FRDM KL25Z RGB DEMO not working out the box.
falahzaidan
Just brought my KL25Z board, plugged it in the usb and am tilting it but it isn't lighting up the LED as i've read it should be.
Any ideas why?
Robin_Shen
The color mix of the RGB LED should change based on the accelerometer data.
Please try to program accelero_i2c_rgb.srec example by using the MSD Flash Programmer.
You can find the accelero_i2c_rgb.srec after download the FRDM-KL25Z Quick start package.
Robin
