can bus test register
ianbenton
Senior Contributor I
Table 399 of the LPC15xx user manual states that bit 7 of the CAN test register will be zero if CAN_RX is high, and one if CAN_RX is low.
I find that exactly the opposite is true.
Please clarify.
jeremyzhou
Hi  Ian Benton,
the opportunity to serve you.
Yes, you are right and I'll report this typo to the Doc team.
TIC
