Breakpoints not working after KDS/PEMicro update
asfarley
I've seen a couple similar error reports but none with exactly these symptoms.
1) Updated KDS to 3.2.0
2) Updated PEMicro KDS plugin to 3.2.4.201710241511
3) Other packages were automatically updated (GNU ARM compiler etc) although I suspect they're not the root cause
I'm using an MK22FX512VLQ12, Win10 under Mac OSX Parallels 13.
Now, my code will not stop on breakpoints while debugging. This was definitely working before.
I have confirmed:
  • "Skip all breakpoints" is disabled
  • I've only added one breakpoint (removed all, then added 1 new breakpoint)
  • The initial startup breakpoint is working
  • Single-stepping seems to work until I hit a Wait function
  • The code with the breakpoint is definitely being executed, confirmed via UART
Anybody else encountering this? Is there a workaround or fix available? (or even a hint about what is causing this?)
I've contacted PEMicro with the same error report, will post back here if I get new information.
jairocaballero
asfarley‌  Have you found a solution? I have the same problem with a LPCXpresso54114 in MCU Xpresso IDE
asfarley
Haven't looked into this again. Can you confirm: are you using a PEMicro Multilink Universal programmer?
jairocaballero
I'm using an example of SDK with a typical debugging configuration to see
the correct operation of my MCU. This under the MCUXpresso IDE. But, I
think that my problem is about incorrect debugging process, because the
example is based on FreeRTOS or similar and we have to make a debug over
the OS. See this documentation.
https://freescaleesd.flexnetoperations.com/337170/577/11781577/MCUXpresso_IDE_FreeRTOS_Debug_Guide.p...
​Thank you.​
*Jairo Andrés Caballero Peña *
E&E Eng. MsC Student
Junior Researcher & Teaching assistant
Electrical Machines and Drives - EM&D Research Group
Department of electrical and electronic engineering
Faculty of engineering
Bogotá Campus
Tel.: (57) 312 4378221 (directo)
Universidad Nacional de Colombia
http://www.ing.unal.edu.co/grupos/emd/
Volunteer - Industry Applications Society - IEEE
https://www.facebook.com/isaiasun
This message and its attachments are addressed to be used exclusive by
the recipients and it can include confidential information or legally
protected information. If you aren't the recipient, it's notified that any
distribution or reproduction of this material is prohibited. If you have
this message in error, please immediately notify us and delete the original
text including the attachments, or delete any reproduction of this. The
opinions expressed in this e-mail are exclusive responsibility of sender
and it not necessarily represents a institutional position of the
Universidad Nacional de Colombia, the use of this informaion made by the
recipient doesn't compromise the institutional responsibility. This message
have been checked with antivirus software; accordingly, the Universidad
Nacional de Colombia doesn't be responsible by the virus presence or
malicious software here, or in the attachments that could make damages.
Please, before printing this e-mail think if is truly necessary make it. Caring
for the environment and making a better world are our responsibility.
2017-11-21 12:37 GMT-05:00 asfarley <admin@community.nxp.com>:
NXP Community
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: Breakpoints not working after KDS/PEMicro update
reply from Alexander Farley
<https://community.nxp.com/people/asfarley?et=watches.email.thread> in *Kinetis
Design Studio* - View the full discussion
<https://community.nxp.com/message/963252?commentID=963252&et=watches.email.thread#comment-963252>
asfarley
Well, I'm not sure what I was experiencing but my PEMicro Multilink/KDS combination seems to be working again. I'm able to place and hit breakpoints as expected.
I haven't been using FreeRTOS or thread-aware debugging, so I think we're probably seeing different issues.
