Help to know the right name of the component.
lennonzanotti
Hi, I have here a component that was purchased from NXP and
I can not figure out the correct name of this component.
It is an 8-pin SMD IC that contains the number 1732 written on it.
Its application is for led lamp. Could someone help me figure out which component is?
guoweisun
Hi ,
If you would like search the IC for high power LED driver controllers,I am afraid that you can't get result.
Because LED driver controllers of NXP has already transfer to Silergy Corp in 2016,so you can search it in Silergy corp.
Thanks!
