Hi All, I am facing issue while loading image in MIMXRT1050-EVK.
This I used for hello_world program with the default settings. I followed "http://www.keil.com/support/docs/2831.htm" link as well but no success. Attaching the log for reference,
Load "C:\\Users\\ARM\\SDK\\boards\\iMXRT1052_DevelopersKit\\demo_apps\\hello_world\\Objects\\hello_world.axf"
No Algorithm found for: 00000000H - 00002507H
Erase skipped!
Error: Flash Download failed - "Cortex-M7"
Hi Krishna,
my understanding is that you are using Keil and you are trying to download the application to flash.
- Probably keil does not provide a mechanism to download application to flash as it does not have the flash alorithm. In this case you are not able to debug from flash, only from ram.
- You can download your application to flash using the serial downloader (see attached document) but you wont be able to debug.
Carlos
Hi Carlos,
Thanks for your reply.
I am using μVision5 IDE and ULINK2. Using ULINK2 as a debugger and as well as programmer.
<< You can download your application to flash using the serial downloader (see attached document) but you wont be able to debug.>>
you mean I can not download the application code into HyperFlash by using ULINK2??
<<my understanding is that you are using Keil and you are trying to download the application to flash>>
I am using ULINK2 with μVision5 IDE .
If we can download to flash by using ULINK2 ,Please suggest .
