Issue about the PWM module in MPC5744p.
weijiezhang
I want to use the four PWM channels below:
PWM0_A3,PWM0_B0,PWM0_B2 OK,PWM0_B3;
But it seems that they can't run at the same time , when the B0 and B2 work , A3 and B3 channel don't work,
i don't konw why , anynoe can tell me how to solve the problem?  Thanks a lot.
petervlna
Hi.
Hmm there should be no issue.
But you do not explain your problem in your post. So it is impossible to judge where is the issue.
I can check your code if you want to share it.
Peter
