushenhui
Sorry, did you forget to add a superlink in "Here" in your sentense. I can't click on "Here" to link to the article.
ZhangJennie
Hi Wu,
I just added it. Hope this helps.
Jennie
wushenhui
It helps, yes, now i have my own development environment, editor, compilier, uart debug, the last, programmer.
Thanks a lot.
ZhangJennie
you are welcome.
Jennie Zhang
