IAP on lpc11u3
IAP on lpc11u3
sanketk
I am using a lpc11y3x device. I want to implement In application programming for the same.
But I am not able to get,  how do I jump from the iap code to my main application.
Is there any application note for the same or some example code to refer.
Sanket
kerryzhou
Hi Sanket K,
    About the IAP usage, you can refer to our application note AN11511, there has the document and the code for your reference.
https://www.nxp.com/docs/en/application-note/AN11511.zip
Wish it helps you!
Kerry
sanketk
The device is lpc11u3x
