The pulseaudio problem
yenchou
Hello,All:
Version: Linux imx6qsabresd 4.1.15
After I opened the computer,I found the err:
E: [pulseaudio] main.c: Failed to find user 'pulse'.
pulseaudio -v
E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="1" name="platform-sound-hdmi" card_name="alsa_card.platform-sound-hdmi" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
E: [pulseaudio] module-console-kit.c: GetSessionsForUnixUser() call failed: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.ConsoleKit was not provided by any .service files
E: [pulseaudio] module.c: Failed to load module "module-console-kit" (argument: ""): initialization failed.
E: [pulseaudio] main.c: Module load failed.
E: [pulseaudio] main.c: Failed to initialize daemon.
Please advise if necessary.
Thank you for your assistance.
Best wishes,
Yen
art
Most likely, your rootfs has become damaged for some reason. Try to reflash your boot media.
Artur
yenchou
Thank you with your advice.
Best wishes,
Yen
