printf function example for MPC5777C using s32 design studio
vrushalitaklika
Can someone help with example function for MPC5777C controller using s32 design studio?
vrushali
jiri_kral
if you need printf for debug purposes - you can use for example ewl_c library with Debugger console:
In debug settings enable semihosting:
You can see the print output in debug session console.
Jiri
harsha_jakkamkr
Hi Jiri,
Is it possible to print with different colors on the console?
Harsha
harsha_jakkamkr
Works like a charm.
Thanks!
