SDA is pulled low on 9th clock pulse!(NTAG Tag NT3H1101 )
tarikah
Hello Dears,
I am working on interfacing MSP430 with NT3H1101 with I2C. I could not read from the NTAG as the SDA is pulled low on 9th clock pulse. I found that it is related to clock stretching bit on register I2C_CLOCK_STR. my question is how can  disable the I2C clock stretching and i cannot access the NTAG because the 9th clock is pulled low?
what shpuld i do that i can communicate with the NTAG?
best regards,
tarik
Tags (2)
Kan_Li
You may access E9h via RF interface.
Hope that helps,
Kan
