S32K146上电复位脚为低,无法debug
zhengjianfei
Hi,各位,大家好,最近在S32K146上遇到一个问题。我们打好S32K146的电路板,贴上S32K146(仅仅只贴了MCU和复位脚上拉电阻;晶体,滤波电容等均没贴)。上电后无法debug,用JLINK也无法连接,检查发现reset脚一直处于低电平(有10k上拉电阻)。试了几个板子,均是如此。想请教下各位为何reset脚会被强制拉低,原理图中是否还有其他需要注意的地方呢?
danielmartynek
The MCU keeps resetting itself when the part is blank, there is no code to be executed.
You may refer to the below application notes.
AN12130 Production Flash Programming Best Practices for S32K1xx MCUs
AN5426 Hardware Design Guidelines for S32K1xx Microcontrollers
luoxin1
The problem has been solved because of the reasons for using pirated J-LINK.Thanks for your support.
zhengjianfei
Hi,Daniel:
